    KT
    49 Posts 9 Posters 8.2k Views 9 Watching
    • david57D Offline
      david57
      Here's a test render with lots of mistakes.
      • david57D Offline
        david57
        Another test render.
        • jenujacobJ Offline
          jenujacob
          by misstakes u mean the plants rite??? u just need a png image and turn on the alpha map in the clipping option! πŸ˜‰
          • david57D Offline
            david57
            • david57D Offline
              david57
              Well, I'm just trying to keep up with Jone's and the Smiths.
              • david57D Offline
                david57
                Another render of Blenders Lsystem Trees.
                • david57D Offline
                  david57
                  • david57D Offline
                    david57
                    Two more renders. Imported trees into SketchUp and separated some twigs
                    from the branches and trunk.
                    Populated the twigs with the same leafs i used for the hedges.
                    • david57D Offline
                      david57
                      and a another...
                      • david57D Offline
                        david57
                        Here's an 11,000 polygon tree. Small enough to work with SketchUp.
                        Using a small laptop, 797 MHz, 512 MB of RAM.
                        • david57D Offline
                          david57
                          Here's the output.
                          • FrederikF Offline
                            Frederik
                            It looks really good, David..!! πŸ˜„
                            Are you planning to make some of these trees into model libraries..??
                            Cheers
                            Kim Frederik
                            • david57D Offline
                              david57
                              Frederik,
                              I don't know yet if im going make any model library's, it's to early to say.
                              Ive only have 9 normal looking trees.
                              and here's another, i added some toes to the base of the tree with blenders
                              sculpt mode tools.
                              • david57D Offline
                                david57
                                ...and here's the result. Nothings perfect, UV's are not setup correctly on any of
                                the trees.
                                • david57D Offline
                                  david57
                                  This is one of my best settings of been using. Just press Generate many times
                                  for random trees. If any body can find better settings let us know.
                                  • david57D Offline
                                    david57
                                    another.
                                    • david57D Offline
                                      david57
                                      • david57D Offline
                                        david57
                                        Starting up another.
                                        • david57D Offline
                                          david57
                                          Download the 3DS file from here.
                                          (www.mediamax.com)
                                          • 2 / 3
