    KT
    49 Posts 9 Posters 6.4k Views 9 Watching
    • david57D Offline
      david57
      Two more.
      • david57D Offline
        david57
        Here,s another render.
        • david57D Offline
          david57
          Model in the background was not made by me.
          Model can be found at
          http://archidom.net/ddd/model_S.htm
          • david57D Offline
            david57
            Needs Pillars or Columns under the radius.
            • david57D Offline
              david57
              Trying to figure this one out, before a render. Need to remove the door ways
              on the first floor, they look like men and women restrooms.
              • david57D Offline
                david57
                • david57D Offline
                  david57
                  Here's a Progressive Path Tracing. I could'nt get rid of the arched door ways. I didnt
                  have the guts.
                    Never mind. Toilets/bathrooms are always needed.
                    But how come that tree is growing from the pavement? 😲
                    Nice render BTW
                    • david57D Offline
                      david57
                      Here's a test render with lots of mistakes.
                      • david57D Offline
                        david57
                        Another test render.
                        • jenujacobJ Offline
                          jenujacob
                          by misstakes u mean the plants rite??? u just need a png image and turn on the alpha map in the clipping option! πŸ˜‰
                          • david57D Offline
                            david57
                            • david57D Offline
                              david57
                              Well, I'm just trying to keep up with Jone's and the Smiths.
                              • david57D Offline
                                david57
                                Another render of Blenders Lsystem Trees.
                                • david57D Offline
                                  david57
                                  • david57D Offline
                                    david57
                                    Two more renders. Imported trees into SketchUp and separated some twigs
                                    from the branches and trunk.
                                    Populated the twigs with the same leafs i used for the hedges.
                                    • david57D Offline
                                      david57
                                      and a another...
                                      • david57D Offline
                                        david57
                                        Here's an 11,000 polygon tree. Small enough to work with SketchUp.
                                        Using a small laptop, 797 MHz, 512 MB of RAM.
                                        • david57D Offline
                                          david57
                                          Here's the output.
                                          • FrederikF Offline
                                            Frederik
                                            It looks really good, David..!! πŸ˜„
                                            Are you planning to make some of these trees into model libraries..??
                                            Cheers
                                            Kim Frederik
                                            • 2 / 3
