    KT
    49 Posts 9 Posters 8.9k Views 9 Watching
    • david57D
      david57
      Tried Clipmaping of leafs, but couldn't get the right results.
      • david57D
        david57
        • david57D
          david57
          Tree Trunk, Branches,and 10 Leafs were made with a Blender script called Gen3.
          Made Components with Trunk, Branches, and only 10 Octagon Leafs in SU.
          The same Ten Leafs were used for the Hedges, but smaller.
          • david57D
            david57
            Two more.
            • david57D
              david57
              Here,s another render.
              • david57D
                david57
                Model in the background was not made by me.
                Model can be found at
                http://archidom.net/ddd/model_S.htm
                • david57D
                  david57
                  Needs Pillars or Columns under the radius.
                  • david57D
                    david57
                    Trying to figure this one out, before a render. Need to remove the door ways
                    on the first floor, they look like men and women restrooms.
                    • david57D
                      david57
                      • david57D
                        david57
                        Here's a Progressive Path Tracing. I could'nt get rid of the arched door ways. I didnt
                        have the guts.
                        • GaieusG
                          Never mind. Toilets/bathrooms are always needed.
                          But how come that tree is growing from the pavement? 😲
                          Nice render BTW
                          • david57D
                            david57
                            Here's a test render with lots of mistakes.
                            • david57D
                              david57
                              Another test render.
                              • jenujacobJ
                                jenujacob
                                by misstakes u mean the plants rite??? u just need a png image and turn on the alpha map in the clipping option! πŸ˜‰
                                • david57D
                                  david57
                                  • david57D
                                    david57
                                    Well, I'm just trying to keep up with Jone's and the Smiths.
                                    • david57D
                                      david57
                                      Another render of Blenders Lsystem Trees.
                                      • david57D
                                        david57
                                        • david57D
                                          david57
                                          Two more renders. Imported trees into SketchUp and separated some twigs
                                          from the branches and trunk.
                                          Populated the twigs with the same leafs i used for the hedges.
                                          • david57D
                                            david57
                                            and a another...
                                            • 2 / 3
