    Need Help on SPIRALOID SHAPE
    25 Posts 9 Posters 4.6k Views 9 Watching
      GreyHead
      Hi simon,
      I'll try to add the extra step later this evening.
      K2 Graphs seems to be here but I think I got it as part of whole bundle of scripts that I downloaded from here but now can't find.
      Bob
        K_tools.rb is what you need...
        404 Not Found
        (www.crai.archi.fr)
        • simon le bonS Offline
          simon le bon
            • -/ I feel Stupid - - -
              In the hurry i had taken first step smartsizer' shape to follow his purpose. Eureka the result was great. But there is a secret. We can't obtain this shape with a simple intersection with a plane. The top of the wall is shaped with two helicoidal lines. And how smartizer have did that: it's a mystery. Probably to discover in Ruby arcanes... Also my enthusiasm, under your eyes in the board has been driven to a flop . And my poor Horseshoe stair is still on the paper.
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/NotsosimpleBalustre.jpg
          dear GreyHead and tig thanks for K_tools.rb (ha! K-Two). Now i need little work to understand how use it.
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/coquille.jpg
          • boofredlayB Offline
            boofredlay
            Sorry I have not read all of the posts in this but would the Spiralizer help you???
            301 Moved Permanently
            (www.sketchucation.com)
            I am not sure you can get a flat top on it or not with the spiralizer but it is worth a try.
              GreyHead
              😄 Keep going, I learn a lot by trying things out here and experimenting.
              As far as I can see Smartsizer did it by creating that grid of lines on each side and drawing in diagonals by hand.
              Bob
              PS I'll take a look at Spiraliser
              PPS I'm experimenting with a script to do some of this but it's slow work - a first script squeezed in odd moments. So far so good.
                simon le bon
                It appears that you are probably right dear GreyHead. Smartsizer seems have drawn his diagonals by hand.
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/diagsdrawbyhand-1.jpg
                I haven't found the way to draw your volute with k-tools.
                  smartsizer
                  Yes, the diagonals are drawn by hand. Details are shown in the Scenes in the attached skp. Scenes 24 and 25 illustrate a method I discovered to manipulate points in a mesh.
                  HorseshoeStair tutorial.skp
                    GreyHead
                    My spiral was something like:
                    K2 Graphs | 2D-Graph polar r=f(p)
                    p-range from: 0.0 (default)
                    p-Range to: 25.132741 (i.e. 8*pi)
                    Stepwidth: 0.06283185 (default - 100 steps per turn)
                    r = p**2 (default)
                    Then scale down to a useful size.
                    Bob
                      GreyHead
                      Bien fait ! Bravo !
                      Bob
                      PS You can get rid of those 'blue' segments at the bottom by selecting a 'white' area, right click and choose 'orient faces'.
                        simon le bon
                        THAT'S IT!
                        Here is my HORSESHOE STAIR with volute ramps.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final3.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final4.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final5.jpg
                        The volute and the leading help of GreyHead, a working direction to follow by smartsizer, many mistakes repaired by fox hack, pair of things i haven't understood at all, and at last, still lot of hard handmade work!!
                        (as you can see here)
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/intermediatVolute-2.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/intermediatVolute_b.jpg
                        (if someone is interested by this laborious travel: DivShare File - HorseshoeStairFinal.skp
                        All my thanks (in order of apparition) to: Greyhead Gaieus smartsizer Tig Boofredlay. You where incredibly kind and perseverant by my side.
                        At the end, smartsizer have given us a so beautiful lesson of drawing: so many strong solutions HorseshoeStair tutorial.skp. It surely have to be sent as a single post on the How To section: for great advantage of everybody interested in Sketchup (and 3D) modeling.
                        . Well, for horseshoe stair, it's over. But i have another project i shall call "The Everythingcurved Stair". Just the good matter to take off with it.
                                         simonlebon
                        • Wo3DanW Offline
                          Wo3Dan
                          Simon,
                          I see that you finished your horse shoe shaped stairs, resulting in a very nice model.
                          Thanks for sharing. Looking forward to what curved complex shape you have in mind now.
                          cheers,
                          Wo3Dan
                          • V Offline
                            Voder Vocoder
                            Here's another variation:
                            http://www.datafilehost.com/download-455bae85.html
                            ~Voder
                              simon le bon
                              Dear Voder Vocoder
                              WAHOUUU! what a pure splendid way to reach the end..
                              Lot of hand made too, as sculptor work, but with each step simple, beautiful..
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/VoderVocoderSpiraloid2-1.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/VoderVocoderSpiraloid-1.jpg
                              How many ways left to do the job? This topic is becoming a Top Master Class lesson of drawing.... Happy!
                              PS: I allow me to put your VoderVocoder_HorseshoeStair SKP file on DivShare
                              To allow permanent access. Because with Data File Host:
                              "Your file is hosted forever as long as it gets downloaded at least one time every 30 days"
                                smartsizer
                                Voder---very nice!!
                                • TaffGochT Offline
                                  TaffGoch
                                  Simon,
                                  When I stumbled across this image while web-surfing, I immediately recalled your discussion thread:
                                  This is a violin in-the-making. There are even more curved and 'dished/cupped' surfaces evident here. A prospective thought-provoker for your 'Everythingcurved Stair'?
                                  Regards,
                                  Taff
                                  "Information is not knowledge." -- Albert Einstein
                                    simon le bon
                                    Dear TaffGoch,
                                    Please to meet you. So kind to you for thinking about this topic and bring back from your surf this woodmaker volute. Appreciate a lot.
                                    Well, in another way, i cannot go back right now: i must do the job. This everythingcurved Stair is in my head. I just need further little time to work on tuts i found here and there on SFC before begin.
                                    slb
                                    • 2 / 2
