    Need Help on SPIRALOID SHAPE
    25 Posts 9 Posters 5.8k Views 9 Watching
    • G
      GreyHead
      Well perhaps I'm nearer than I thought I was . . .
      To give you the short version I cleaned up your main version, put a cylinder in place for the center, then drew a volute spiral using a RubyScript (K2 graphs - sorry about the maths).
      Added a few lines to make a closed face, scaled it to size, pulled it up with the Push/Pull tool, then intersected it with an inclined plane to line up with the top surface of the main balustrade.
      Easier to see than describe, there's a 'pictures only' tutorial attached -- too late to add words tonight.
      Bob
      horseshoe_2.skp
        smartsizer
        Starting from one section of your attached file, I adjusted the "pushpull" height of the various spiral segments. In my opinion, the volute looks better if it is a little higher than the point where the large curving sweep meets the spiral. I started working my way around the spiral, simplifying the curve from the outside in. I leave it to you to take it from there if you like the effect.
        You might redraw your spiral so that it looks about the same from above, but the endpoints of the spiral segments fall on the same radii, so the segments get shorter the closer they get to the center. This will make it easier to fine tune the shape. If this doesn't make sense, let me know and I will draw a sample file.
        Good luck!
        HorseshoeStair2.skp
        • G
          GreyHead
          I like that baluster sweep, much nicer to my eye than the intersected plane. Will have a look at the spiral script later and see if I can do anything useful. There has to be a first ruby script I guess.
          Bob
          • simon le bonS
            simon le bon
            -dear GreyHead i would like to apply your method but -(one: i am unable to find anywhere K2 graphs RubyScript (but this search had showed me how many exciting extensions we can use))
            and -(two: i'm not sure of what to do with the last step of your horseshoe_2.skp). I'm afraid i need a scene number six
            And else i agree with you: smartsizer's baluster look nice.
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/GreyHead_volute.jpg
            -dear smartsizer, your solutions gives me a new way to work :
            -/creating multilevel facing -/intersected with a plane -/draw top lines of the wall
            -/stitch so far we can in the volute.
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/smartsizer_step1-1.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/smartsizer_step2-1.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/smartsizer_step3-1.jpg
            And you're right, the shape i pretty better like that.
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/smartsizer_idea.jpg
            I'm glad to see i was far but not so far from this.
            Are we in the real world? thanks a lot to give your freetime so friendly.
            • G
              GreyHead
              Hi simon,
              I'll try to add the extra step later this evening.
              K2 Graphs seems to be here but I think I got it as part of whole bundle of scripts that I downloaded from here but now can't find.
              Bob
                K_tools.rb is what you need...
                http://www.crai.archi.fr/rubylibrarydepot/ruby/fr_k_tools_50.rb
                • simon le bonS
                  simon le bon
                    • -/ I feel Stupid - - -
                      In the hurry i had taken first step smartsizer' shape to follow his purpose. Eureka the result was great. But there is a secret. We can't obtain this shape with a simple intersection with a plane. The top of the wall is shaped with two helicoidal lines. And how smartizer have did that: it's a mystery. Probably to discover in Ruby arcanes... Also my enthusiasm, under your eyes in the board has been driven to a flop . And my poor Horseshoe stair is still on the paper.
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/NotsosimpleBalustre.jpg
                  dear GreyHead and tig thanks for K_tools.rb (ha! K-Two). Now i need little work to understand how use it.
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/coquille.jpg
                  • boofredlayB
                    boofredlay
                    Sorry I have not read all of the posts in this but would the Spiralizer help you???
                    404 Not Found
                    (www.sketchucation.com)
                    I am not sure you can get a flat top on it or not with the spiralizer but it is worth a try.
                    • G
                      GreyHead
                      😄 Keep going, I learn a lot by trying things out here and experimenting.
                      As far as I can see Smartsizer did it by creating that grid of lines on each side and drawing in diagonals by hand.
                      Bob
                      PS I'll take a look at Spiraliser
                      PPS I'm experimenting with a script to do some of this but it's slow work - a first script squeezed in odd moments. So far so good.
                      • simon le bonS
                        simon le bon
                        It appears that you are probably right dear GreyHead. Smartsizer seems have drawn his diagonals by hand.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/diagsdrawbyhand-1.jpg
                        I haven't found the way to draw your volute with k-tools.
                          smartsizer
                          Yes, the diagonals are drawn by hand. Details are shown in the Scenes in the attached skp. Scenes 24 and 25 illustrate a method I discovered to manipulate points in a mesh.
                          HorseshoeStair tutorial.skp
                          • G
                            GreyHead
                            My spiral was something like:
                            K2 Graphs | 2D-Graph polar r=f(p)
                            p-range from: 0.0 (default)
                            p-Range to: 25.132741 (i.e. 8*pi)
                            Stepwidth: 0.06283185 (default - 100 steps per turn)
                            r = p**2 (default)
                            Then scale down to a useful size.
                            Bob
                            • G
                              GreyHead
                              Bien fait ! Bravo !
                              Bob
                              PS You can get rid of those 'blue' segments at the bottom by selecting a 'white' area, right click and choose 'orient faces'.
                              • simon le bonS
                                simon le bon
                                THAT'S IT!
                                Here is my HORSESHOE STAIR with volute ramps.
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final3.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final4.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final5.jpg
                                The volute and the leading help of GreyHead, a working direction to follow by smartsizer, many mistakes repaired by fox hack, pair of things i haven't understood at all, and at last, still lot of hard handmade work!!
                                (as you can see here)
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/intermediatVolute-2.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/intermediatVolute_b.jpg
                                (if someone is interested by this laborious travel: DivShare File - HorseshoeStairFinal.skp
                                All my thanks (in order of apparition) to: Greyhead Gaieus smartsizer Tig Boofredlay. You where incredibly kind and perseverant by my side.
                                At the end, smartsizer have given us a so beautiful lesson of drawing: so many strong solutions HorseshoeStair tutorial.skp. It surely have to be sent as a single post on the How To section: for great advantage of everybody interested in Sketchup (and 3D) modeling.
                                . Well, for horseshoe stair, it's over. But i have another project i shall call "The Everythingcurved Stair". Just the good matter to take off with it.
                                                 simonlebon
                                • Wo3DanW
                                  Wo3Dan
                                  Simon,
                                  I see that you finished your horse shoe shaped stairs, resulting in a very nice model.
                                  Thanks for sharing. Looking forward to what curved complex shape you have in mind now.
                                  cheers,
                                  Wo3Dan
                                  • V
                                    Voder Vocoder
                                    Here's another variation:
                                    http://www.datafilehost.com/download-455bae85.html
                                    ~Voder
                                    • simon le bonS
                                      simon le bon
                                      Dear Voder Vocoder
                                      WAHOUUU! what a pure splendid way to reach the end..
                                      Lot of hand made too, as sculptor work, but with each step simple, beautiful..
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/VoderVocoderSpiraloid2-1.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/VoderVocoderSpiraloid-1.jpg
                                      How many ways left to do the job? This topic is becoming a Top Master Class lesson of drawing.... Happy!
                                      PS: I allow me to put your VoderVocoder_HorseshoeStair SKP file on DivShare
                                      To allow permanent access. Because with Data File Host:
                                      "Your file is hosted forever as long as it gets downloaded at least one time every 30 days"
                                        smartsizer
                                        Voder---very nice!!
                                        • TaffGochT
                                          TaffGoch
                                          Simon,
                                          When I stumbled across this image while web-surfing, I immediately recalled your discussion thread:
                                          This is a violin in-the-making. There are even more curved and 'dished/cupped' surfaces evident here. A prospective thought-provoker for your 'Everythingcurved Stair'?
                                          Regards,
                                          Taff
                                          "Information is not knowledge." -- Albert Einstein
                                          • simon le bonS
                                            simon le bon
                                            Dear TaffGoch,
                                            Please to meet you. So kind to you for thinking about this topic and bring back from your surf this woodmaker volute. Appreciate a lot.
                                            Well, in another way, i cannot go back right now: i must do the job. This everythingcurved Stair is in my head. I just need further little time to work on tuts i found here and there on SFC before begin.
                                            slb
