    1 new feature
    36 Posts 17 Posters 9.0k Views 17 Watching
    • Paul RussamP
      Paul Russam
      When Solo first wrote:
      @solo said:
      nurbs!!
      I read it as if someone was yelling it as a warning against invading aliens in a 50's sifi movie
      I know, I'm odd 😉
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
      • StinkieS
        Stinkie
        Hmm, imagine ... I bought MoI recently, and I've been fantasizing about a cross between SU and MoI a lot.
        Kwisten's dont-you-dare-crash-on-me-button sounds like a plan too.
          remus
          quiet kwis, the phrase 'high poly' and any of its derivatives are forbidden from this thread!!
          • K
            kwistenbiebel
            I've got another one.
            A 'displacement-map-to-geometry tool'.
            This could be a great feature when modeling buildings using photomatch .
            Sketchup could generate a displacement map from a facade picture and transform it into 3D.
            In this way,we could have windows, doors and facade material bump automatically 'hard modeled' into geometry.
            A tremendous photorealism boost (definitely for rendering 😄)....but only possible if Sketchup can handle higher poly models off course.
            • K
              kwistenbiebel
              OK 😉....sorry about that . 😆
                remus
                How would that work with locking axes for movement? I like the directional focing quite a lot...
                  remus
                  you know if you use the move tool you can force the direction of movement using the arrow keys, i was basically asking how you would like to work your nudge tool around forcing the direction of movement. Hope thats a bit clearer.
                  • L
                    lewiswadsworth
                    While we're dreaming, I'd like to have a built-in "Make Espresso" tool, perhaps with Cappuccino (CTRL) and Mocha (SHIFT) options.
                    col sporcar si trova
                      JuanV.Soler
                      I insist in :
                      %(#4000BF)[A tool that will , in a small rectangulo provided by the same tool, eliminate all the points inside and create a one single brilliant point.
                      That would give an enormous ability to close faces.
                      Most useful when elevating a complex sum of planes.
                      When you are drawing a building you get many times the non coplanar faces. It is absolutely impossible to get the right point to close a face properly.
                      I want that tool.
                        richcat
                        Hi Modelhead I think your dreaming about Space design from RPS its FREE 😍
                        http://wiki.renderplus.com/index.php?title=Space_Design#Space_Design_Toolbar
                        Move a component (or any selected entities) along an axis basically a nudge tool, set increment movement, choose axis, ETC,ETC but sorry no drink option 😢 . Had to give up caffeine so my heart could slow down. 🎉
                        I think there was also another ruby nudge tool as well recently 😒
                        • Wo3DanW
                          Wo3Dan
                          Just one button to toggle on/off 3D orbiting.
                          Once you apply 'Align View' on axes, a face or a section plane you could simply proceed drawing semi 2D in the aligned view without worrying about orbiting. Only panning and orbiting 2D.
                          I know you could save some scenes but....
                          • soloS
                            Mind navigation.
                            Orbit, zoom, pan, etc just with your mind, sounds like science fiction now, but who know with version 12 it may just be science fact.
                            • W
                              watkins
                              Dear All,
                              This is more a modification to an existing tool.
                              It would be nice to have a multiple copy option for the move too. Click the Ctrl key once and you have the single copy option ('+' sign appears); click the Ctrl key twice and you have the multi-copy option ('++' sign appears). Scroll through the options by clicking the Ctrl key.
                              I know about the *n and /n options, but these only work between the start and finish point, or along a linear path. I often want to pick up a copy of a component and then drop it in lots of different places in X,Y and Z.
                              Regards,
                              Bob
                                remus
                                oooh, i think ive got a good one...a tool that allows you to project geometry onto a surface. I was thinking so youd be able to do things like this trellis http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=7304 without havign to do lots of boring stuff.
                                  Isn't that 'Drape' ? You might have to change axes or roate some stuff but...
                                    remus
                                    😒 woops, forgot aobut that little tool..., cheers for reminding me tig 🎉
                                    • W
                                      watkins
                                      Dear Remus,
                                      Didier Bur has a collection of tools called projection tools which allow one to project geometry on to a plane. In fact, I asked him to update the tool set, which he did, and which can found in the Ruby Depository (second page, Projection Toolbar Update)
                                      Hope this helps.
                                      Regards,
                                      Bob
                                      PS I liked your Glastonbury Tor.
                                        remus
                                        cheers for pointing that out wat, seems like i missed quite a lot in that area 😛 i tried the projection toolbar a long time ago, can it project onto a curved plane?
                                        • kenK
                                          ken
                                          Well, my wish is to have some way to group layers into upper and sub levels. Such that in the layer manger display window, I could have an upper level layer named "xxxx" and inside that layers' level are all the sub level layers that I want to be associated with the upper named layer. In addition, also, to have the option of just showing the upper level layers, or all the sub level layers of each upper level layer.
                                          Hope this makes since.
                                          Ken
                                          • GaieusG
                                            Yes it does, Ken; some kind of multi-level, collapsible layer system. Just like in Win Eexplorers menu list on the left.
                                            Well, as I remember, Todd is thinking about such a plugin. 👍
                                            • 2 / 2
