    1 new feature
    36 Posts 17 Posters 8.5k Views 17 Watching
    • G
      Gjenio
      @paul russam said:
      @solo said:
      nurbs!!
      Run for the hills the nurbs are coming!!!
      What do you mean? Are you in the developing team? Is it a scoop or a joke?
      • soloS
        And this, my little ponies is how rumours begin. 😆
        • Paul RussamP
          Paul Russam
          When Solo first wrote:
          @solo said:
          nurbs!!
          I read it as if someone was yelling it as a warning against invading aliens in a 50's sifi movie
          I know, I'm odd 😉
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
          • StinkieS
            Stinkie
            Hmm, imagine ... I bought MoI recently, and I've been fantasizing about a cross between SU and MoI a lot.
            Kwisten's dont-you-dare-crash-on-me-button sounds like a plan too.
              remus
              quiet kwis, the phrase 'high poly' and any of its derivatives are forbidden from this thread!!
              • K
                kwistenbiebel
                I've got another one.
                A 'displacement-map-to-geometry tool'.
                This could be a great feature when modeling buildings using photomatch .
                Sketchup could generate a displacement map from a facade picture and transform it into 3D.
                In this way,we could have windows, doors and facade material bump automatically 'hard modeled' into geometry.
                A tremendous photorealism boost (definitely for rendering 😄)....but only possible if Sketchup can handle higher poly models off course.
                • K
                  kwistenbiebel
                  OK 😉....sorry about that . 😆
                    remus
                    How would that work with locking axes for movement? I like the directional focing quite a lot...
                      remus
                      you know if you use the move tool you can force the direction of movement using the arrow keys, i was basically asking how you would like to work your nudge tool around forcing the direction of movement. Hope thats a bit clearer.
                      • L
                        lewiswadsworth
                        While we're dreaming, I'd like to have a built-in "Make Espresso" tool, perhaps with Cappuccino (CTRL) and Mocha (SHIFT) options.
                        col sporcar si trova
                          JuanV.Soler
                          I insist in :
                          %(#4000BF)[A tool that will , in a small rectangulo provided by the same tool, eliminate all the points inside and create a one single brilliant point.
                          That would give an enormous ability to close faces.
                          Most useful when elevating a complex sum of planes.
                          When you are drawing a building you get many times the non coplanar faces. It is absolutely impossible to get the right point to close a face properly.
                          I want that tool.
                            richcat
                            Hi Modelhead I think your dreaming about Space design from RPS its FREE 😍
                            http://wiki.renderplus.com/index.php?title=Space_Design#Space_Design_Toolbar
                            Move a component (or any selected entities) along an axis basically a nudge tool, set increment movement, choose axis, ETC,ETC but sorry no drink option 😢 . Had to give up caffeine so my heart could slow down. 🎉
                            I think there was also another ruby nudge tool as well recently 😒
                            • Wo3DanW
                              Wo3Dan
                              Just one button to toggle on/off 3D orbiting.
                              Once you apply 'Align View' on axes, a face or a section plane you could simply proceed drawing semi 2D in the aligned view without worrying about orbiting. Only panning and orbiting 2D.
                              I know you could save some scenes but....
                              • soloS
                                Mind navigation.
                                Orbit, zoom, pan, etc just with your mind, sounds like science fiction now, but who know with version 12 it may just be science fact.
                                • W
                                  watkins
                                  Dear All,
                                  This is more a modification to an existing tool.
                                  It would be nice to have a multiple copy option for the move too. Click the Ctrl key once and you have the single copy option ('+' sign appears); click the Ctrl key twice and you have the multi-copy option ('++' sign appears). Scroll through the options by clicking the Ctrl key.
                                  I know about the *n and /n options, but these only work between the start and finish point, or along a linear path. I often want to pick up a copy of a component and then drop it in lots of different places in X,Y and Z.
                                  Regards,
                                  Bob
                                    remus
                                    oooh, i think ive got a good one...a tool that allows you to project geometry onto a surface. I was thinking so youd be able to do things like this trellis http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=7304 without havign to do lots of boring stuff.
                                      Isn't that 'Drape' ? You might have to change axes or roate some stuff but...
                                        remus
                                        😒 woops, forgot aobut that little tool..., cheers for reminding me tig 🎉
                                        • W
                                          watkins
                                          Dear Remus,
                                          Didier Bur has a collection of tools called projection tools which allow one to project geometry on to a plane. In fact, I asked him to update the tool set, which he did, and which can found in the Ruby Depository (second page, Projection Toolbar Update)
                                          Hope this helps.
                                          Regards,
                                          Bob
                                          PS I liked your Glastonbury Tor.
                                            remus
                                            cheers for pointing that out wat, seems like i missed quite a lot in that area 😛 i tried the projection toolbar a long time ago, can it project onto a curved plane?
                                            • 2 / 2
