    Two Radius intersecting at 90 degrees
    32 Posts 9 Posters 4.8k Views 9 Watching
    • EdsonE Offline
      Edson
      hi, pagan
      which screen capture app did you use for those movies?
      http://www.mahfuz.arq.br
        dylan
        @natemclain said:
        Now that I can follow! πŸ˜„
        Thanks for the help!
        I still never got the first solution to work.
        I think looking at the explanations, the reason you probably did not get the first method to work was the Intersection.
        When you grouped the half of the model and then open the group to push/pull through the other piece. You then select that group, right click and explode.
        Next step you select the whole model, right click, Intersect/Intersect with Model.
        You can then delete the excess which will give you the desired result.
        That said, the follow me procedure you have already completed is far easier πŸ˜„
        http://dmdarchitecture.co.uk/
          Pagan
          @edson said:
          hi, pagan
          Hi,a used a Quick Screen Recorder!
          Sometimes used and Camtasia Studio,depend on need,for something quick Quick Screen Recorder.
          For beter recording a Camtasia Studio. πŸ˜‰
            dylan
            Are these available free Pagan?
              Pagan
              Are these available free Pagan?[/quote]
              No,but for free you could use a this,didn't try it yet.
              (wisdom-soft.com)
                Pagan
                Just find it http://www.nbxsoft.com/screen-recorder.php completly free,it's look like just like Quick Screen Recorder.
                  Dylan, see the thread about Camtasia (free now) here.
                  πŸ˜’
                    dylan
                    How did I miss that thread!
                    Ok, well if you follow the link Gaieus posted, it says the offer has expired on the webpage.
                    Ignore it!
                    Just click on the link to download the program then the link to get your serial. On this page it tells you the offer ends 7th January.
                    2 days to grab it!
                      Gidon Yuval
                      Am I too late to offer this little tut?
                      Testing2.skp
                      If you don't know where you're going, you're never going to get there.
                        Yes, Gidon, too late. (Of course when someone is cooking goulash on Sabbath! πŸ˜„ )
                        See this post with this attachment.
                        πŸ˜„
                          Julius
                          check out Debut, it's better tahn autoscreenrecorder purchasable version and it's free. (when installing it will ask you if you want to install any other program, they're all trial versions but "Prism" wich is free and is a good video format converter).
                            gata
                            On the original model, that 'stubborn' face would have pushed through if you used Push/Pull+Ctrl (PC).
                            • N Offline
                              natemclain
                              I was just able to get back on the PC and play with this some more.
                              I have a new problem...
                              Just so you know this is a leg for furniture.
                              I can make the leg by hand, but want to share it with others online.
                              I have the profile that I want to push to the back side on both faces of the model.
                              Can someone explain the process to accomplish this?
                              Should I push/pull the curved profile back before I create the cove on the 2 faces that everyone has shown?
                              All the suggestions have been very helpful! And I have learned allot with this excercise.
                              BTW I have attached an actual picture of the leg that I'm trying to model.
                              TIA
                              Nate
                              TestingAgain.skp
                                Hi Nate,
                                Have a look at Gidon's "Cabriole leg" tutorial in this thread to get some ideas.
                                This leg of yours have some similarities and you can easily adapt the workflow.
                                  PKast
                                  Here's your answer. Follow along by clicking on the tabbed scenes.
                                  There are some tutorials on just this type of leg. Try a search on cabriole leg.
                                  Best
                                  PKastmiler
                                  TestingAgain[1] Answer.skp
                                    Holy crap, I didn't even notice the skp attachment below the image!
                                    Great solution, PKast!
                                    • N Offline
                                      natemclain
                                      You guys are absolutely amazing!
                                      Works great.
                                      Thanks for the tips.
                                      This software is incredible!
                                      Thanks again!
                                      Nate
                                        Pagan
                                        http://i3.tinypic.com/6tzdekj.jpg
                                        If the rear side have same shape as front side of leg you could do it like this.
                                        Video preview:http://dhost.info/pagan/leg.avi
                                        And here is a model:http://dhost.info/pagan/leg.skp
                                        • 2 / 2
