    Two Radius intersecting at 90 degrees
    32 Posts 9 Posters 4.8k Views 9 Watching
      No, here is what I'm referring.
      True that if you select this front face too, it does no harm jst make sure you also select the ending half circle of your cylinder, too (I cannot see from this picture whether you have selected it or not).
      Also Edson is right; you could have done the whole thing with one snap; the follow me tool.
        See ideas about the follow me tool [url=http://www.sketchucation.com/forums/scf/sas
        /Newbie/Testing3.skp]here[/url].
        (OK Edson, I was concentrating on the current problem... πŸ˜’ )
        • EdsonE Offline
          Edson
          thanks, csaba, for making the skippy i should have made (and did not from lazyness (50%) + involvement in a design competition for a large building in brasilia (50% more).
          i had a hunch it would be easier with follow me.
          cheers.
          http://www.mahfuz.arq.br
            Pagan
            I'm not shure did I understand what do you want,maybe something like this?
            Video previw 1: http://dhost.info/pagan/01.avi
            Video previw 2: http://dhost.info/pagan/02.avi
            • N Offline
              natemclain
              Now that I can follow! πŸ˜„
              Thanks for the help!
              I still never got the first solution to work.
                Well, good then.
                Although you could get it to work somehow because it is generally useful (often the Push/Pull tool just does not want to go through some geometry).
                • N Offline
                  natemclain
                  Without this forum I would have been STUCK!
                  That worked great and I'm very pleased with Sketchup. It is a remarkable piece of software. You can draw things much faster than I can in CAD. And its a 3D model. Unreal!
                  Thanks again!
                  N
                  • EdsonE Offline
                    Edson
                    hi, pagan
                    which screen capture app did you use for those movies?
                      dylan
                      I think looking at the explanations, the reason you probably did not get the first method to work was the Intersection.
                      When you grouped the half of the model and then open the group to push/pull through the other piece. You then select that group, right click and explode.
                      Next step you select the whole model, right click, Intersect/Intersect with Model.
                      You can then delete the excess which will give you the desired result.
                      That said, the follow me procedure you have already completed is far easier πŸ˜„
                      http://dmdarchitecture.co.uk/
                        Pagan
                        @edson said:
                        hi, pagan
                        Hi,a used a Quick Screen Recorder!
                        Sometimes used and Camtasia Studio,depend on need,for something quick Quick Screen Recorder.
                        For beter recording a Camtasia Studio. πŸ˜‰
                          dylan
                          Are these available free Pagan?
                            Pagan
                            Are these available free Pagan?[/quote]
                            No,but for free you could use a this,didn't try it yet.
                            (wisdom-soft.com)
                              Pagan
                              Just find it http://www.nbxsoft.com/screen-recorder.php completly free,it's look like just like Quick Screen Recorder.
                                Dylan, see the thread about Camtasia (free now) here.
                                πŸ˜’
                                  dylan
                                  How did I miss that thread!
                                  Ok, well if you follow the link Gaieus posted, it says the offer has expired on the webpage.
                                  Ignore it!
                                  Just click on the link to download the program then the link to get your serial. On this page it tells you the offer ends 7th January.
                                  2 days to grab it!
                                    Gidon Yuval
                                    Am I too late to offer this little tut?
                                    Testing2.skp
                                    If you don't know where you're going, you're never going to get there.
                                      Yes, Gidon, too late. (Of course when someone is cooking goulash on Sabbath! πŸ˜„ )
                                      See this post with this attachment.
                                      πŸ˜„
                                        Julius
                                        check out Debut, it's better tahn autoscreenrecorder purchasable version and it's free. (when installing it will ask you if you want to install any other program, they're all trial versions but "Prism" wich is free and is a good video format converter).
                                          gata
                                          On the original model, that 'stubborn' face would have pushed through if you used Push/Pull+Ctrl (PC).
                                          • N Offline
                                            natemclain
                                            I was just able to get back on the PC and play with this some more.
                                            I have a new problem...
                                            Just so you know this is a leg for furniture.
                                            I can make the leg by hand, but want to share it with others online.
                                            I have the profile that I want to push to the back side on both faces of the model.
                                            Can someone explain the process to accomplish this?
                                            Should I push/pull the curved profile back before I create the cove on the 2 faces that everyone has shown?
                                            All the suggestions have been very helpful! And I have learned allot with this excercise.
                                            BTW I have attached an actual picture of the leg that I'm trying to model.
                                            TIA
                                            Nate
                                            TestingAgain.skp
