    More flexibility with edges
    16 Posts 9 Posters 4.0k Views 9 Watching
    • GaieusG
      Edson,
      if you hide SOME edges in a group or component, they won't be unhidden even if you go to Edit > Unhide > All.
      This way you can "turn off" edges selectively.
      As for colouring them individually, to me it is quite satisfactory. Explain, please, why it is not good enough for you!
      • EdsonE
        Edson
        @gaieus said:
        Edson,
        as far as i know, one cannot select a few edges and give them a different color from the rest. or can one? unless i am mistaken you can only change the color of ALL the edges. that is what i mean by not being good enough.
        what if i wanted to draw a few red lines for the sake of highlighting some part of a scheme?
        http://www.mahfuz.arq.br
        • GaieusG
          Indeed you can do that. The best way really is to pre-select those lines because though you can use the paint bucket tool to paint a line straight but sometimes it's hard to "aim" properly.
          Do it in wireframe to avoid painting faces, too.
          • Wo3DanW
            Wo3Dan
            @gaieus said:
            Edson,
            Edson,
            Like Gaieus mentioned, you can indeed color edges differently anyway you like.
            See (as an example I did a while ago):
            http://sketchup.google.com/3dwarehouse/details?mid=a9096f57b8c534b9c1c418114d9a901b
            poster-Wo3Dan
              SchreiberBike
              I didn't realize that this was possible either. Playing with it, I'm having a hard time getting it right, but with more practice I imagine I'll be able to do it reliably.
              • Wo3DanW
                Wo3Dan
                SchreiberBike,
                This might help you when painting edges:
                • select ‘Wire Frame’ mode
                • make a copy of the object (this way you only get the edges copied)
                • now select View>Edge Style>Profile (thick lines)
                • paint whatever needs to be painted
                • move back the wire frame to same location as the original object
                  this object will now inherit the painted edges
                Note that even when painting the edges you can have ‘Shaded With Textures’ selected again so you will see the object next to the wire frame with its thick lines.
                poster-Wo3Dan
                • JClementsJ
                  JClements
                  Open the Entity Info dialog. Select an edge and look at the color swatch in Entity Info; don't like the color then double click on the swatch and pick from other colors or materials currently used in the model.
                  • W
                    watkins
                    Dear Edson,
                    If you are having problems then go to Styles, select Edit, then Edge Settings (first Icon), and then make sure that Colour is set to 'By Material'.
                    JClements' method is very convenient, but if you require specific colours then you will have to 'load' those colours into the model by painting a dummy object (like a cube), which one deletes to leave the materials (colours) behind. Those colours will then be available in the 'Edit Info' dialogue box when you double click on the displayed colour in that dialogue box.
                    Kind regards,
                    Bob
                    • JClementsJ
                      JClements
                      Bob, you will get no argument from me about your comments.
                      Just wanted others to note that there was another method for coloring edges.
                      Regards, J
                      • W
                        watkins
                        Dear J,
                        There are a lot of techniques that need promoting and the use of Entity Info is one of them. You have my support.
                        Kind regards,
                        Bob
                          Julius
                          oh, tank you, this information about coloured lines is very useful. btw, to paint a line is not necessary to open "entity info" like bob said, you can also use the pait tool (face style ->wireframe)
                          • GaieusG
                            You can use the paint tool while in "normal" modes, too - it's just too easy to mistake the lines and paint the faces.
                            You can always preselect a bunch of lines though and "batch paint" them.
                              Julius
                              yes, this is what i meant.
                              • L
                                lapx
                                Has anyone tried exporting to see how it looks i.e. parking lot lines? 😒
                                • plot-parisP
                                  plot-paris
                                  great! I didn't know colouring lines is possible. now I am one step closer to evading cad programs... 😄
                                  should be quite easy to handle the different line colours when your model is well organized (groups/components).
                                  perhaps applying different line thicknes to various lines would be a nice idea for a ruby (unless something like that already exists!? 😆 )
