    Yafray Render
    33 Posts 7 Posters 5.5k Views 7 Watching
    • david57D Offline
      david57
      Ok SpaceCow, try to import the lwo as in the image below.
      • david57D Offline
        david57
        My sun energy is set to 1.0 the default. Yafray settings for the most
        recent renders are below.
        • david57D Offline
          david57
          And don't forget the sky color. No HDR's. This settings should work for any
          exteriors.
            SpaceCow
            Thanks dave!!!!
            • david57D Offline
              david57
              • david57D Offline
                david57
                Trying out some lanterns from Google 3D Warehouse. Modified a bit.
                Needs white frosted glass.
                  Could you use some bumpmaps on those walls? They are great but that would spice up the whole picture big time!
                  • soloS Offline
                    Coming along great, some ground textures would make it 'POP' nicely.
                    • david57D Offline
                      david57
                      More bump to walls and floor. Slows processor legs to a crawl. Might need a larger
                      cement slab and door.
                      • soloS Offline
                        May slow it down to the speed of snot...but it looks great!
                        • david57D Offline
                          david57
                            Yes, definitely better. That close-up wall is just nice!
                            • david57D Offline
                              david57
                              Here's another render. Im trying to calibrate the correct colors on
                              the large cube, but unsuccessfull. The cube has a material color set
                              to (0.8 0.8 0.8). Im trying to use this person's renders as a gauge.
                              Just a moment...
                              (www.evermotion.org)
                              • david57D Offline
                                david57
                                Added another cube to scene. Sun and sky setting are about right.
                                • soloS Offline
                                  It's really coming together very well, it's amazing after a project like this how much one learns.
                                  With the increased realism and path towards scenes like the one you linked above a few previously accepted components like the angular rocks start to stand out, is there any way you can soften or replace them with more freeform ones?
                                  great work.
                                  • david57D Offline
                                    david57
                                    Thanks Solo,
                                    Ive been think of working on the rocks, but textured UV'S from SU are
                                    not exported correctly into blender or imported correctly into blender
                                    with the python script that blender uses. It makes a big mess with
                                    any textures including the tree textures. Don't know what my next step will
                                    be.
                                    • david57D Offline
                                      david57
                                      @david57 said:
                                      Some people say they are addicted to rendering, but i have hangovers and
                                      regrets with the renders i did yesterday.
                                      • N Offline
                                        Noohaldinho
                                        Hi There,
                                        The pictures looks nice and the way they were enhanced are nice too ,,
                                        I have question though regarding exporting from Skethup to Blender ... HOW TO? and what is required to do so?
                                        I'm using Apple platform MAC OSX on a PowerPC G5 ... so what I need to know
                                        Please I need a quick reply .. because I have to submit my term project to my instructor soon ... and I'm thinking of submitting a rendered images too along with the main design (2D plans, Sections) then I'm going also to post it here too in this forum in the gallery section.
                                        Please I'll appreciate any reply on my email also just to save time since I check it always
                                        abushoaq@gmail.com
                                          lewiswadsworth
                                          David,
                                          As opposed to using Yafray, have you done anything with Blender's own node-based rendering system? That's on my list to try, when I can afford to experiment with something out-of-the-ordinary, just because it is such an unusual way to set up post-processing before actually rendering...I recently read the Blender manual chapter on it. I like the possibility of setting it up so that some--but not all--items in the final result might be rendered non-photorealistically with edges and so forth.
                                          col sporcar si trova
                                          • david57D Offline
                                            david57
                                            Lewis,
                                            I've done very little work with the Blender Nodes, Not enough to be of help to you.
                                            I read from blender.org, that this person does his work with blender.
                                            (www.gucias.republika.pl)
                                            • 2 / 2
