    Yafray Render
    33 Posts 7 Posters 7.0k Views 7 Watching
    • david57D
      david57
      Here's a 13 minute render. Planning to place a garage to the far right.
      • david57D
        david57
        But, before i built the garage, i need VEHICALS.
        • david57D
          david57
          Something strange happened to this render. It's not posible.
          • GaieusG
            It must be waaay down in the south as it seems to be summer there...
            πŸ˜’
              SpaceCow
              Hey guys,
              I'm new to the SketchUp forum and wanted to export a sketchup file to blender because I love to use blender as well. I downloaded the .lwo exporter and blender won't open it. Is it supposed to? I thought blender was only supposed to open .blend files and such.
              if there is an exporter from sketchup to blender and someone could help me it would be much appreciated.
              • david57D
                david57
                Ok SpaceCow, try to import the lwo as in the image below.
                • david57D
                  david57
                  My sun energy is set to 1.0 the default. Yafray settings for the most
                  recent renders are below.
                  • david57D
                    david57
                    And don't forget the sky color. No HDR's. This settings should work for any
                    exteriors.
                      SpaceCow
                      Thanks dave!!!!
                      • david57D
                        david57
                        • david57D
                          david57
                          Trying out some lanterns from Google 3D Warehouse. Modified a bit.
                          Needs white frosted glass.
                          • GaieusG
                            Could you use some bumpmaps on those walls? They are great but that would spice up the whole picture big time!
                            • soloS
                              Coming along great, some ground textures would make it 'POP' nicely.
                              • david57D
                                david57
                                More bump to walls and floor. Slows processor legs to a crawl. Might need a larger
                                cement slab and door.
                                • soloS
                                  May slow it down to the speed of snot...but it looks great!
                                  • david57D
                                    david57
                                    • GaieusG
                                      Yes, definitely better. That close-up wall is just nice!
                                      • david57D
                                        david57
                                        Here's another render. Im trying to calibrate the correct colors on
                                        the large cube, but unsuccessfull. The cube has a material color set
                                        to (0.8 0.8 0.8). Im trying to use this person's renders as a gauge.
                                        http://www.evermotion.org/vbulletin/showthread.php?t=63326
                                        • david57D
                                          david57
                                          Added another cube to scene. Sun and sky setting are about right.
                                          • soloS
                                            It's really coming together very well, it's amazing after a project like this how much one learns.
                                            With the increased realism and path towards scenes like the one you linked above a few previously accepted components like the angular rocks start to stand out, is there any way you can soften or replace them with more freeform ones?
                                            great work.
