    Yafray Render
    33 Posts 7 Posters 7.0k Views 7 Watching
    • david57D
      david57
      But, before i built the garage, i need VEHICALS.
      • david57D
        david57
        Something strange happened to this render. It's not posible.
        • GaieusG
          It must be waaay down in the south as it seems to be summer there...
          πŸ˜’
            SpaceCow
            Hey guys,
            I'm new to the SketchUp forum and wanted to export a sketchup file to blender because I love to use blender as well. I downloaded the .lwo exporter and blender won't open it. Is it supposed to? I thought blender was only supposed to open .blend files and such.
            if there is an exporter from sketchup to blender and someone could help me it would be much appreciated.
            • david57D
              david57
              Ok SpaceCow, try to import the lwo as in the image below.
              • david57D
                david57
                My sun energy is set to 1.0 the default. Yafray settings for the most
                recent renders are below.
                • david57D
                  david57
                  And don't forget the sky color. No HDR's. This settings should work for any
                  exteriors.
                    SpaceCow
                    Thanks dave!!!!
                    • david57D
                      david57
                      • david57D
                        david57
                        Trying out some lanterns from Google 3D Warehouse. Modified a bit.
                        Needs white frosted glass.
                        • GaieusG
                          Could you use some bumpmaps on those walls? They are great but that would spice up the whole picture big time!
                          • soloS
                            Coming along great, some ground textures would make it 'POP' nicely.
                            • david57D
                              david57
                              More bump to walls and floor. Slows processor legs to a crawl. Might need a larger
                              cement slab and door.
                              • soloS
                                May slow it down to the speed of snot...but it looks great!
                                • david57D
                                  david57
                                  • GaieusG
                                    Yes, definitely better. That close-up wall is just nice!
                                    • david57D
                                      david57
                                      Here's another render. Im trying to calibrate the correct colors on
                                      the large cube, but unsuccessfull. The cube has a material color set
                                      to (0.8 0.8 0.8). Im trying to use this person's renders as a gauge.
                                      http://www.evermotion.org/vbulletin/showthread.php?t=63326
                                      • david57D
                                        david57
                                        Added another cube to scene. Sun and sky setting are about right.
                                        • soloS
                                          It's really coming together very well, it's amazing after a project like this how much one learns.
                                          With the increased realism and path towards scenes like the one you linked above a few previously accepted components like the angular rocks start to stand out, is there any way you can soften or replace them with more freeform ones?
                                          great work.
                                          • david57D
                                            david57
                                            Thanks Solo,
                                            Ive been think of working on the rocks, but textured UV'S from SU are
                                            not exported correctly into blender or imported correctly into blender
                                            with the python script that blender uses. It makes a big mess with
                                            any textures including the tree textures. Don't know what my next step will
                                            be.
