    Yafray Render
    33 Posts 7 Posters 7.0k Views 7 Watching
    • soloS
      Coming along great, some ground textures would make it 'POP' nicely.
      • david57D
        david57
        More bump to walls and floor. Slows processor legs to a crawl. Might need a larger
        cement slab and door.
        • soloS
          May slow it down to the speed of snot...but it looks great!
          • david57D
            david57
            • GaieusG
              Yes, definitely better. That close-up wall is just nice!
              • david57D
                david57
                Here's another render. Im trying to calibrate the correct colors on
                the large cube, but unsuccessfull. The cube has a material color set
                to (0.8 0.8 0.8). Im trying to use this person's renders as a gauge.
                http://www.evermotion.org/vbulletin/showthread.php?t=63326
                • david57D
                  david57
                  Added another cube to scene. Sun and sky setting are about right.
                  • soloS
                    It's really coming together very well, it's amazing after a project like this how much one learns.
                    With the increased realism and path towards scenes like the one you linked above a few previously accepted components like the angular rocks start to stand out, is there any way you can soften or replace them with more freeform ones?
                    great work.
                    • david57D
                      david57
                      Thanks Solo,
                      Ive been think of working on the rocks, but textured UV'S from SU are
                      not exported correctly into blender or imported correctly into blender
                      with the python script that blender uses. It makes a big mess with
                      any textures including the tree textures. Don't know what my next step will
                      be.
                      • david57D
                        david57
                        @david57 said:
                        Some people say they are addicted to rendering, but i have hangovers and
                        regrets with the renders i did yesterday.
                        • N
                          Noohaldinho
                          Hi There,
                          The pictures looks nice and the way they were enhanced are nice too ,,
                          I have question though regarding exporting from Skethup to Blender ... HOW TO? and what is required to do so?
                          I'm using Apple platform MAC OSX on a PowerPC G5 ... so what I need to know
                          Please I need a quick reply .. because I have to submit my term project to my instructor soon ... and I'm thinking of submitting a rendered images too along with the main design (2D plans, Sections) then I'm going also to post it here too in this forum in the gallery section.
                          Please I'll appreciate any reply on my email also just to save time since I check it always
                          abushoaq@gmail.com
                          • L
                            lewiswadsworth
                            David,
                            As opposed to using Yafray, have you done anything with Blender's own node-based rendering system? That's on my list to try, when I can afford to experiment with something out-of-the-ordinary, just because it is such an unusual way to set up post-processing before actually rendering...I recently read the Blender manual chapter on it. I like the possibility of setting it up so that some--but not all--items in the final result might be rendered non-photorealistically with edges and so forth.
                            col sporcar si trova
                            • david57D
                              david57
                              Lewis,
                              I've done very little work with the Blender Nodes, Not enough to be of help to you.
                              I read from blender.org, that this person does his work with blender.
                              (www.gucias.republika.pl)
                              • I
                                ilay7k
                                sorry, i know thats not blender's forum but Andrey Izrantsev/bdancer/ create vray's exporter for blender - http://blender.lugr.ru/
                                but if you want thats works you need vray-standalone edition(in maya and xsi), so link with chaosgroup support team....
                                • L
                                  lewiswadsworth
                                  @david57 said:
                                  Lewis,
                                  Thanks David. I'll take a look.
                                  • 2 / 2
