    Most used scripts.
    23 Posts 17 Posters 5.9k Views 17 Watching
    • boofredlayB Offline
      boofredlay
      Thanks guys, I forgot about makefaces. I use that one when I import from autocad... that shows you how long it has been, I forgot about that command altogther.
      Since the v6 install, the only script I re-installed was windowizer, until now that is.
      Keep em comin'. ๐Ÿ˜‰
      • Phil MeadowsP Offline
        Phil Meadows
        I haven't been able to work Windoizer into my workflow, as I do mostly retail centers with irregular storefront. I used it a lot more when I was building cities for my comic book work, but alas...I don't do that anymore.
        When I moved to version 6 I decided to only load tools as I needed them, thus keeping the bloat out of the plugins menu. I've got:
        Curve Stitcher
        Flatten to 2d
        Mirror selection
        Podium
        Randor
        Weld
        Xporter
        Xref tools
        and that's it. Well, Makefaces over in the Tools folder. I have tons of ruby scripts loaded in V.5 but these are the only ones I've needed since upgrading.
        • daikuD Offline
          daiku
          TIG's AddVertex+.rb
          Always seems to know right where I want a cpoint.
          Clark Bremer
          http://www.northernlightstimberframing.com
            Hi all,
            It mostly depends what exactly I'm doing but these are now my regular ones:
            Lately, for a bigger work to reconstruct some Gothic architecture:
            Curve Stitcher
            Weld
            Tube along Path
            For creating terrains by exact measurement:
            Cloud
            Convert to xLines (plus maybe Delete Construction Lines Only)
            Triangulate points
            What is new to me but enjoy playing with it:
            Soap Skin and Bubble
            • CadFatherC Offline
              CadFather
              extrude along path, drop, mirror, filter extensions, projections...
              • N Offline
                not registered yet
                a picture
                http://www.sketchucation.com/forums/scf/sas/Ruby/untitled.jpg
                [LMNO]
                • Alan FraserA Offline
                  Alan Fraser
                  I use many of the ones already mentioned...especially Make Faces. One I don't think anyone has mentioned so far is Menu...based on Didier's menu loader. There may be something better by now, but I find it invaluable for keeping everything neat and tidy.
                  http://www.sketchucation.com/forums/scf/sas/Ruby/menu.png
                  3D Figures
                    Stu
                    Make Faces, every time I start a new model with an ACad drawing.......SU2KT, most times I finish a SU model and something I find absolutly indispensible.....Nudge rb.....for moving any group or component in x,y or z direction, for a distance I specify, independent of any snapping or inference.
                    http://www.landesign.com.au
                    • F Offline
                      firkins
                      Alan,
                      Could you tell us more about the Menu script that you mentioned. I am a "power user" with many scripts in my plugins menu and would like to be able to organize them as you have.
                      I have looked on Didiers ruby library and sMustard, but have not been able to located it. Could you point me in the right direction?
                      Thanks,
                      Michael
                      %(#000080)["Those who would give up Essential Liberty
                      to purchase a little Temporary Safety,
                      deserve neither Liberty not Safety."]
                      Ben Franklin
                      • Didier BurD Offline
                        Didier Bur
                        Go to "Geometry-Drawing" section. Scripts are sorted alphabetically (by name) ๐Ÿ˜„
                        DB
                          boofredlay
                          I cannot seem to find the Geometry-Drawing section. Maybe I am looking on the wrong site. ๐Ÿ˜ณ
                          EDIT: Sorry, found it but I do not see Menu Loader there. What is the proper name of this srcipt?
                          Also, what is the difference between "extrude along path" and "Follow Me"?
                            Didier Bur
                            Sorry, I thought you were searching for makefaces.rb ๐Ÿ˜ณ
                            Menu loader is not available t my site, I forget to put it in a page.
                            I'll retrieve it asap but maybe you could ask Alan for it... ๐Ÿ˜ฎ
                            And extrudealongpath is quicker than follow me, and more convenient for as you have to select path first instead of interactively pointing each edge to follow, which is sometimes difficult.
                            DB
                            • monsterzeroM Offline
                              monsterzero
                              I use these the most:
                              Nudge (hotkey N)
                              Left Click Reverse Face Tool (hotkey K)
                              Set Center Point
                              Add Hidden Layer (hot key L)
                              I'm going to try Jim's Mover script as well. I suspect that I'll want to use Make Face when I really start moving files from Maya to SU. But for now I don't use it, I probably should.
                              monsterzero
                              I live stream my work on my graphic novel:
                              https://www.youtube.com/@monsterz3r0
                              http://infinitemachine.tv/
                              https://www.aaatitle.xyz/
                                Alan Fraser
                                The version I showed was downloaded from the Ruby forum....MENUS.rb I've put a copy in the Depository.
                                http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1538
                                3D Figures
                                  boofredlay
                                  This is how I use Follow Me. I select the path, select the follow me tool then click. Hmmm.
                                  Thanks a bunch Alan.
                                    Baker518
                                    I did some learning on Alan's Menu2.rb. I spent about 30 hours learning how to manipulate it to my tastes (I dont mean to step on any toes by doing it), I just wanted more rubies than it offered initially. It is quite flexable and easy to add to. It took alot of trial and error on my part but I learned a lot also. I left all the credits in place and didnt add my name to the list either.
                                    All that said, Menu2 is a great tool to organize your plugins somewhat neatly. You did good work Alan
                                    Don't worry about things you have no control over. Worry is a lack of Faith!
                                      marne
                                      For me as an landscape architect the
                                      mover2.rb,
                                      soap skin bubble,
                                      random push pull,
                                      randomize tin,
                                      TBD's Randor and of course the
                                      drop.rb, are very needful for creating and editing plants and areas.
                                      And always use the purge script for a fast cleanup of your model.
                                      Often useful is the selection memory tool, especially when u made a more complex selection...
                                      and sometimes some of all the other scripts, like flightpaath2 or so.
                                      Greetings marne
                                      • John SayersJ Offline
                                        John Sayers
                                        The one I use most appart from Housebuilder is "left click add construction point" shortcut N.
                                          bellwells
                                          I use PushPullAlongAVector and PutOnLayer quite a lot. Second tier scripts for me are 3D Text (I use SU5 more than 6), 2D Grid and Stair.
                                          I possess 10 times more scripts than I use. Boys and their toys, huh?
                                          Ron
                                            mozzie
                                            My use of SU rather specialised and not representative, but I have greatly benefited from
                                            1. pipe along path & extrude along path
                                            2. points cloud
                                            3. put on layer
                                            My thanks to the respective authors.
                                            I have also used curve stitcher and angular dimension to good effect.
                                            And I love the go 2 school training videos!
