    Most used scripts.
    23 Posts 17 Posters 5.4k Views 17 Watching
      Stu
      Make Faces, every time I start a new model with an ACad drawing.......SU2KT, most times I finish a SU model and something I find absolutly indispensible.....Nudge rb.....for moving any group or component in x,y or z direction, for a distance I specify, independent of any snapping or inference.
      http://www.landesign.com.au
      • F Offline
        firkins
        Alan,
        Could you tell us more about the Menu script that you mentioned. I am a "power user" with many scripts in my plugins menu and would like to be able to organize them as you have.
        I have looked on Didiers ruby library and sMustard, but have not been able to located it. Could you point me in the right direction?
        Thanks,
        Michael
        %(#000080)["Those who would give up Essential Liberty
        to purchase a little Temporary Safety,
        deserve neither Liberty not Safety."]
        Ben Franklin
          Didier Bur
          Go to "Geometry-Drawing" section. Scripts are sorted alphabetically (by name) ๐Ÿ˜„
          DB
            boofredlay
            I cannot seem to find the Geometry-Drawing section. Maybe I am looking on the wrong site. ๐Ÿ˜ณ
            EDIT: Sorry, found it but I do not see Menu Loader there. What is the proper name of this srcipt?
            Also, what is the difference between "extrude along path" and "Follow Me"?
              Didier Bur
              Sorry, I thought you were searching for makefaces.rb ๐Ÿ˜ณ
              Menu loader is not available t my site, I forget to put it in a page.
              I'll retrieve it asap but maybe you could ask Alan for it... ๐Ÿ˜ฎ
              And extrudealongpath is quicker than follow me, and more convenient for as you have to select path first instead of interactively pointing each edge to follow, which is sometimes difficult.
              DB
              • monsterzeroM Offline
                monsterzero
                I use these the most:
                Nudge (hotkey N)
                Left Click Reverse Face Tool (hotkey K)
                Set Center Point
                Add Hidden Layer (hot key L)
                I'm going to try Jim's Mover script as well. I suspect that I'll want to use Make Face when I really start moving files from Maya to SU. But for now I don't use it, I probably should.
                monsterzero
                I live stream my work on my graphic novel:
                https://www.youtube.com/@monsterz3r0
                http://infinitemachine.tv/
                https://www.aaatitle.xyz/
                  Alan Fraser
                  The version I showed was downloaded from the Ruby forum....MENUS.rb I've put a copy in the Depository.
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1538
                  3D Figures
                    boofredlay
                    This is how I use Follow Me. I select the path, select the follow me tool then click. Hmmm.
                    Thanks a bunch Alan.
                      Baker518
                      I did some learning on Alan's Menu2.rb. I spent about 30 hours learning how to manipulate it to my tastes (I dont mean to step on any toes by doing it), I just wanted more rubies than it offered initially. It is quite flexable and easy to add to. It took alot of trial and error on my part but I learned a lot also. I left all the credits in place and didnt add my name to the list either.
                      All that said, Menu2 is a great tool to organize your plugins somewhat neatly. You did good work Alan
                      Don't worry about things you have no control over. Worry is a lack of Faith!
                        marne
                        For me as an landscape architect the
                        mover2.rb,
                        soap skin bubble,
                        random push pull,
                        randomize tin,
                        TBD's Randor and of course the
                        drop.rb, are very needful for creating and editing plants and areas.
                        And always use the purge script for a fast cleanup of your model.
                        Often useful is the selection memory tool, especially when u made a more complex selection...
                        and sometimes some of all the other scripts, like flightpaath2 or so.
                        Greetings marne
                          John Sayers
                          The one I use most appart from Housebuilder is "left click add construction point" shortcut N.
                            bellwells
                            I use PushPullAlongAVector and PutOnLayer quite a lot. Second tier scripts for me are 3D Text (I use SU5 more than 6), 2D Grid and Stair.
                            I possess 10 times more scripts than I use. Boys and their toys, huh?
                            Ron
                              mozzie
                              My use of SU rather specialised and not representative, but I have greatly benefited from
                              1. pipe along path & extrude along path
                              2. points cloud
                              3. put on layer
                              My thanks to the respective authors.
                              I have also used curve stitcher and angular dimension to good effect.
                              And I love the go 2 school training videos!
