๐Ÿ”Œ Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Most used scripts.
23 Posts 17 Posters 4.4k Views 17 Watching
    boofredlay
    Hi all.
    I never got deep into Ruby scripts.
    I tried a bunch out but really only use the Windowizer now.
    I was just wondering which ones you guys use the most and why.
    Thanks.
    Eric
      Phil Meadows
      I use Makefaces a lot. I also use TBD's Randor for randomizing the size and rotation of trees. that helps a lot if you want to avoid marching-soldier trees along a sidewalk or whatever.
      I guess if you want to call Podium a ruby script then that would be my #1.
        PeterCharles
        I use the "Unfold" plugin by Jim Foltz. Helps me create flat pattern profiles from sheet metal shapes. ๐Ÿ˜„
        Oh, and I use DrawHelix13 (but I shouldn't plug my only script ๐Ÿ˜ณ )
          boofredlay
          Thanks guys, I forgot about makefaces. I use that one when I import from autocad... that shows you how long it has been, I forgot about that command altogther.
          Since the v6 install, the only script I re-installed was windowizer, until now that is.
          Keep em comin'. ๐Ÿ˜‰
            Phil Meadows
            I haven't been able to work Windoizer into my workflow, as I do mostly retail centers with irregular storefront. I used it a lot more when I was building cities for my comic book work, but alas...I don't do that anymore.
            When I moved to version 6 I decided to only load tools as I needed them, thus keeping the bloat out of the plugins menu. I've got:
            Curve Stitcher
            Flatten to 2d
            Mirror selection
            Podium
            Randor
            Weld
            Xporter
            Xref tools
            and that's it. Well, Makefaces over in the Tools folder. I have tons of ruby scripts loaded in V.5 but these are the only ones I've needed since upgrading.
              daiku
              TIG's AddVertex+.rb
              Always seems to know right where I want a cpoint.
              Clark Bremer
              http://www.northernlightstimberframing.com
                Hi all,
                It mostly depends what exactly I'm doing but these are now my regular ones:
                Lately, for a bigger work to reconstruct some Gothic architecture:
                Curve Stitcher
                Weld
                Tube along Path
                For creating terrains by exact measurement:
                Cloud
                Convert to xLines (plus maybe Delete Construction Lines Only)
                Triangulate points
                What is new to me but enjoy playing with it:
                Soap Skin and Bubble
                  CadFather
                  extrude along path, drop, mirror, filter extensions, projections...
                  • N Offline
                    not registered yet
                    a picture
                    http://www.sketchucation.com/forums/scf/sas/Ruby/untitled.jpg
                    [LMNO]
                      Alan Fraser
                      I use many of the ones already mentioned...especially Make Faces. One I don't think anyone has mentioned so far is Menu...based on Didier's menu loader. There may be something better by now, but I find it invaluable for keeping everything neat and tidy.
                      http://www.sketchucation.com/forums/scf/sas/Ruby/menu.png
                      3D Figures
                        Stu
                        Make Faces, every time I start a new model with an ACad drawing.......SU2KT, most times I finish a SU model and something I find absolutly indispensible.....Nudge rb.....for moving any group or component in x,y or z direction, for a distance I specify, independent of any snapping or inference.
                        http://www.landesign.com.au
                        • F Offline
                          firkins
                          Alan,
                          Could you tell us more about the Menu script that you mentioned. I am a "power user" with many scripts in my plugins menu and would like to be able to organize them as you have.
                          I have looked on Didiers ruby library and sMustard, but have not been able to located it. Could you point me in the right direction?
                          Thanks,
                          Michael
                          %(#000080)["Those who would give up Essential Liberty
                          to purchase a little Temporary Safety,
                          deserve neither Liberty not Safety."]
                          Ben Franklin
                          • Didier BurD Offline
                            Didier Bur
                            Go to "Geometry-Drawing" section. Scripts are sorted alphabetically (by name) ๐Ÿ˜„
                            DB
                              boofredlay
                              I cannot seem to find the Geometry-Drawing section. Maybe I am looking on the wrong site. ๐Ÿ˜ณ
                              EDIT: Sorry, found it but I do not see Menu Loader there. What is the proper name of this srcipt?
                              Also, what is the difference between "extrude along path" and "Follow Me"?
                                Didier Bur
                                Sorry, I thought you were searching for makefaces.rb ๐Ÿ˜ณ
                                Menu loader is not available t my site, I forget to put it in a page.
                                I'll retrieve it asap but maybe you could ask Alan for it... ๐Ÿ˜ฎ
                                And extrudealongpath is quicker than follow me, and more convenient for as you have to select path first instead of interactively pointing each edge to follow, which is sometimes difficult.
                                DB
                                • monsterzeroM Offline
                                  monsterzero
                                  I use these the most:
                                  Nudge (hotkey N)
                                  Left Click Reverse Face Tool (hotkey K)
                                  Set Center Point
                                  Add Hidden Layer (hot key L)
                                  I'm going to try Jim's Mover script as well. I suspect that I'll want to use Make Face when I really start moving files from Maya to SU. But for now I don't use it, I probably should.
                                  monsterzero
                                  My New Twitch Stream!
                                  https://www.twitch.tv/infinitestorylab
                                  infinitemachine.com
                                    Alan Fraser
                                    The version I showed was downloaded from the Ruby forum....MENUS.rb I've put a copy in the Depository.
                                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1538
                                    3D Figures
                                      boofredlay
                                      This is how I use Follow Me. I select the path, select the follow me tool then click. Hmmm.
                                      Thanks a bunch Alan.
                                        Baker518
                                        I did some learning on Alan's Menu2.rb. I spent about 30 hours learning how to manipulate it to my tastes (I dont mean to step on any toes by doing it), I just wanted more rubies than it offered initially. It is quite flexable and easy to add to. It took alot of trial and error on my part but I learned a lot also. I left all the credits in place and didnt add my name to the list either.
                                        All that said, Menu2 is a great tool to organize your plugins somewhat neatly. You did good work Alan
                                        Don't worry about things you have no control over. Worry is a lack of Faith!
                                          marne
                                          For me as an landscape architect the
                                          mover2.rb,
                                          soap skin bubble,
                                          random push pull,
                                          randomize tin,
                                          TBD's Randor and of course the
                                          drop.rb, are very needful for creating and editing plants and areas.
                                          And always use the purge script for a fast cleanup of your model.
                                          Often useful is the selection memory tool, especially when u made a more complex selection...
                                          and sometimes some of all the other scripts, like flightpaath2 or so.
                                          Greetings marne
                                          1 / 2
