    Section Edge Display
    12 Posts 9 Posters 2.1k Views 9 Watching
      Japes
      Can anyone tell me if it's possible to alter the edge thickness of sections once/or before I create them?
      JP
        JuanV.Soler
        you can go to window - styles and then edit.
        you´ll see : section cut width
          Japes
          Thanks for the fast reply, I don't suppose it's possible to get the 'face' of a section to 'fill' is it?
          • EdsonE Offline
            Edson
            japes,
            2 tips.
            there is a ruby script that does just that. it is called SectionCutFace.rb and you can get it at the Ruby Library Depot:
            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/SectionCutFace.rb
            a couple of threads in the old forum that deal with that:
            http://forum.sketchup.com/showthread.php?t=41114&highlight=section+cuts
            http://forum.sketchup.com/showthread.php?t=68163&highlight=fill+section+cuts
            hope it helps you.
            edson
            http://www.mahfuz.arq.br
              Japes
              Thank you edson, that's a great help
              JP
              • boofredlayB Offline
                boofredlay
                That is a great ruby Edison. I use it quite a bit.
                Note that the second link that Edison posted above takes you to a thread that is 4 pages long. The most recent ruby script is 1.9 about 3/4 the way down page 3.
                  dylan
                  Thanks for the info Eric, I didn't have the latest version.
                  http://dmdarchitecture.co.uk/
                    Gidon Yuval
                    Eric, you're so right. It's one of my favourite scripts. It's so useful, logical and necessary that it makes you wonder how it wasn't a built in SU tool to begin with.
                    If you don't know where you're going, you're never going to get there.
                      Jackson
                      Wow, I really need to rummage through the Depot again- I'd missed this great script! Thanks for the info Edson.
                      Jackson
                      Jackson
                        I also use it a lot - and since it makes all faces of the section cut independent faces, you can later paint them as you wish. A stone wall cut can be stone, a wooden beam wooden etc. Really great, indeed.
                        I still have some problems with it. As I noticed, with difficult geometry (lots of - often nested - components/groups, layers etc.) the created group somehow tends to be kind of "hidden" behind the section plane itself and I need to move the plane a bit (1 or 2 cms) "off" the group to display it. Then it leaves this small distance there - though obviously it does not bother too much most of the times.
                        • TIGT Online
                          New improved version of SectionCutFace.rb is in the depository here...
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1517
                            TIG, thanks for posting it here, too (I already use the enw version and works perfectly) I just forgot to "update" this thread.
