    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Tubealongpath.rb
    28 Posts 12 Posters 5.9k Views 12 Watching
    • N Offline
      not registered yet
      Hey y'all,
      I have this script from
      404 Not Found
      (www.crai.archi.fr)
      I like the way that it works with one exception.
      I would love to have it on the context menu when I right-click a line.
      I played around a bit and I could get it to show up on the context
      menu, but cannot get it to work from there.
      Any help would be appreciated.
      Thanks,
      Mike W.
        lewiswadsworth
        That is also one of my favorite scripts, but I simply added a shortcut key for it.
        --Lewis
        [Lewis Wadsworth]
        col sporcar si trova
          azuby
          UI.add_context_menu_handler { |m| m.add_item("Tube Along Path") { tube_along_path } }
          azuby
          *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
          Bad English? PM me, correct me. :smile:**
            I also use it a lot with Gothic vault ribs and window tracery. I love it!
            • N Offline
              not registered yet
              Does it look similar to chamferalongpath.rb?
              [Invader ZIM]
              • boofredlayB Offline
                boofredlay
                --Lewis
                You replied about the tubealongpath.rb
                What does this ruby do that follow me does not? I did not want to divert the topic.
                Thanks.
                  Eric, it mostly does the same it is just a faster and easier way of it (though obviously with limited possibilities regarding the faces to be extruded). But when I need to extrude a lot of faces all along a Gothic window tracery for instance, it is very handy because I dont need to precisely place the faces to be extruded just hit the script and it does the job.
                  Obviously I don't always use it when making extrusions.
                    lewiswadsworth
                    Eric,
                    I end up modeling a great many tubular railings along stairs and balconies, and this is something of a life saver...I don't have to orient a face perpendicular to the edge that describes the rail, I just select the rail, hit the hotkey for the plugin, specify my diameter, and go. It has also proved useful in creating steel trusses and open-web joists where the chords are round in cross section.
                    However, the variant pipe-along-path ruby is even more useful much of the time, because I can specify the number of edges in the circle sweeping the edge. Usually I don't need more than 8 if the tube/pipe is small diameter. I just have to remember to set the inner diameter to 0 when I don't want a real pipe.
                    404 Not Found
                    (www.crai.archi.fr)
                    --Lewis
                    [Lewis Wadsworth]
                    • N Offline
                      not registered yet
                      Azuby,
                      Thanks much! That worked like a charm.
                      Eric,
                      I am making a model of our plant and all of its plumbing and wiring. This works well for tubing along odd angles because I don't have to set a face for follow me to use.
                      Thanks all,
                      Mike W.
                        Glad my script is useful...
                          We all are, TIG, thanks...
                          šŸ˜„
                            boofredlay
                            Thanks for the Script TIG, and thanks for the information Gaieus and Lewis. I will go get me one.
                              Typically at the end of an interactive script there's a menu section, something like:
                              if( not file_loaded?("............."))
                              XXXXXXXXXXXXXXXXX
                              file_loaded="..........."
                              The "............." is the script's name and the XXXXXXXXXXXXXXXX part is the menu definition - this is so it only loads once if for some reason you manually load the script etc you'll only get one menu item.
                              To add a right-click context-menu you need to add some code - like azuby's or similar forms. You replace the title and 'action' to suit... so in "Mirror.rb" it's:
                              UI.add_context_menu_handler do |menu|
                              if Sketchup.active_model.selection
                              menu.add_separator
                              menu.add_item("Mirror Selection") { Sketchup.active_model.select_tool MirrorTool.new}
                              end#if
                              end#do menu
                              inside the if loop at the end as well as the normal Plugins Menu instructions...
                              Azuby's equivalent way would be:
                              UI.add_context_menu_handler{|menu|menu.add_separator;menu.add_item("Mirror Selection"){Sketchup.active_model.select_tool MirrorTool.new}}
                                Feel free... it's the only way we learn...
                                  kdjanz
                                  Just to update TIG's reply, here is the code to cut and paste that worked for me FOR THE PIPE_ALONG_PATH ruby:
                                       ###$submenu2.add_item("Pipe Along Path") { pipe_along_path }###
                                     UI.add_context_menu_handler{|menu|menu.add_separator;menu.add_item("Pipe Along Path"){Sketchup.active_model.select_tool pipe_along_path.new}}
                                  Hope this helps everyone enjoy this excellent piece of code.
                                  Thanks again TIG
                                  Kelly
                                    stefx
                                    Sorry guys....
                                    I'm a little bit new with sketchup plugin and ruby script....
                                    so...
                                    I can't understand how I can install this tool..
                                    Could someone help me?
                                    many thanks,
                                    Stef.
                                      remus
                                      You need to download the file form the link in the OP. Once youve done that you need to move it to the plugins folder in the SU system file -> \google\google sketchup 6\plugins
                                      Once youve done that the plugin should be in the 'plugins' menu next time you start SU up.
                                        stefx
                                        Hi Remus!
                                        Thank you for your answer.....
                                        but...
                                        usually I download a file (with .rb file) and I put in plugin folder....(as you told me!)
                                        I don't understand when you say "You need to download the file form the link in the OP"
                                        Is there a link where I can download the file?
                                        (I can find just the script text and I'm not able to use it)
                                        Probably it is a silly request...I know, I'm very new of sketcup's plugins!...sorry!
                                        Could someone help me?...Thanks!
                                        Stef.
                                          Hi Stef,
                                          Yes, that is the script itself actually.
                                          Select all the text and copy/paste it into a plain text editor (such as Notepad or something - no MS Word or anything like that!) then save the text file as TubeAlongPath.rb into the Plugins folder.
                                            rv1974
                                            Hi TIG!
                                            Is it possible to extend the existing .rb by adding 3d\cross etc. line conjunctions handling?
                                            It'd be a real killer!
