    Tubealongpath.rb
    28 Posts 12 Posters 7.3k Views 12 Watching
    • GaieusG
      We all are, TIG, thanks...
      πŸ˜„
      • boofredlayB
        boofredlay
        Thanks for the Script TIG, and thanks for the information Gaieus and Lewis. I will go get me one.
          Typically at the end of an interactive script there's a menu section, something like:
          if( not file_loaded?("............."))
          XXXXXXXXXXXXXXXXX
          file_loaded="..........."
          The "............." is the script's name and the XXXXXXXXXXXXXXXX part is the menu definition - this is so it only loads once if for some reason you manually load the script etc you'll only get one menu item.
          To add a right-click context-menu you need to add some code - like azuby's or similar forms. You replace the title and 'action' to suit... so in "Mirror.rb" it's:
          UI.add_context_menu_handler do |menu|
          if Sketchup.active_model.selection
          menu.add_separator
          menu.add_item("Mirror Selection") { Sketchup.active_model.select_tool MirrorTool.new}
          end#if
          end#do menu
          inside the if loop at the end as well as the normal Plugins Menu instructions...
          Azuby's equivalent way would be:
          UI.add_context_menu_handler{|menu|menu.add_separator;menu.add_item("Mirror Selection"){Sketchup.active_model.select_tool MirrorTool.new}}
            Feel free... it's the only way we learn...
            • K
              kdjanz
              Just to update TIG's reply, here is the code to cut and paste that worked for me FOR THE PIPE_ALONG_PATH ruby:
                   ###$submenu2.add_item("Pipe Along Path") { pipe_along_path }###
                 UI.add_context_menu_handler{|menu|menu.add_separator;menu.add_item("Pipe Along Path"){Sketchup.active_model.select_tool pipe_along_path.new}}
              Hope this helps everyone enjoy this excellent piece of code.
              Thanks again TIG
              Kelly
                stefx
                Sorry guys....
                I'm a little bit new with sketchup plugin and ruby script....
                so...
                I can't understand how I can install this tool..
                Could someone help me?
                many thanks,
                Stef.
                  remus
                  You need to download the file form the link in the OP. Once youve done that you need to move it to the plugins folder in the SU system file -> \google\google sketchup 6\plugins
                  Once youve done that the plugin should be in the 'plugins' menu next time you start SU up.
                    stefx
                    Hi Remus!
                    Thank you for your answer.....
                    but...
                    usually I download a file (with .rb file) and I put in plugin folder....(as you told me!)
                    I don't understand when you say "You need to download the file form the link in the OP"
                    Is there a link where I can download the file?
                    (I can find just the script text and I'm not able to use it)
                    Probably it is a silly request...I know, I'm very new of sketcup's plugins!...sorry!
                    Could someone help me?...Thanks!
                    Stef.
                    • GaieusG
                      Hi Stef,
                      Yes, that is the script itself actually.
                      Select all the text and copy/paste it into a plain text editor (such as Notepad or something - no MS Word or anything like that!) then save the text file as TubeAlongPath.rb into the Plugins folder.
                        rv1974
                        Hi TIG!
                        Is it possible to extend the existing .rb by adding 3d\cross etc. line conjunctions handling?
                        It'd be a real killer!
                          stefx
                          Hi Gaieus,
                          Thnak you very much for your answer.
                          I got a problem.
                          I get copy and paste in a notepad and then save it with the name "tubealongpath.rb" in the plugin folder (so i can see a txt file with that name) but also after a restart I cannot see anything in the plugin menu...
                          have you got any idea about the mistake?
                          Thanks.
                          Stef.
                          • jujuJ
                            juju
                            What OS are you using and do you have administrative privileges using the logon you're using when you do the changes?
                            • GaieusG
                              I think ruby scripts are csae sensitive. Save with the exact name I posted.
                                stefx
                                Hi Juju,
                                I'm using Windows Xp.
                                I didn't get any problems with plugins and .rb files before.
                                I think it is really weird.
                                There are not many things to try......so....
                                if someone find out something let me know!
                                thanks.
                                stef.
                                  remus
                                  You could always right click the link in the OP and download the file straight to your plugins folder. That would hopefully eliminate any problems with naming the file.
                                    stefx
                                    Hi Remus!
                                    Thank for your tip!
                                    I tried it and now it works properly!
                                    For sure it was my mistake in terms of name....anyway...
                                    Now I start to play with it...it seems like follow me....is there any chance to have different radius of different section of the same pipe?
                                    stef.
                                    • GaieusG
                                      Hi Stef,
                                      Not with thisscript. Still it is very handy because it creates the extrusion easily and you need not hassle with aligning faces perpendicular to lines and such.
                                        stefx
                                        Gaeius,
                                        Thank you very much for your help!!
                                        the script is very helpful!
                                        Very good job!
                                        Stef.
