    [Tutorial > Modeling] How a Pro Builds a House in SU pt 2
    47 Posts 23 Posters 41.9k Views 23 Watching
    • EdsonE Offline
      Edson
      hi kris,
      this tutorial is a great input for most people, I am sure. thanks a lot for your generosity.
      http://www.mahfuz.arq.br
      • KrisidiousK Offline
        Krisidious
        thedifferenz,
        how your structure will look in the real world, to be as real as possible... use real world materials. and I mean componenets really. if you are going to build a wall, don't just draw a face and pull it up, create 2x4's 2x6's 4'x8' plywood and sheet rock, and then manipulate those comonents over and over, using the "make unique" command on the context menu. put these together to create your wall and then you will know exactly what the framer in the field will run up against.
        "But, I am not confident about using sketchup to do the elevation of my house. Because, i learned sketchup using trial-and-error method, which is time consuming. And i lack the basics of drawings. I always used to get confused about where my line is getting drawn, is it in x axis/yaxis/z axis... and i still dont know how to draw a line is a particular axis... i click here, i click there, then draw and will check where it came up, if its not in right direction, i will delete it and will try again... and it suX(could some help me out of this?)."
        this should be solved with the color of the axis in sketchup.
        http://www.applelinks.com/reviews/gifs/sketchup-onaxis.gif
        I've posted those screen shots... and I invite everyone to add their WIP (Work In Progress) pictures to this thread... and feel free to ask questions...
        emahfuz,
        thanks for the kind words... I have a design you might like called Paixao...
        I mainly did this thread for the exact reason of thedifferenz, he found this page via Google already and I just made it a few days ago... that is shooting the rank of this site up... and getting new visitors... the more helpful posts, the more folks we get...
        By: Kristoff Rand
          Daniel Bouchard
          Kris,
          Very interesting and very useful. I'll try soon.
          Thanks a lot
          • EdsonE Offline
            Edson
            kris,
            let me know where to find Paixao...
              Shaun Tennant
              Edson,
              Check here! http://www.aboveallhouseplans.com/House_Plans/Paixao/Paixao.htm
              (Shaun Tennant)
              Whether they find a life there or not, I think Jupiter should be called an enemy planet.
              • Jack Handey
              • EdsonE Offline
                Edson
                thanks, shawn.
                it is a curious name for a design as it means passion in portuguese. it can also be a fairly common surname.
                regards.
                  Krisidious
                  thanks Shaun for posting the link... my lil SU Groupie... 😉
                  emahfuz, yes Passion... is the name, I knew being Brazilian you would notice...
                  By: Kristoff Rand
                    rhankc
                    kris,
                    Your tuts are good:You have heard the thing about give a man a fish, feed him for a day, teach him to fish.... judging from the muscle in your template I think you could write a great tut on template building that would power the lessons in push/pull walls and roofs even faster and farther. Keep up the good work! thanks!
                    Hank
                    • EdsonE Offline
                      Edson
                      I am eagerly waiting for part 3.
                      edson
                        tegman
                        Fantastic tutorial!!!
                        I've learned a lot of things!!!!
                        Thanks for sharing you knowlegde!!!
                        Rick
                        (Tegman)
                        Architectural desktop, Sketchup, Chief Architect.
                        http://plans-rf.blogspot.com/
                        • N Offline
                          not registered yet
                          The tutorial is very good - I'm just a beginner.
                          Wondering where we find Part 1?
                          (norske)
                            Krisidious
                            here ya go...
                            404 Not Found
                            (www.sketchucation.com)
                            By: Kristoff Rand
                              DzineTech
                              Greetings all, my 1st post on these new forums. Well done to Coen setting this place up; a far superior environment and interface than the new google groups in my opinion.
                              Anyway back on topic. I've read through this how-to and felt that I should add my own thoughts on the advice given in a constructive manner that will hopefully provide some of the newer modellers with an alternate method of construction.
                              My main disagreement with the workflow provided is the procedure of the wall construction. There was good advice given regarding the tidyness of our drawings however I feel that one of the most important area of modelling/CAD housekeeping is to not create faces and edges that aren't required. If you follow the procedure of push-pulling rectangles to form the external walls in a series of panels as shown, you end up with 4 lines and 1 face between each panel junction that simply aren't required (note: only on panels which run parallel!). This method of modelling is akin to building blocks whereas my personal preference is to somewhat different.
                              Stage 1
                              My advice would be to trace the outline of the external wall to form a shape and offset the wall thickness inwards. This will leave you with 2 shapes (1 for the thickness of the external wall and another for the internal void) Of course the internal line of the external wall may have areas where it differs from the plane of the external but the line tool and eraser can quickly tidy this up as required.
                              Stage 2
                              With the correct shapes now drawn, a simple push pull of the external wall face to the necessary height will extrude our entire wall in one operation instead of several and we will have the minimum amount of faces required. The top and bottom faces of the wall extrusion can also be deleted as they won't normally be seen unless in section. Internal walls follow the same procedure of tracing the outline to form one face and extrude as before.
                              Stage 3
                              Window and door openings. My preference is to make components of these and I would locate the insertion point at the top center of the component. Once made I would create a guideline at 2.1m (sorry, child of the metric age here!) above internal finished floor level and place my door or window on this. A simple horizontal move will finish the required location of the component.
                              Previously I would create components that would cut the external wall face however now I tend not to. As SketchUp is a suface and not a solids modeller my components wouldn't cut the internal face of the wall. to solve this I now draw a rectangle on the external wall face, tracing the opening of the already placed window/door. Push-pulling this new face inwards the depth of the wall thickness (either type the distance or switch to wireframe and snap to an internal face edge). This makes the soffit and jamb faces (internally and externally) in a quick clean operation and should not require any data cleanup.
                              I hope it all makes sense and as I recognise a few names from the former sketchup forums I know you guy's (and gal's!) will probably be aware of the workflow already but perhaps some newcomers will benefit from it.
                              Time for a coffee...
                              (DzineTech)
                                Krisidious
                                there is a method to my madness...
                                the reason I want those extra faces... it prepare for autocad and drafting a house's construction documents. if this were just a 3D model I would agree... but it's for a pro to make a real house out of.... so we need to be able to cut sections at any poin where a window is and see the mullions...
                                thanks for you advice though.
                                By: Kristoff Rand
                                  DzineTech
                                  Sorry, but I don't understand what you mean by requiring the extra faces for autocad; perhaps you can explain or illustrate with a screenshot?
                                  I assume when you mean pro you mean that you will produce construction drawings based on the model and these will be issued to a professional kit manufacturer (timber frame/metal frame) or to a contractor for his brick layers. Your requirement to see the window components (head, cill, transom, mullions, jambs etc..) works exactly the same for section cuts in my workflow as yours does; the important factor being that the window component would need to be detailed enough to reveal enough information wherever the section planes are located.
                                  (DzineTech)
                                    sorgesu
                                    Kris, this is probably the most germaine and most required tutorial for SketchUp. So good of you to go to such detail to do this. Great job.
                                    Susan Sorger
                                    Former Seller Hand Rendered Entourage
                                    Former Canadian Authorized Training Centre, SketchUp
                                      Krisidious
                                      yes I need to buckle down and get part 3 done... the home is complete...
                                      here are some screenshots
                                      http://www.aboveallhouseplans.com/Clients/Wilson/Wilson_Forrest.htm
                                      there are a few problems with it, but I never really complete anything... I'm always off to the next project
                                      By: Kristoff Rand
                                        Krisidious
                                        DzineTech,
                                        yes you are correct in your assumption, however if you were to cut a section above the window, most people have removed those faces, and thus the window only shows up if you cut the section directly through the area in which the window is located.
                                        so we may both be right...
                                        DzineTech points out that it is the proper way to model, to remove any faces which are not seen or used. which I agree with.
                                        and as he or she points out, you can model the house and make construction docs from it using his method, if the all the windows and openings are at the same level, through out the home. however if some windows or openings are above others with in the same floor or plane, then you will not see them when you do a section cut at the nominal level.
                                        am I being clear? I'm trying, I'll make some screenshots later like DzineTech suggested. and I'll try to get part three done.
                                        By: Kristoff Rand
                                          DzineTech
                                          Kris, I understand the difficulties that varying window openings poses if you are trying to show a section through both at the one time. I'm hoping your screenshots will explain how your wall construction method achieves this.
                                          Personally I wouldn't even consider taking a SketchUp model to create construction drawings. For me I keep use it for 3D only and use Microstation for all technical work. The workflow I use gives me speed and keeps file sizes to a minimum. If your method works for you then good. I'm certainly not egotistic and insisting that what I do is the only way to do it and all other methods are wrong.
                                          PS I'm Male 😄
                                          (DzineTech)
                                            Krisidious
                                            oh of course not... there is more than one way to skin a ______...
                                            By: Kristoff Rand
                                            • 1 / 3
