    [Tutorial > Modeling] Woodworking Dovetails - Tutorial
    28 Posts 10 Posters 13.0k Views 10 Watching
    • T
      titmas
      Very practical and truly 3 dimensional. You said to explode the legs before intersecting with model, so must each object that is going to be intersected with model be a component or a group? Iv also been having some issues with not being able to select a single line after the intersect but instead it selects the whole object. Is this due to not exploding before interesting?
      • G
        Gidon Yuval
        That's exactly it Sean. Only if your parts are exploded will SU form the faces that should be there after clean-up. SU seems to 'borrow' the faces from the two parts in order to complete the new part.
        In some cases it is necessary to copy the one part and keep one copy as a group while using the other copy to form the new part using intersect. That's what I did in the dovetail tut.
        In the case of the leg, no copying was needed as the origional part is not an actual part of the table but rather a tool or template of sorts.
        By the way, do you not like having your picture taken? You look so pissed off in your avatar πŸ˜„
        (Gidon)
        If you don't know where you're going, you're never going to get there.
        • T
          titmas
          Gidon,
          thanks, now that i know how IWM works it makes it easier to do these cut away views for detailed construction sketches.
          http://www.sketchucation.com/forums/scf/sas/Tutorials/floating TV shelf.jpg
          ...and about that Avatar, that photo is about 2 years old back when i was hairy-er and meaner, now the beard is gone along with the mean guy persona(thanks to my girlfriend)but the photo is kind of a reminder.
          • boofredlayB
            boofredlay
            I did not think you avatar was mean or mad at all. I thought you looked like you just woke up on the beach after an all nighter and was ready to surf. πŸ€“
            • T
              titmas
              Actually Eric, you don't know just how close you are with that one. πŸ˜‰
              Its nice to see that 'hello kitty' is trying out for the football team. Or is he going to a halloween party as a 'Gladiator' extra? Either way that's just about the only kitten photo that doesnt make me want to puke from its sugary sweet cuteness.
              • G
                Gidon Yuval
                Actualy, the kitten is wearing that helmet in self defence. There's a killer hamster on the loose.
                (Gidon)
                • G
                  Gidon Yuval
                  I thought I'd add another little tutorial on a technique that has saved me countless hours of time and which is great for tweeking furniture parts.
                  I can't figure out how to insert a photo into the body of the text so I'll add them as attached files.
                  Sorry.
                  Anyway, this tutorial deals with moving in edit mode as opposed to scaling.
                  (Gidon)
                  • G
                    Gidon Yuval
                    Move vs. Scale - continued.
                    Sorry about the clumsy way I posted this. Like I said, I can't figure out how to insert the pictures into the body of the text.
                    Any way, I hope you find this usefull.
                    (Gidon)
                    • T
                      titmas
                      So now I can make just one component of a certain style of drawer/cabinet/box etc and use the move tool in edit mode to re-size it for the application at hand verses having to make many different sizes of the same component. Cool.
                        SchreiberBike
                        @gidon said:
                        By the way Schreiber, which woodworking forum were you refering to?
                        I'm moderately active over at SawmillCreek.org. A lot of excellent woodworkers there.
                        Dave Richards showed me a much better way to do dovetails in SU and when I get a chance, I'll post a new tutorial.
                        Woodworkers get very picky about their dovetails because they are hard to do well and because they are a very strong way of making a drawer or a case. They can be made with a router and a jig fairly easily, but handmade dovetails can be made to look very distinctive.
                        Here are some really nice ones.
                        The gentleman who made this particular joint is Mark Singer. He is architect and a woodworker and a bunch of other things. He made this piece for a very cool California-coast house which he designed, built furniture for and won an award for.
                        • boofredlayB
                          boofredlay
                          Beautiful.
                          • G
                            Gidon Yuval
                            That is a nice piece John.
                            I stopped in at Sawmill Creek a few times a while ago. A very nice forum indeed. I should go back and visit.
                            (Gidon)
                              Sawduster
                              Over the weekend I downloaded Wink and played around with it. One of the things I did was another tutorial on drawing DTs in SU. Gotta admit, never thought about using Intersect Model to draw the DTs or pins. One thing I would add is to speed up the drawing of the lines for the DTs. I do the top and bottom half tail lines, dimension the first width line from each of those, then do a copy of each half tail line with a "/#" to do the rest of the lines.
                              I would not object to a special forum here for woodworking stuff, though I've learned a ton of stuff from the archetectural types and others.
                              BTW, I believe you have to store pics somewhere on the net, then use the [img]url%20of%20pic[/img] function to link to it from the post. Like this:
                              http://xs52.xs.to/pics/05434/BentwoodTable04.jpg
                              That is stored on my website and linked. Saves storeage space here.
                              Attaching pics limits how and where they show up. There's a work around by atttaching them to others posts then linking to them in the post you want them. PITA.
                              May all your dimensions be the sum of their total.
                              Jerry
                              http://www.sawdustersplace.com
                                [attachment=0:3asosxvb]<!-- ia0 -->IMG_2037.jpg<!-- ia0 -->[/attachment:3asosxvb]
                                The rest of the house that those dovetails are in is quite nice as well. So is the house he lives in.
                                Glad to have helped you out John.
                                FWIW, here's the method I showed John. I was kind of tired when I did it and it shows in the video.
                                http://www.brightcove.tv/title.jsp?title=1184386602
                                Dave
                                • N
                                  not registered yet
                                  @titmas said:
                                  If dovetails are the mark of a crafstman than half-blind dovetails are the mark of...
                                  http://www.sketchucation.com/forums/scf/sas/Tutorials/half blind dovetail joint.jpg
                                  ... a compulsive-obsessive perfectionist!!
                                  (gppatnude)
                                  • GaieusG
                                    In all the years I've been around carpentry I've never heard that one, good call Eric.
                                    Although not as sophisticated as the dovetail joint, the box joint is equally as strong but much less complicated to make and has a more utilitarian feet to it.
                                    http://www.sketchucation.com/forums/scf/sas/Tutorials/box joint.jpg
                                    • 2 / 2
