    [Tutorial > Modeling] Woodworking Dovetails - Tutorial
    28 Posts 10 Posters 13.7k Views 10 Watching
      alan wood
      Hi John,
      I am really interested in helping a beginner to dovetailing, master the topic.
      If you are up for it, post a model of the project in mind, either publically or privately and I will attempt to walk you through the project. I'm also happy designing the dovetails on the drawers and the full drawer constuction plus any other stuff you need help with.
      cheers
      Alan
      http://www.hand-cut-dovetails.com
      • T
        titmas
        If dovetails are the mark of a crafstman than half-blind dovetails are the mark of...
        http://www.sketchucation.com/forums/scf/sas/Tutorials/half blind dovetail joint.jpg
        • boofredlayB
          boofredlay
          ... half blind craftsmen? πŸ˜†
          This is one area of woodworking I have not tackeled yet. Hand cut or otherwise. Alan has tried to get me cutting some but time is just not on my side these days.
          • G
            Gidon Yuval
            This thread certainly strengthens my belief that there should be a wood working sub forum.
            I thought the tutorial was excelent, but I am kinda confused. It seems to start off like a tutorial on how to make dovetails in the workshop and then turns into a tutorial about how to do them in SU.
            As far as doing them in SU I'd like to offer my own tutorial, if I may. I hope you find it usefull. It takes a slightly different approach.
            By the way, Alan, I love your web site.
            Cheers guys
            (Gidon)
            If you don't know where you're going, you're never going to get there.
            • T
              titmas
              Gidon,
              I appreciate your tut on DT's especially the 'intersect with model' function. To me, at least, its a pretty powerful function and I've been trying to use that more in my modeling so its nice to have your tut that uses it.
              side note, I checked out your 'display cabinet' thread and not only is that a beautiful cabinet you modeled but by selectively deconstructing it I gained some insight into building cabinets with inset doors. I like your use of an applied filler strip between the doors and an interior shelf on the bottom of the cabinet to stop the door. Thanks, I'll try to incorporate that into my next inset door project
              • TaffGochT
                TaffGoch
                Are you familiar with the 'Fine Woodworking' magazine blog that concentrates on how to use SketchUp in the woodshop? There are several dovetail posts in the blog:
                http://blogs.taunton.com/n/blogs/blog.aspx?webtag=fw-designforum
                (Click on the 'Archive' link, under 'Blog Entries' in the right-hand column, to find the dovetail posts.)
                I don't recall mention of the site here, and only recently discovered it myself. Mr. Killen was having trouble with the teaching lab computers and their OpenGL drivers. He came to the Google SketchUp Help Group for assistance, and was able to get back on track. I'm glad he looked to the group for help, otherwise, I'd never known about the blog!
                "Information is not knowledge." -- Albert Einstein
                  alan wood
                  Hi Gidon
                  Thanks for the comments re the web page, all possible thanks to the help from Modelhead(Bruce). It is a slow process because I do the lot, in between all other things in life I enjoy. If you find anything that is not clear, please tell me so that I can improve it.
                  I've saved your tutorial, especially liked the intersect with model that will speed things up considerably in my workflow.
                  TaffGoch. Enjoyed the link to Fine Woodworking and their blog regarding SketchUp.
                  I'm now writing for the 'British Woodworking' magazine, and eventually they will be providing downloadable sketchup models from their web site. Some of the images they published were created in Sketchup. I didn't think I would have been doing that this time last year.
                  cheers
                  Alan
                  • G
                    Gidon Yuval
                    Here's another tutorial that's based on "intersect with model".
                    By the way Schreiber, which woodworking forum were you refering to?
                    (Gidon)
                    • T
                      titmas
                      Very practical and truly 3 dimensional. You said to explode the legs before intersecting with model, so must each object that is going to be intersected with model be a component or a group? Iv also been having some issues with not being able to select a single line after the intersect but instead it selects the whole object. Is this due to not exploding before interesting?
                      • G
                        Gidon Yuval
                        That's exactly it Sean. Only if your parts are exploded will SU form the faces that should be there after clean-up. SU seems to 'borrow' the faces from the two parts in order to complete the new part.
                        In some cases it is necessary to copy the one part and keep one copy as a group while using the other copy to form the new part using intersect. That's what I did in the dovetail tut.
                        In the case of the leg, no copying was needed as the origional part is not an actual part of the table but rather a tool or template of sorts.
                        By the way, do you not like having your picture taken? You look so pissed off in your avatar πŸ˜„
                        (Gidon)
                        • T
                          titmas
                          Gidon,
                          thanks, now that i know how IWM works it makes it easier to do these cut away views for detailed construction sketches.
                          http://www.sketchucation.com/forums/scf/sas/Tutorials/floating TV shelf.jpg
                          ...and about that Avatar, that photo is about 2 years old back when i was hairy-er and meaner, now the beard is gone along with the mean guy persona(thanks to my girlfriend)but the photo is kind of a reminder.
                          • boofredlayB
                            boofredlay
                            I did not think you avatar was mean or mad at all. I thought you looked like you just woke up on the beach after an all nighter and was ready to surf. πŸ€“
                            • T
                              titmas
                              Actually Eric, you don't know just how close you are with that one. πŸ˜‰
                              Its nice to see that 'hello kitty' is trying out for the football team. Or is he going to a halloween party as a 'Gladiator' extra? Either way that's just about the only kitten photo that doesnt make me want to puke from its sugary sweet cuteness.
                              • G
                                Gidon Yuval
                                Actualy, the kitten is wearing that helmet in self defence. There's a killer hamster on the loose.
                                (Gidon)
                                • G
                                  Gidon Yuval
                                  I thought I'd add another little tutorial on a technique that has saved me countless hours of time and which is great for tweeking furniture parts.
                                  I can't figure out how to insert a photo into the body of the text so I'll add them as attached files.
                                  Sorry.
                                  Anyway, this tutorial deals with moving in edit mode as opposed to scaling.
                                  (Gidon)
                                  • G
                                    Gidon Yuval
                                    Move vs. Scale - continued.
                                    Sorry about the clumsy way I posted this. Like I said, I can't figure out how to insert the pictures into the body of the text.
                                    Any way, I hope you find this usefull.
                                    (Gidon)
                                    • T
                                      titmas
                                      So now I can make just one component of a certain style of drawer/cabinet/box etc and use the move tool in edit mode to re-size it for the application at hand verses having to make many different sizes of the same component. Cool.
                                        SchreiberBike
                                        I'm moderately active over at SawmillCreek.org. A lot of excellent woodworkers there.
                                        Dave Richards showed me a much better way to do dovetails in SU and when I get a chance, I'll post a new tutorial.
                                        Woodworkers get very picky about their dovetails because they are hard to do well and because they are a very strong way of making a drawer or a case. They can be made with a router and a jig fairly easily, but handmade dovetails can be made to look very distinctive.
                                        Here are some really nice ones.
                                        The gentleman who made this particular joint is Mark Singer. He is architect and a woodworker and a bunch of other things. He made this piece for a very cool California-coast house which he designed, built furniture for and won an award for.
                                        • boofredlayB
                                          boofredlay
                                          Beautiful.
                                          • G
                                            Gidon Yuval
                                            That is a nice piece John.
                                            I stopped in at Sawmill Creek a few times a while ago. A very nice forum indeed. I should go back and visit.
                                            (Gidon)
