    [Tutorial > Modeling] How a Pro Builds a House in SU pt 1
    88 Posts 30 Posters 83.9k Views 30 Watching
    • jujuJ Offline
      juju
      Edson, what you're saying isn't quite making sense. The idea is to create a plane on which to "texture" the image plan and then trace it. It shouldn't be outside of the plane you created.
      • EdsonE Offline
        Edson
        juju, sorry about that. let me try again.
        i imported the plan and scaled it, ok? then i drew a larger rectangle close to it and copied the scaled plan onto it. since the rectangle was bigger than the image there ensued a tiling effect. in trying to get rid of the tiling (by using Texture>>Position) i threw the plan off scale. so i ended up with two plans side by side, one scaled correctly and the other slightly bigger while all the tutorial suggested was to have one scaled plan "textured" on the plane.
        i hope it makes some sense to you now.
        edson
        http://www.mahfuz.arq.br
          Edson, you can also try to scale the "larger" rectangle in a way (not with the scale tool) but selecting the edge on the side you notice the tiling and moving it (make sure to lock the axis of movement) to the edge of the original drawing.
          You can repeat this along the other axis. This way you end up with a rectangle which is perfectly covered with the image (and only one instance of it).
            Charlie__V
            krisidious,
            Many thanks for this,especially the scaling image part. :~)
            C
            • N Offline
              Nick W
              Kris,
              I've been walking through your process and it's very helpful and informative. I've learned a lot. Thanks for that Smile
              What is the big orange line in your template (see attached)? I can't seem to track it down or hide it. It is congruent with the green axis and is visible only on the positive side of the origin.
              http://www.nrwiesneski.com
              • jujuJ Offline
                juju
                The orange line is the direction where the sunlight is coming from. I use it on all my work to get accurate sun angles.
                • N Offline
                  Nick W
                  If that is the case, do you know how to hide it?
                  The orange line doesn't change when I change the position of the sun...
                  I imagine it's something very simple... thanks in advance for your instructive help
                  • EdsonE Offline
                    Edson
                    uncheck it and the sun's direction will not show.
                    • N Offline
                      Nick W
                      Thanks guys!
                      I just realized that the non-pro version probably doesn't have that feature, as I can't find it right now. Though I've seen it before, which confused me on several occasions (I have Pro at work, but not at home).
                      Peace!
                      nick
                      • KrisidiousK Offline
                        Krisidious
                        it's the North Arrow... and you should have it in your model info
                        go to the top of SketchUp...
                        go to Window
                        then to Model info
                        then click on Location
                        at the bottom it says Solar Orientation
                        uncheck Show in Model.
                        By: Kristoff Rand
                        • N Offline
                          Nick W
                          It's not there as far as I can see... (see attached)
                          maybe it's an issue with an older version? Version 6.0.515 is what I have installed here.
                          however, I know that I've seen the "location" options before. I'm assuming it was while working on my work computer, which led me to the conclusion that it's a Pro vs not-Pro difference.
                          • N Offline
                            Nick W
                            Here is the help text regarding setting location. This seems to confirm the lack of "Location" settings in the non-Pro version:
                            Specifying a Model's Location in the World
                            You can set the location of your model in all versions of SketchUp. However, the mechanism for setting location is different between SketchUp Pro and Google SketchUp (free).
                            Setting Location in SketchUp Pro
                            Use the Location panel in the Model Info dialog box (Window > Model Info > Location) to set the location for your model.
                            Caution - Do not use the Location panel in the Model Info dialog box to change the location of a model after importing the current view from Google Earth (using the Google Plugin). Using the Location panel to position models in Google Earth will likely result in an incorrectly located model.
                            Setting Location in Google SketchUp (free)
                            Load Google Earth and navigate to the location where you model will exist (the town is sufficient). Use SketchUp's Get Current View button to import the current view, as well as the location, from Google Earth. You can hide or delete the Google Earth snapshots if you want to work without them (such as when doing a shadow study).
                            • N Offline
                              Nick W
                              I'll change the setting when I get to work on Monday.
                              I noticed that the north line only shows up in the ISO view tab, not in the elevation or plan views. I'm guessing it's because Kris had set the views up with that feature enabled or disabled and SU still recognizes the setting, but doesn't give me the interface to change it.
                              Thanks again for this template, Kris! πŸ˜„
                                Krisidious
                                no problem Nick... and thanks for finding this little glitch... I'll remove it from the template and replace the file... again nice catch.
                                By: Kristoff Rand
                                • N Offline
                                  Nick W
                                  [light bulb over head] After thinking through what I wrote in the last post, I realized that since the setting is attached to the view I could simply regenerate the ISO view by resetting the camera position from a scene with the North line disabled.
                                    rhankc
                                    hello Kris,
                                    back to the template again, I have been using your template on most new starts, mostly because I think it works different than the stock start file; probably the most noticeable difference is the higher number of degree divisions (minutes?) on the protractor from the vs. 6 stock protractor. Is that protractor an entity from previous versions or is there a settings for fine tuning your system?
                                    Thanks for your time.
                                    Hank
                                    Hank
                                      Krisidious
                                      I bleive that's in the modelinfo dialog box...
                                      goto Window>Model Info>Units
                                      then angle units and Precision and snapping
                                      that should do it...
                                      By: Kristoff Rand
                                        rhankc
                                        you are right, and I go there daily, have not ever seen it... thanks
                                        Hank
                                        • syburnS Offline
                                          syburn
                                          hi all,
                                          im having probs with step 6. after making the rectangle i then cant see the jpg plan as its under neath. so no matter how much i right click i cant see the "Use image blah blah" option.
                                          Any ideas what im doing wrong?
                                          Report this post
                                          (syburn)
                                            Krisidious
                                            at this point it is best to right click on your image, and select use image as texture, then apply the texture to the rectangle... now continue tracing...
                                            By: Kristoff Rand
                                            • 1 / 5
