Kitchen/Dining/Coffee Area
Looks like a photo.
Ta mate, some items to look at again on reflection... Pardon the pun.
I was not happy with the glass settings I had, the jar for kitchen utensils not FFP. Better, I think.
very nice!
Ta mate, appreciated.
Different view.
I’m going to nitpick, as usual: the chrome on the kettle is a bit too mirror-like. What if you added a roughness map featuring scratches and fingerprints—a very dark map, just to keep the chrome look while making it appear a little less pristine?
Here it’s a bit too much... and the other one, arguably, not enough.
Nitpick away, it's how improvement happens, thank you, Sir.
Nice kitchen view.
Be careful with those 8 MB PNG files you’re sending... they take a while to load. -
Just for info : Rayscaper is a real Time render or an image takes some times for be created ? And How many time ?
Pretty quick, those renders are in the 30 - 40 minutes frame. The last is a bit over an hour. The car renders at 4000 by about 2400 are between 20 - 30 minutes on average but my pc, not so new or well specced.
Latest view. 6 4000s 4000 x 2230 913954 tri 1h 24m 13s GPU
Thanks for the info! So not for my latop more 13 years old!
with denoiser on and 4k resoltion you get a nice preview in less than a minute
So for 1 k ? No need 4 k resolution!
I preview on 1089.
If i want a rendered images i use the cool easy classic free one!
Mix quasi all 3D formats !
Can be used for commercial purposes!
https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx max 1920 x 800
if you want free 1920 x 1080 take the V 9
https://www.simlab-soft.com/3d-products/simlab-composer-old-download.aspx -
I've been searching for the best solution for Rayscaper for ages, and I can assure you that the denoiser works much better and is extremely effective at 4K, even at just 64 spp for previews. What really matters is the image resolution. A high resolution. (In French, we use the term "définition".)
In fact, that's exactly the resolution and sample count I use for animations. I then import the sequence of still images into my video editing software and export the final result in 1080p.
For a high-quality final result, use 1024 spp and, of course, a good image resolution—you can always scale it down later for publication.
Good stuff @mike-amos! It's featured here and here.
