    Kitchen/Dining/Coffee Area
    21 Posts 5 Posters 174 Views 5 Watching
      Ta mate, appreciated.
        Different view.
        • KrassK
          Krass
          I’m going to nitpick, as usual: the chrome on the kettle is a bit too mirror-like. What if you added a roughness map featuring scratches and fingerprints—a very dark map, just to keep the chrome look while making it appear a little less pristine?
          Here it’s a bit too much... and the other one, arguably, not enough.
          Krass
            Nitpick away, it's how improvement happens, thank you, Sir.
            • KrassK
              Krass
              Nice kitchen view.
              Be careful with those 8 MB PNG files you’re sending... they take a while to load.
              Krass
                Just for info : Rayscaper is a real Time render or an image takes some times for be created ? And How many time ?
                  Pretty quick, those renders are in the 30 - 40 minutes frame. The last is a bit over an hour. The car renders at 4000 by about 2400 are between 20 - 30 minutes on average but my pc, not so new or well specced.
                  Mike AmosM 1 Reply Last reply
                    Mike Amos @Mike Amos
                    Latest view. 6 4000s 4000 x 2230 913954 tri 1h 24m 13s GPU
                      Thanks for the info! So not for my latop more 13 years old! 🙂
                      • KrassK
                        Krass
                        with denoiser on and 4k resoltion you get a nice preview in less than a minute
                        Krass
                          So for 1 k ? No need 4 k resolution! 🙂
                            I preview on 1089.
                              If i want a rendered images i use the cool easy classic free one! 🙂 Mix quasi all 3D formats !
                              Can be used for commercial purposes!
                              https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx max 1920 x 800
                              if you want free 1920 x 1080 take the V 9 😉 https://www.simlab-soft.com/3d-products/simlab-composer-old-download.aspx
                              • KrassK
                                Krass
                                I've been searching for the best solution for Rayscaper for ages, and I can assure you that the denoiser works much better and is extremely effective at 4K, even at just 64 spp for previews. What really matters is the image resolution. A high resolution. (In French, we use the term "définition".)
                                In fact, that's exactly the resolution and sample count I use for animations. I then import the sequence of still images into my video editing software and export the final result in 1080p.
                                Krass
                                • KrassK
                                  Krass
                                  For a high-quality final result, use 1024 spp and, of course, a good image resolution—you can always scale it down later for publication.
                                  Krass
                                  • pixelcruncherP
                                    Good stuff @mike-amos! It's featured here and here.
