    Kitchen/Dining/Coffee Area
    21 Posts 5 Posters 174 Views 5 Watching
      Pretty quick, those renders are in the 30 - 40 minutes frame. The last is a bit over an hour. The car renders at 4000 by about 2400 are between 20 - 30 minutes on average but my pc, not so new or well specced.
      Mike AmosM 1 Reply Last reply
        Mike Amos @Mike Amos
        Latest view. 6 4000s 4000 x 2230 913954 tri 1h 24m 13s GPU
          Thanks for the info! So not for my latop more 13 years old! 🙂
          • KrassK
            Krass
            with denoiser on and 4k resoltion you get a nice preview in less than a minute
            Krass
              So for 1 k ? No need 4 k resolution! 🙂
                I preview on 1089.
                  If i want a rendered images i use the cool easy classic free one! 🙂 Mix quasi all 3D formats !
                  Can be used for commercial purposes!
                  https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx max 1920 x 800
                  if you want free 1920 x 1080 take the V 9 😉 https://www.simlab-soft.com/3d-products/simlab-composer-old-download.aspx
                  • KrassK
                    Krass
                    I've been searching for the best solution for Rayscaper for ages, and I can assure you that the denoiser works much better and is extremely effective at 4K, even at just 64 spp for previews. What really matters is the image resolution. A high resolution. (In French, we use the term "définition".)
                    In fact, that's exactly the resolution and sample count I use for animations. I then import the sequence of still images into my video editing software and export the final result in 1080p.
                    Krass
                    • KrassK
                      Krass
                      For a high-quality final result, use 1024 spp and, of course, a good image resolution—you can always scale it down later for publication.
                      Krass
                      • pixelcruncherP
                        Good stuff @mike-amos! It's featured here and here.
                        • 2 / 2
