    Modlumi - Easy 3D modelling
    392 Posts 9 Posters 60.2k Views 9 Watching
      Bug : crossing arcs extruded can't be Extruded ! (multiple)
      Or very difficult to find the good start!
      buga.zip
      alt text
      alt text
        Requests πŸ™‚
        PushPull + CTRL on the fly!
        PushPull with Direction ( we have yet Follow me or Rail Sweep but)
        Edit Points
        SubDivision
        Have happy coding! πŸ™‚
        alt text
        alt text
          alt text
          alt text
            Request ! AlignSelected Objects (there are some cool selection similar functions but...
            • pixelcruncherP
              Modlumi 0.27 is out!
              This release is about getting started and getting around. Modlumi now opens on a welcome screen with two finished models to explore, you can find any command by typing its name, and big models move a lot faster. Several fixes come straight from the models you posted here, so thank you for those.
              Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.26 on Windows, it will offer you the update. The Mac build of 0.27 will follow later.
              Start from the welcome screen
              When Modlumi starts, it offers a finished birdhouse and bookshelf to explore, your own files to open or import, and the units for a new model. A sample opens as an untitled copy, so you can pull it apart freely. If you're new, Build your first model opens a short hands-on lesson. Help β†’ Welcome Screen shows the screen again, and you can turn it off at startup.
              The interface
              A tour of the Modlumi window, from the menus and toolbar to panels and the status bar.
              Modlumi Docs (modlumi.com)
              Your first model
              A ten-minute hands-on lesson that builds a row of stools, using drawing, extruding, components, copies, materials and saving.
              Find any command by typing
              Press Shift+S (as in SketchUp) or Ctrl+K, or choose Help β†’ Search Commands, and type what you want to do. Each result shows where the command lives in the menus and its shortcut. Typing mirror finds Flip. Extension commands are listed too, and the commands you used last come first.
              Keyboard shortcuts
              Every keyboard shortcut in Modlumi.
              SketchUp text and dimensions come along
              Leader text, screen text and linear dimensions in your SketchUp files now import with their position, text, tag and hidden state. If a file holds annotations Modlumi can't keep, it tells you and imports the rest.
              And also
              • Large models orbit, edit and undo faster. A detailed house model draws in less than half the time per frame, an edit or undo inside it rebuilds only the part that changed, and hovering over dense geometry finds snap points several times sooner.
              Fixes
              • @pilou, both of your Extrude bugs are fixed. The side of your stepped block now extrudes as far as you like, and the wall faces where your two crossing arcs meet extrude too.
              • @ntxdave, section planes now fill only solid shapes. Your box made of single faces shows its cut lines and you can see inside, as in SketchUp.
              • @Krass, your buffet model imports now. One face had a hole shaped like a figure 8, which stopped the whole import. Thanks @Mike-Amos for confirming it.
              • New models start in the units you chose, in every open window. A window that was already open when you chose Use for New Models in another one kept using the old units.
              • Long bug reports are no longer lost. Help β†’ Report a Bug accepted descriptions longer than the site takes and then dropped them silently. The form now counts characters as you near the limit.
              All the details are in the release notes: https://modlumi.com/docs/release-notes/
              Thanks again for all the feedback. As always, tell me what breaks and what you'd like next. Help β†’ Report a Bug can attach your model.
                Very cool Bravo!
                BUT hight request priority : PushPull + CTRL for separate (or not) the "copy move" of the PushPull ! (and multiple of course)
                It's the more important thing when you modelise! πŸ™‚ Without we are so deprived! πŸ™‚
                All your challengers make it so... πŸ™‚
                  Modlumi online is 0.28 ??
                  And here 0.27 ! πŸ™‚
                    About the Sweep 2 Rails : we can't Click again on the Rail 1 as Rail 2 for make a Sweep One rail ? πŸ˜‰
                    alt text
                    alt text
                    alt text
                      Sorry always bug! πŸ™‚
                      Can't All Push Pull!
                      bug128.zip
                      But found it! It's because one or more faces slap on another one , generaly at a crossing!
                      So this bug can't be solved! Just make one by one the fault faces! πŸ™‚
                      • ntxdaveN
                        ntxdave
                        I wish I could understand/learn how you create stuff like this. Not necessarily the renders, basically the models itself (and you are doing this in Modlumi).
                        Press F1...thank me later
                          @ntxdave
                          Make any Object : Make a Group
                          Select this Group
                          Copy Move it (M + CTRL)
                          Type / 5 = 6 Objects (Original + 5 between original and second) or Type * 5 = 6 objects( original + behind distance original and second)
                          Type 50% then Enter = Your 6 objects a decrease Size from the first Original to last
                          Select All : make a Group
                          etc... exactely the same with Rotate! (Q)
                          It's a sort of Fractal process! πŸ™‚
                          All was made with 5 as number of /, and 50% as reduce size generation !
                          With training you will make that in seconds!
                          For Size you must take an Handle(s) first!
                          Size was not use in this Gif : Only Move Copy and Rot!
                          Don't forget to make a Group or a Component after a finished command!
                          The Last line for example is: Make a group, Make a Big Move with Ctrl then type /5 then type 50% Enter πŸ™‚
                          alt text
                            Search inside Modlumi a good view then make Snap Shot or save image inside ModLum
                            you can hide the axes inside ModLumi or ask the Ai to make it! πŸ™‚
                            alt text
                            Ask birds in free Vizcom
                            alt text
                            Variations Vizcom...export image
                            alt text
                            then Drag & Drop inside Gemin section Image πŸ™‚ Prompt was : make a tapestry from this image
                            Truely a game's boy as I said previouly! πŸ™‚
                            alt text
                            etc...
                            Reply Quote 2
                            • 16
                            • 17
                            • 18
                            • 19
                            • 20
                            • 20 / 20
