    2.3k Posts 516 Posters 2.9m Views 521 Watching
      TIG Moderator @comlife7
      @comlife7 said:
      rbz파일을 인스톨해도 아이콘이 생기지 않음. 툴바에도 없음 스케치업 v2022사용중. 정품 사용자이고 라이센스도 가지고 있음
      No icon appears after installing the .rbz file, and it doesn't show up on the toolbar either. I am using SketchUp v2022. I am a legitimate user and hold a valid license.
      Which exact extension are you referring to ?
      If it's a Fredo6 extension, then look under the Tools menu.
      Remember that you need LibFredo6 installed as well - because this supports Fredoo6's extensions.
      And you need the latest version of the SketchUcation tools installed, as that manages the licenses.
      After installing these extensions restart SketchUp to sync everything...
      • C
        clr03 Newcomers
        When I want to use curviloft it doesn't work because it says that my liscense has expired but I have never used or installed curviloft before. I don't want to pay for something that has a 30 day free trial and I never had my 30 days. In the picture is what happens when I want to try and use this extension.
          Are you using the latest version of both Curviloft and Libfredo?
          That may be the reason you are prompted. Otherwise you may have simply forgotten you installed at some point.
          • F
            fmokhtar @fredo6
            @fredo6
            Hi Fredo,
            Thank you for your previous reply.
            Before writing back to you, I followed the instructions and tried to release/reset the licenses in order to identify which ones were still linked to my broken computer configuration.
            Most of the relevant activations were made in 2025, when I bought ThruPaint and installed SketchUp 2025. The activation dates shown in the license store match the period when I installed everything on my previous system configuration.
            The issue is that some licenses now appear to be linked to an obsolete hardware/OS configuration. I had to reinstall the operating system and all programs from scratch on a new hard drive, so the hardware ID seems to have changed.
            As you can see in the screenshot pasted below, the listed seats still refer to the old configuration, and I do not see any option available to release those seats myself from the license store.
            Would you be able to help me with this, or advise me who I should contact at SketchUcation to have these old seats released/reset?
            I am always grateful for the excellent work you do.
            Best regards,
            Farid Mokhtar Noriega
            • X
              xmedia2018
              "Hello, I purchased the license for the Fredo6 Animator plugin on July 29, 2026, and it has not been activated yet. I made my payment through PayPal using my Visa debit card. What do I need to do?"
                dduschenes
                HI there, I purchased a license for RoundCorner, but whenever I try to activate it, it doesn´t show in the licenses files box - as if I didn´t have it. How should I proceed?
                  Rich O Brien Moderator @dduschenes
                  You are probably running outdated extensions.
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                  Send us an email on support@sketchucation.com
                  • V
                    verticalgreen Newcomers
                    Ich habe eine dauerlizens für JointPushPull kann sie aber nicht in sketchup aktivieren.
                      Please explain clearly where you are having issues.
                      A few questions first...
                      • Do you have the appropriate license file saved onto your computer.
                      • Have you tried validating it in the Tools submenu for that extension ?
                      • On trying what are the error messages [if any].
                      • What does the Extensions > SketchUcation entry for SCFlicense management items report ?
                      Bitte erläutern Sie genau, wobei Probleme auftreten.
                      Zunächst ein paar Fragen:
                      • Haben Sie die entsprechende Lizenzdatei auf Ihrem Computer gespeichert?
                      • Haben Sie versucht, sie im Untermenü „Tools“ (Werkzeuge) für diese Erweiterung zu validieren?
                      • Welche Fehlermeldungen erscheinen dabei (falls vorhanden)?
                      • Was wird unter „Extensions“ (Erweiterungen) > „SketchUcation“ im Bereich der SCF-Lizenzverwaltung angezeigt?
                        sumin36 Newcomers
                        I purchased a ClothWork license, but the pin movement feature is not working. Why?
                        Dave RD 1 Reply Last reply
                          sumin36 Newcomers
                          This post is deleted!
                            Dave R @sumin36
                            @sumin36 What version of SketchUp? What operating system? (Please complete your forum profile with that information.) Do you have the current version of the Sketchucation Tool installed? That is required for license management. Does the extension show that you've activated the license?
                            • 112
                            • 113
                            • 114
                            • 115
                            • 116
                            • 116 / 116
