    Modlumi - Easy 3D modelling
    408 Posts 9 Posters 71.1k Views 9 Watching
    • pixelcruncherP
      @Krass, could you send me the Mercedes model from your videos? Attaching the .skp here is fine, or send it through Help β€Ί Send Feedback… in the app.
      I can't reproduce the edge artifacts on Linux with our own car model, and the desktop app on Windows draws through Direct3D, which handles one edge depth offset differently. With your model I can test a fix before the next desktop build. If you can, also mention your graphics card.
      KrassK 1 Reply Last reply
        @pixelcruncher
        Combine 2 curvated solid perfect! Ok
        Right Click on them / Erase ! OK perfect ! But why we can't do that also directly inside the OutLiner ???
        If the exe on desktop version is only 5 megas i wiil download it! πŸ™‚
        Like this i will can test some script by a friend, alas not by me because scripting is out from me now! πŸ™‚
        (except if i use Ai ... but that will be another story! πŸ™‚
        modeling bugs first! πŸ™‚
        1 Reply Last reply β™₯
          Excellent the Desktop version installed is 15 megas so I have it also! πŸ™‚
          And i see that is the same number 0.13
          That will be always the same ?
          • pixelcruncherP
            pixelcruncher Extension Creator @pilou
            @pilou Okay 15MB, it was heavily zipped then πŸ™‚ - I will try to keep the file size under control, and also ship it as a single exe file. But it might grow over time.
              Yes but it's reasonable for old Latop! :=)
              Anyway that works fine! πŸ™‚
              1 Reply Last reply πŸ‘
                Silly question but seems yes !
                We can lunch several versions in the same time! πŸ™‚ For my test only 2 !
                But the Ctrl + C, Ctrl + V seems not working betweem them !
                • pixelcruncherP
                  Yeah πŸ™‚ That's a good idea. Do you want it to copy the selected geometry?
                    Yes on some programs you can make a simple Copy Paste! πŸ™‚
                    I think only selected geometry will be first the more simple! πŸ™‚
                    Like this you can make some test in the same time! πŸ™‚ (depending of course of the free memory available) πŸ™‚
                    A Drag & Drop will be more comfortable! But a shortCut is cool too!
                    A Request : Right Click for recall the previous function... maybe yes existing in some ?
                    • KrassK
                      Krass @pixelcruncher
                      here is the car
                      @pixelcruncher C63+AMG+Coupe+W204+(1).skp
                      Krass
                      • KrassK
                        Krass @pilou
                        yes I use it everytime in the old SU
                        Krass
                        • pixelcruncherP
                          Modlumi 0.14 is out
                          Hi all,
                          Modlumi 0.14 is out, in the browser at modlumi.com and for Windows: modlumi.com/download/latest/windows
                          What's new
                          • The Windows app now tells you when a new version is out. It checks when it starts and once a day, and shows a small notice where you can download the update, read what's new, skip that version, or close it. Help β†’ Check for Updates… checks right away, and Help β†’ Check for Updates Automatically turns the checks off. The check sends no ID and nothing about your models.
                          • Choose the units new models start with. In Model Settings, Use for New Models keeps the current units, precision and suffix. Modlumi then starts in them, as does File β†’ New. Saved and imported models keep their own units. Thanks to the browser user who asked for this through the feedback form!
                          Fixes
                          • Rectangle and Extrude previews stay in place while you type a dimension. The typed value takes effect on Enter or a click.
                          @pilou, about the version number: it goes up with each release, and this one is 0.14. From now on the desktop app tells you when a newer one is out. 0.13 doesn't check yet, so please download 0.14 from the site this one time.
                          Full release notes: modlumi.com/docs/release-notes
                          Cheers,
                          Thomas
                            Not yet on the 0.14 the erase group on the Outliner! πŸ™‚
                            Number version of the "Installer" file is always crypted !:) modlumi-9dd7225-Setup-x64
                            0.14 on the desktop installed! πŸ™‚
                              Request:
                              does it possible to have the segment of the Arc Circle in the color of the axis after the first click ?
                              When it's snaped on it of course!
                              Now we have just the box message "On Red Axis"
                                Request
                                Have a Snap 3D when you Draw a Circle, a Polygon !
                                Seems Rectangle and Arc Circle has yet that!
                                Else it's a nightmare for make after a rotation etc...
                                  There is something with the display of Guide Lines! ?
                                  Create Guide Point fails..
                                  Create normal Guide lines is difficult!
                                  this function seems have regressed!
                                    Request
                                    Editing Points (geometry)
                                    Subdivide a line
                                    Push Pull a Line (s) like an extrude πŸ™‚
                                    Subdivision of a solid volume
                                    Multiple selection for multiple edition...
                                      Bug about Sweep ? 0.14 File .modl linked!
                                      bug_0.14.zip
                                        Request
                                        Sweep between 2 profils, 2 rails
                                        Or more simple first : Sweep with % πŸ™‚ (like the Move Rotate existing)
                                          Bug ? No Snap 3D for make the PushPull at the middle of a vertical side segment for example ?
                                          Put a Point Guide or a Line help not more!
                                            Request
                                            When you have made a Push Pull on a face said 2 units
                                            You click on another face = same Push Pull ! πŸ™‚
                                            • 20
                                            • 21
                                            • 7 / 21
