    Modlumi - Easy 3D modelling
    337 Posts 9 Posters 37.2k Views 8 Watching
      Many thanks for the infos ! ๐Ÿ™‚
        You said 5 Megas for the Installer yes but the complete program installed is how Big ( 500 Meg ...? )
          Request
          In the Move, Rotate, Size + CTRL + * / % ...+ a "randomize" for give some fun variations in the result?
          Not yet on the volume itself... but... ๐Ÿ™‚
          • pixelcruncherP
            pixelcruncher Extension Creator @pilou
            @pilou still about 5 meg, itโ€™s a small program. It doesnโ€™t download a ton of stuff from the web.
            • pixelcruncherP
              Well it doesnโ€™t download anything for the installation. Its just one exe.
              • ntxdaveN
                ntxdave
                Another of my silly questions: How do you draw/show/hide guides?
                Still another one: I want to draw a rectangle with each of the 4 corners rounded (same size). What is the best way to do that. In SketchUp, when you do that, you can double click in each of the other corners and it will repeat the first corner.
                Press F1...thank me later
                • pixelcruncherP
                  Modlumi 0.13 is out: fixes for your latest reports
                  Modlumi 0.13 is live at https://modlumi.com/app. Thanks @pilou for the reports and the files, they made these easy to track down.
                  Combine Solids through curves
                  Union, Subtract, Intersect, Trim, Split and Outer Shell now work when the cut goes through an arc or a curve, like the two half-round volumes in your 2volumes file. Before, they all failed with "the result would not be a closed solid".
                  Combine Solids through a curve, before and after
                  Redrawn sides stay whole
                  Erasing a line drawn across a rectangle together with the side it touched, then drawing that side again, now gives one edge. The rectangle is back to four sides.
                  Redrawn side, before and after
                  Eraser on groups and components
                  Pointing the Eraser at an edge or guide inside a closed group or component now erases the whole object. To erase a single guide or edge, open the group first. That's why the guides in your 2pp file looked impossible to delete: they were inside groups.
                  Eraser on a group, before and after
                  @Krass, I'm still looking at the edge artifacts you saw on the desktop version.
                  Full release notes, now also listing 0.11 and 0.12: https://modlumi.com/docs/release-notes/
                  As always, bug reports and ideas are welcome here or through the feedback button in the app.
                    @ntxdave
                    Just 2 things to know for draw Help Lines guide (for the moment!
                    You must click (select) a segment yet existing for a line .
                    So Draw a line
                    Select it Press T , Click the midle of the line for exemple, and drag , type 5 as 5 units you must ha a line drawn at 5 units!
                    For Point guide it's the same but your first click must at a corrner of 2 segments!
                    • pixelcruncherP
                      @Krass, could you send me the Mercedes model from your videos? Attaching the .skp here is fine, or send it through Help โ€บ Send Feedbackโ€ฆ in the app.
                      I can't reproduce the edge artifacts on Linux with our own car model, and the desktop app on Windows draws through Direct3D, which handles one edge depth offset differently. With your model I can test a fix before the next desktop build. If you can, also mention your graphics card.
                      KrassK 1 Reply Last reply
                        @pixelcruncher
                        Combine 2 curvated solid perfect! Ok
                        Right Click on them / Erase ! OK perfect ! But why we can't do that also directly inside the OutLiner ???
                        If the exe on desktop version is only 5 megas i wiil download it! ๐Ÿ™‚
                        Like this i will can test some script by a friend, alas not by me because scripting is out from me now! ๐Ÿ™‚
                        (except if i use Ai ... but that will be another story! ๐Ÿ™‚
                        modeling bugs first! ๐Ÿ™‚
                        1 Reply Last reply โ™ฅ
                          Excellent the Desktop version installed is 15 megas so I have it also! ๐Ÿ™‚
                          And i see that is the same number 0.13
                          That will be always the same ?
                          • pixelcruncherP
                            @pilou Okay 15MB, it was heavily zipped then ๐Ÿ™‚ - I will try to keep the file size under control, and also ship it as a single exe file. But it might grow over time.
                              Yes but it's reasonable for old Latop! :=)
                              Anyway that works fine! ๐Ÿ™‚
                              1 Reply Last reply ๐Ÿ‘
                                Silly question but seems yes !
                                We can lunch several versions in the same time! ๐Ÿ™‚ For my test only 2 !
                                But the Ctrl + C, Ctrl + V seems not working betweem them !
                                • pixelcruncherP
                                  Yeah ๐Ÿ™‚ That's a good idea. Do you want it to copy the selected geometry?
                                    Yes on some programs you can make a simple Copy Paste! ๐Ÿ™‚
                                    I think only selected geometry will be first the more simple! ๐Ÿ™‚
                                    Like this you can make some test in the same time! ๐Ÿ™‚ (depending of course of the free memory available) ๐Ÿ™‚
                                    A Drag & Drop will be more comfortable! But a shortCut is cool too!
                                    A Request : Right Click for recall the previous function... maybe yes existing in some ?
                                    • KrassK
                                      Krass @pixelcruncher
                                      here is the car
                                      @pixelcruncher C63+AMG+Coupe+W204+(1).skp
                                      Krass
                                      • KrassK
                                        Krass @pilou
                                        yes I use it everytime in the old SU
                                        Krass
                                        • pixelcruncherP
                                          Modlumi 0.14 is out
                                          Hi all,
                                          Modlumi 0.14 is out, in the browser at modlumi.com and for Windows: modlumi.com/download/latest/windows
                                          What's new
                                          • The Windows app now tells you when a new version is out. It checks when it starts and once a day, and shows a small notice where you can download the update, read what's new, skip that version, or close it. Help โ†’ Check for Updatesโ€ฆ checks right away, and Help โ†’ Check for Updates Automatically turns the checks off. The check sends no ID and nothing about your models.
                                          • Choose the units new models start with. In Model Settings, Use for New Models keeps the current units, precision and suffix. Modlumi then starts in them, as does File โ†’ New. Saved and imported models keep their own units. Thanks to the browser user who asked for this through the feedback form!
                                          Fixes
                                          • Rectangle and Extrude previews stay in place while you type a dimension. The typed value takes effect on Enter or a click.
                                          @pilou, about the version number: it goes up with each release, and this one is 0.14. From now on the desktop app tells you when a newer one is out. 0.13 doesn't check yet, so please download 0.14 from the site this one time.
                                          Full release notes: modlumi.com/docs/release-notes
                                          Cheers,
                                          Thomas
                                            Not yet on the 0.14 the erase group on the Outliner! ๐Ÿ™‚
                                            Number version of the "Installer" file is always crypted !:) modlumi-9dd7225-Setup-x64
                                            0.14 on the desktop installed! ๐Ÿ™‚
                                            • 16
                                            • 17
                                            • 7 / 17
