    Honda S800
    16 Posts 7 Posters 874 Views 7 Watching
      While I fuss with inspiration for textures I have brought this model out of retirement to render with the latest build of Rayscaper.
      I have Sketchup 2024 until I can fix up the inability to run Sketchup 2026 but I have to wait and see what goes on next.
      Reply Quote 2
      • pbacotP
        Wow! Sweet!
        Reply Quote 2
          Ta mate, Rayscaper does the magic.
            Front 3/4 view.
            Reply Quote 3
            • pixelcruncherP
              Very nice car & render!
                Ta folks, not happy with the red, not deep enough IMHO.
                Sorry folks, wrong image
                Mike AmosM 1 Reply Last reply
                Reply Quote 2
                  Mike Amos @Mike Amos
                  Trying to find automotive ies files, I will pass on what I find.
                    Reply Quote 2
                      Rayscaper doesn't support IES yet.
                        Ta Rich, not so bad I have found zero then..........
                          Build 100, tested a bit tonight. Loving this folks, bleep amazing imho.
                          1 Reply Last reply πŸ‘
                          • tuna1957T
                            tuna1957
                            You’re absolutely correct. An amazing result. Job well done. πŸ‘
                            • KrassK
                              Krass
                              Hello, Mike,
                              Very nice
                              did you use the new car painting preset? On your previous renders it seems you applied a Sheen effect
                              Krass
                              • pixelcruncherP
                                Super nice result, I see the flakes so I assume you are using the new car paint material?
                                • majidM
                                  majid
                                  Super!
                                    Thanks folks, the credit belongs to Thomas.
                                    The settings Used up until build 100 was essentially smoothing the finish and adding a bit of metalic job done. The flake effect in this car paint setting has a high initial setting which made the surface appear as though infected with Eczema but scrolling the value right down is closer to reality and quick to apply
                                    Barely scratched the surface and looking forward to redo's of a bunch like the hotrods and the Dusenberg ST..
