    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      Version 4.4.6 - 04.11.2026
      • Added a "Style 6" (Schlage - Camelot) to the built-in door hardware options.
      • Configured the "Ctrl" hot key within the draw door tool with additional justification options (x-dir).
      Tutorial 84 - Positioning Doors (7:19 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 4.4.6b - 04.12.2026
        • Added custom door positioning offsets into the Door tab of the Global Settings.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 4.4.7 - 04.16.2026
          • Fixed a bug with custom door positioning for metric templates.
          • Enabled "profile cutting" of posts for vertical handrails.
          • Fixed a bug with the bottom trimming algorithm for balusters
          design.medeek.com
          • medeekM Offline
            medeek
            Version 4.4.8 - 04.18.2026
            • Enabled custom components as posts for vertical handrails
            design.medeek.com
            • medeekM Offline
              medeek
              Tutorial 85 - Profile Cut Newel Posts (9:04 min.)
              design.medeek.com
              • medeekM Offline
                medeek
                Version 4.4.8b - 04.18.2026
                • Enabled custom components as balusters for vertical and OTP handrails.
                Th sub-folder structure is the same as for newel posts, so Tutorial #85 is applicable to balusters as well.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 4.4.8c - 04.19.2026
                  • Fixed a minor typo in the stair module.
                  • Added a ornamental iron baluster into the baluster component library.
                  The limitations of profile cutting balusters can be overcome by using a predefined component instead, which allows for much more intricate baluster geometries.
                  However as I have been researching various baluster layouts I've noticed that with iron balusters usually more than one baluster style is utilized. The typical scenario is two or three different baluster geometries are alternated along the run of stairs. I will need to give this some more thought.
                  Stairs can be a "rabbit hole".
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 4.4.9 - 04.19.2026
                    • Enabled a secondary custom profile/component parameter for balusters.
                    • Added additional ornamental iron balusters into the baluster component library.
                    I think I've beat this horse to death. Hopefully with this added option we can configure most of the common baluster layouts, however there will always be a few that will be beyond the scope of the plugin (ie. three or more baluster types in various repeating patterns).
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 4.5.0 - 04.20.2026
                      • Enabled custom components as posts for OTP handrails.
                      • Enabled "profile cutting" of posts for OTP handrails.
                      • Modified the bottom trimming algorithm for balusters to better accommodate complex baluster components.
                      • Added one additional ornamental iron baluster into the baluster component library.
                      • Added one OTP newel post into the newel post component library: LJ4270_43
                      I will readily admit configuring OTP handrails with their associated posts and fittings is a bit tricky, adjusting the various offsets takes a few iterations to really hone things in.
                      I appreciate everyone who has pushed me to flesh out the newel post and baluster capabilities. I feel like the stair module is a bit complicated now and perhaps even a bit clunky with so many options and variables but at the same time it is much more configurable and flexible and can I say with these new capabilities more powerful.
                      Obviously it would be optimal if I could spend some serious time and create many of the standard balusters and newel posts found in LJ Smithโ€™s general catalog so that the user would have a bevy of options to choose from without having to exert additional effort in creating their own. However, such an undertaking could easily consume two to three weeks and my development time is probably better spent elsewhere at the moment.
                      design.medeek.com
                      L 1 Reply Last reply ๐Ÿ‘ Reply Quote 1
                        Luke147ll Newcomers @medeek
                        @medeek keep up the good work.. I've designed and built miles of walls using the wall plugin! 8b25ee20-6923-42df-b851-ab42360c29cc-image.jpeg
                        medeekM 1 Reply Last reply ๐Ÿ‘ Reply Quote 0
                        • medeekM Offline
                          medeek @Luke147ll
                          @Luke147ll
                          Wow, now I'm curious. Please post more as this build progresses. I am especially curious to know how it all comes together for you and what if any issues arose. Also if you don't mind and are comfortable with it, I would love for you to post a screenshot or two of your model.
                          This is very cool stuff, to see the plugin translating into real world wood. Impressive!
                          design.medeek.com
                            @medeek
                            I've got a couple great models that are all framed out. I will put together a gallery and post it tonight after work. I used to prefab wall panels and created all the shop drawings using your plugin.. I got too busy with custom residential and sold the equipment. Now I use the plugin to create a build ready digital twin. I will post some images in the gallery and call it something like medeek in action.
                            • medeekM Offline
                              medeek
                              Well... I thought I was done with balusters and newel posts, but I'm not quite there yet.
                              The problem is that with metal or iron balusters they are often installed with a shoe as shown below:
                              My current algorithm installs balusters just like they are installed in real life:
                              First I trim the top of the original baluster component/group and then I have to trim them individually for each of their bottoms because the balusters may intersect the treads at different heights hence their heights/lengths will be different.
                              Because of this a predefined shoe positioned at the base of the baluster component may work for one location (ie. no trimming required) but then it will be removed in subsequent baluster locations.
                              What this means in practice is that a shoe (if that option were enabled) needs to be a completely separate group/component just as it is in real life. My algorithm needs to position it individually in the Z-dir just as I trim each baluster bottom individually.
                              Arguably, there is a lot going on with stairs, the guys that install these must be real craftsmen, I certainly take my hat off to them.
                              design.medeek.com
                                Luke147ll Newcomers
                                Medeek Walls in action
                                Hey Nathaniel, Here is how I've been using the plugin for custom residential home building.
                                This is a project I'm working on.. it's called the sports barn its an entertainment complex with a golf sim, putting green and basketball court. On this project the architect, engineer and MEP all worked in Revit.
                                On this one I took the geometry from all the different consultants along with the CAD files for the floor plans and sections to build out the wall framing. I typically start with the 2D files and trace out the outline of the structure with the Medeek wall tool. I've developed my own toolset to treat the different models sort of like GitHub. I don't need all of the redundant geometry from 3 or 4 models so I commit the necessary components from each one to my main model.. Like steel from Struct and HVAC from the Mech.
                                I use a combination of sections, benchmark elevations and my out math the set all of my plate heights. I then use the center lines for all the ROs in the 2D CAD file and cut in the window and door openings. I usually work in phases and don't worry about perfect ROs on the first pass.
                                When I have the overall structure framed up, I start to overlay all of the models I need to flush out. I compare the structural vs architectural ( i frame off struct) this usually goes a few rounds to hammer out the discrepancies.
                                Once all of the issues are flushed out I move to structural connections. Different projects require different levels of detail.. This was all stick framed on site so the blocking, corners and plate connections weren't very important. The main purpose of framing out this model was the lumber order. In this case it was quicker and cheaper to digitally build it and simply count the studs.
                                This job was a little different.. All the walls were prefabricated and all of the timbers were done in house.. This level of detail means everything needs to be flushed out in the model. The steel needs to be modeled to the fasteners and the need to be perfect down to the blocking for toilet paper holders.
                                This house was designed in auto cad so there wasn't any outside geometry to start with. I lined up all the sections and details in place and modeled the foundation. The truss company did produce 3d shop drawing for this project that I was able to import and review.
                                To build the walls I produce a section cut of the walls to show stud orientation and interior partitions( they can be hard to see in an elevation). The shops for the walls can be a bit tedious but for the most part are produced in layout.
                                Let me know if you have any questions or suggestions.. I've been using this system for about 7 years now.. I've got what architects call a raised in a barn methodology for the way I do things but it seems to work.
                                medeekM 1 Reply Last reply ๐Ÿ‘ Reply Quote 1
                                • medeekM Offline
                                  medeek
                                  Version 4.5.1 - 04.22.2026
                                  • Enabled custom components as baluster shoes for vertical and OTP handrails.
                                  • Added the following (L.J. Smith) baluster shoes into the baluster shoe component library: LI_ALFSH01, LI_ALR010, LI_ALRD201, LI_ALSQ301, LI_ALSQPL1, LI_PROCOL.
                                  I took the time today to carefully model a few of these baluster shoes since they are fairly simple geometry and it is always fun to get my hands dirty with some actual modeling and take a small break from the code.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek @Luke147ll
                                    @Luke147ll
                                    Wow, very impressive work. The level of detail in your models is something else.
                                    It looks like you have a very diverse workflow, using not just SketchUp but various other design softwares.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      design.medeek.com
                                        That's awesome! 90% off for those in education. $33 instead of $330 is a huge discount.
                                        • medeekM Offline
                                          medeek
                                          Version 4.5.3 - 05.21.2026
                                          • Added an inset option for in-wall columns.
                                          • Added preview thumbnails into the railing draw and edit menus.
                                          • Added a toggle option for the auto-rotation of corner posts within the draw and edit menus of the railing module.
                                          [Uploaded Images Lost to Server Upgrade Issue May 15th]
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 4.5.4 - 05.22.2026
                                            • Added an option for a top and a bottom baluster shoe.
                                            • The top baluster shoe can be controlled with the additional "shoe height" parameter, which in turn allows for baluster collars.
                                            • Added the shoerail offset parameter to vertically offset the shoerail.
                                            • Fixed a bug in the railing edit menu with metric units.
                                            design.medeek.com
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 77 / 80
