    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • gullfoG
      gullfo
      very cool! thanks!
      Glenn
      http://www.runnel.com
      • medeekM
        medeek
        Just so everyone is aware, they should update to this latest release: SU 2026.1.2 because of specific bug fix for the SpaceMouse issue as documented here:
        • (Windows) Fixed a crash related to DX12 rendering triggered by orbiting or zooming while using a 3Dconnexion SpaceMouse, notably after using extensions such as Medeek Wall.
        (help.sketchup.com)
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • gullfoG
          gullfo
          i find SU 2026 unusable do the folder setting restrictions which make my component and material collections virtually unreadable from all the duplication and then consider that if i do modify the folders, the installer simply reverts. so i'm on 2025 until they can fix it. thankfully i don't use a SpaceMouse...
          Glenn
          • medeekM
            medeek
            Version 4.4.4 - 04.02.2026
            • Enabled the following methods within the Medeek Wall API: wall_draw_perim
            • Enabled "profile cutting" of balusters for vertical and OTP handrails.
            I'm not sure why I didn't realize I could do this before but I woke up yesterday and I realized that a simple profile could be revolved into the cutting solid (like putting a piece of square stock on a lathe) and then boolean subtracted from the square baluster as shown to give a typical "turned" baluster.
            design.medeek.com
            • medeekM
              medeek
              Version 4.4.5 - 04.05.2026
              • Fixed a bug with the profile cutting of balusters.
              • Enabled a new boolean subtraction algorithm for profile cutting of balusters.
              design.medeek.com
              • medeekM
                medeek
                Version 4.4.5b - 04.08.2026
                • Added a tooltip for the Corner Treatment option into the Global Settings, Draw and Edit Wall Menus.
                I didn't realize that the term "California Corner" was not well known in the industry. To that end I've added a tooltip for "Corner Treatment" which shows a typical (2x6) California Corner and a U-Corner. Hopefully this further clarifies this parameter for some users who are not familiar with this term. The other corner treatments seem fairly self explanatory.
                design.medeek.com
                • medeekM
                  medeek
                  I've been meaning to add in a "Style 6" door hardware option for quite some time. Basically something for your entrance door, and I haven't had a good option for this until now. This low poly entrance hardware and deadbolt (handleset) is loosely modeled after the Camelot series by Schlage. I will include this in the next roll out:
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 4.4.6 - 04.11.2026
                    • Added a "Style 6" (Schlage - Camelot) to the built-in door hardware options.
                    • Configured the "Ctrl" hot key within the draw door tool with additional justification options (x-dir).
                    Tutorial 84 - Positioning Doors (7:19 min.)
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 4.4.6b - 04.12.2026
                      • Added custom door positioning offsets into the Door tab of the Global Settings.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 4.4.7 - 04.16.2026
                        • Fixed a bug with custom door positioning for metric templates.
                        • Enabled "profile cutting" of posts for vertical handrails.
                        • Fixed a bug with the bottom trimming algorithm for balusters
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 4.4.8 - 04.18.2026
                          • Enabled custom components as posts for vertical handrails
                          design.medeek.com
                          • medeekM
                            medeek
                            Tutorial 85 - Profile Cut Newel Posts (9:04 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 4.4.8b - 04.18.2026
                              • Enabled custom components as balusters for vertical and OTP handrails.
                              Th sub-folder structure is the same as for newel posts, so Tutorial #85 is applicable to balusters as well.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 4.4.8c - 04.19.2026
                                • Fixed a minor typo in the stair module.
                                • Added a ornamental iron baluster into the baluster component library.
                                The limitations of profile cutting balusters can be overcome by using a predefined component instead, which allows for much more intricate baluster geometries.
                                However as I have been researching various baluster layouts I've noticed that with iron balusters usually more than one baluster style is utilized. The typical scenario is two or three different baluster geometries are alternated along the run of stairs. I will need to give this some more thought.
                                Stairs can be a "rabbit hole".
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 4.4.9 - 04.19.2026
                                  • Enabled a secondary custom profile/component parameter for balusters.
                                  • Added additional ornamental iron balusters into the baluster component library.
                                  I think I've beat this horse to death. Hopefully with this added option we can configure most of the common baluster layouts, however there will always be a few that will be beyond the scope of the plugin (ie. three or more baluster types in various repeating patterns).
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 4.5.0 - 04.20.2026
                                    • Enabled custom components as posts for OTP handrails.
                                    • Enabled "profile cutting" of posts for OTP handrails.
                                    • Modified the bottom trimming algorithm for balusters to better accommodate complex baluster components.
                                    • Added one additional ornamental iron baluster into the baluster component library.
                                    • Added one OTP newel post into the newel post component library: LJ4270_43
                                    I will readily admit configuring OTP handrails with their associated posts and fittings is a bit tricky, adjusting the various offsets takes a few iterations to really hone things in.
                                    I appreciate everyone who has pushed me to flesh out the newel post and baluster capabilities. I feel like the stair module is a bit complicated now and perhaps even a bit clunky with so many options and variables but at the same time it is much more configurable and flexible and can I say with these new capabilities more powerful.
                                    Obviously it would be optimal if I could spend some serious time and create many of the standard balusters and newel posts found in LJ Smith’s general catalog so that the user would have a bevy of options to choose from without having to exert additional effort in creating their own. However, such an undertaking could easily consume two to three weeks and my development time is probably better spent elsewhere at the moment.
                                    design.medeek.com
                                    L 1 Reply Last reply 👍
                                    • L
                                      Luke147ll Newcomers @medeek
                                      @medeek keep up the good work.. I've designed and built miles of walls using the wall plugin! 8b25ee20-6923-42df-b851-ab42360c29cc-image.jpeg
                                      medeekM 1 Reply Last reply 👍
                                      • medeekM
                                        medeek @Luke147ll
                                        @Luke147ll
                                        Wow, now I'm curious. Please post more as this build progresses. I am especially curious to know how it all comes together for you and what if any issues arose. Also if you don't mind and are comfortable with it, I would love for you to post a screenshot or two of your model.
                                        This is very cool stuff, to see the plugin translating into real world wood. Impressive!
                                        design.medeek.com
                                        • L
                                          @medeek
                                          I've got a couple great models that are all framed out. I will put together a gallery and post it tonight after work. I used to prefab wall panels and created all the shop drawings using your plugin.. I got too busy with custom residential and sold the equipment. Now I use the plugin to create a build ready digital twin. I will post some images in the gallery and call it something like medeek in action.
                                          • medeekM
                                            medeek
                                            Well... I thought I was done with balusters and newel posts, but I'm not quite there yet.
                                            The problem is that with metal or iron balusters they are often installed with a shoe as shown below:
                                            My current algorithm installs balusters just like they are installed in real life:
                                            First I trim the top of the original baluster component/group and then I have to trim them individually for each of their bottoms because the balusters may intersect the treads at different heights hence their heights/lengths will be different.
                                            Because of this a predefined shoe positioned at the base of the baluster component may work for one location (ie. no trimming required) but then it will be removed in subsequent baluster locations.
                                            What this means in practice is that a shoe (if that option were enabled) needs to be a completely separate group/component just as it is in real life. My algorithm needs to position it individually in the Z-dir just as I trim each baluster bottom individually.
                                            Arguably, there is a lot going on with stairs, the guys that install these must be real craftsmen, I certainly take my hat off to them.
                                            design.medeek.com
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 77 / 81
