    Been a while.
    40 Posts 5 Posters 3.8k Views 5 Watching
      You are getting there, no worries. Hoping you have a decent break mate.
        OK, I understand the plague that is removing Rayscaper lights.
        "Cleanup", is removing the Rayscaper lights.
        Frustrating but at least I got something out of today.
          Post artificial light death, I have this.
            OK, auto exposure OFF (It will get there) and set at 7.5. I also fixed the blind which was rather abused. I have confirmed to my own satisfaction that when items and finishes/colours go missing, a restart of Rayscaper will fix the problem. Also, do not use cleanup for the whole model, elements in turn. Otherwise you will have your Rayscaper lights deleted.
            10 2500s 2015 x 1202 1412211 tri 8m 13s GPU  env 0.80 Backplate Auto Exposure off Exposure 7.5.png
              Your glass is not right. You can see the distortion due to IOR.
              Can you screenshot your glass material setup in the Rayscaper dialog?
                Look here how the refraction distorts with Thin unchecked.
                Rayscaper Thin Glass Setting
                  I cannot do so but it was definitely selected as 'thin' AFIK. Normal habit is to do so.
                  No render proceeding ATM due to this report.....
                    Repeated more than half a dozen times, same subject render.
                      Rayscaper has reverted to cpu rendering method again.
                        Stuff is expected with a beta release program, not the end of the world in any way.
                        I have Maxwell render running the scene so the model is not at fault.
                        I have had some time to finesse the layout and make sure stuff just 'fits' and is doable.
                        • P
                          Hey Mike,
                          I'm sorry to hear you're running into these issues with Rayscaper. Would you mind sending me this scene so I can have a look?
                          Summarizing your woes:
                          • Auto-exposure is behaving strangely. Mike, I'm still not sure what you mean by this.
                          • Geometry does not appear in the renders.
                          • Viewport shows CPU, while you have enabled GPU rendering.
                          • Rendering fails.
                          I think it's easier if you send me the scene and, preferably, the logs when such a render failure occurs (https://www.rayscaper.com/getting-help/report-a-bug/#1-export-the-log-files), so I can try to reproduce/fix these problems.
                          Thanks,
                          Thomas
                          Mike AmosM 1 Reply Last reply
                            Mike Amos @pixelcruncher
                            @pixelcruncher said:
                            Hey Mike,
                            ************Auto exposure doing funky things is a fraction where the interior and exterior are mismatched.
                            The exterior tends towards overexposure when the interior is properly or slightly underexposed**********.**
                            Sometimes geometry just fails to export to Rayscaper, that or it is deleted. Restart can fix this sometimes.
                            Simples, Sometimes the render window shows CPU rendering with my selecting it.
                            • Rendering fails.
                            Mostly when the CPU method is self appointed, nothing in the render window at all.
                            Thanks,
                            Thomas
                              Sorry, missed this response, stuff happening and loudly.
                              I will not be sending any scene's for a while as onepillockdrive is taking me up the wall. On my tenth circuit of wall, ceiling, wall, floor.......
                              microsnot wanting me to reinstall the pillock drive to "Experience the full benefit of a properly functioning pc experience, it is only between Β£20 and Β£50 per month to home all my files on their 'super safe' servers".
                              • hellnbakH
                                hellnbak
                                Geez, I would give anything to understand even a tiny percentage of what you guys are talking about
                                • 2 / 2
