    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • fredo6F
      When you report a Ruby error, please copy the text in the Ruby console from the Error line and paste it as text here in the forum. This screenshot can be exploited.
      • ntxdaveN
        ntxdave
        There was no error message so I shared what I saw. I fully understand what you are saying though. πŸ‘
        Any idea why I am not getting a video though?
        Press F1...thank me later
        • fredo6F
          Yes there is an error as shown in your screenshot.
          Simply, I miss the beginning of the error message.
          By the way resize to lower part of the console to the minimum (one line). The upper part is for the display of messages.
          • ntxdaveN
            ntxdave
            Is this what you are looking for?
            fredo6_animator/animatorpalette.rbe:820:in `block in palette_clip_name_duration_video'
            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4100:in `execute_button'
            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3854:in `onLButtonUp'
            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in `onLButtonUp'
            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:1293:in `onLButtonUp'
            • fredo6F
              Better but I need the top message starting by 'Error...'. This is where the error is stated.
              ntxdaveN 1 Reply Last reply
              • ntxdaveN
                ntxdave @fredo6
                @fredo6 said in [Plugin] Animator - v4.6a - 18 Dec 25:
                OK, here it everything that is in the top box
                #<NoMethodError: undefined method custom_convert_id' for Traductor::ChromiumWdlg:Class> c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:159:in cid'
                c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:44:in initialize__' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6weblist.rbe:33:in initialize'
                c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:in new' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:in job_dialog_select_repair'
                c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1641:in job_detect_repairing' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:2293:in movie_clip_generation'
                c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorpalette.rbe:820:in block in palette_clip_name_duration_video' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4100:in execute_button'
                c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3854:in onLButtonUp' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp'
                • fredo6F
                  Which version of LibFredo6 do you have?
                  • ntxdaveN
                    ntxdave
                    I thought I had the latest version. It says I am up to date. I will have to go to my laptop to find out. Where is the best place to check?
                    • ntxdaveN
                      ntxdave
                      • fredo6F
                        Menu Window > LibFredo6 Setting... > About
                        • ntxdaveN
                          ntxdave
                          I have done some more testing, and there is something wrong with my file. In other files I can launch the movie generator.
                          So, tomorrow I will try to clean up the file and see if I can get things back on trach. I did look at the file earlier and something I did messed up the location of some objects in my animation. So, first I will get that cleaned up and then try one step at a time to see what is causing the problem. Big problem was that I made 4 other copies of the file and they are also messed up also. So, I will try to resolve/figure out what the problem is.
                          Hope I have not caused you any problems. I thought I was creating something with positive results, so I need to figure this all out and share with you what I figure out.
                          • ntxdaveN
                            ntxdave
                            I am continuing to have problems. It seems like some files will allow me to generate a movie and some will not.
                            Hers is a file that "seems" to be OK and in Animator I can see everything, but when I try to generate the video, nothing happens.
                            3 Scene Animator.skp
                            BTW: I tried both with clips for each section and without them and get the same result. Everything plays fine in Animator, but it will not let me generate a video.
                            I am beginning to wonder if I should just give up.
                            • fredo6F
                              Can you report the Ruby error properly. Thanks.
                              • ntxdaveN
                                ntxdave
                                Thank you so much for the update to LibFredo6 v15.8d.
                                I was about to give up but after updating to the LibFredo6 v15.8d I was able to generate the video. πŸ‘ πŸ‘ πŸ‘
                                In fact, I was also able to create a 2nd version of the model with everything done in clips. Again πŸ‘ πŸ‘ πŸ‘
                                So, here are some videos I was able to create with the 2 versions of the file (one without clips and the other with clips).
                                Without clips:
                                3 Scene Animator.mp4
                                With Clips
                                3 Scene Animation With Clips.mp4
                                I hope this shows that you can have multiple animated scenes in a SU model and use Animator to "show them off".
                                • ntxdaveN ntxdave referenced this topic on
                                • ntxdaveN
                                  ntxdave
                                  I think I finally resolved the issue that I was having with the cameras (not 100% the way I want) but I am not having a problem trying to generate a video. It stops every time at the same spot (I have tried about 10 time this morning). Here is a screen shot of where things stop:
                                  I would be happy to share the file, but it is too big to upload to this forum. If there is another way I can share with someone who is willing to take a look at it, just let me know and I will share it.
                                  fredo6F 1 Reply Last reply
                                  • ntxdaveN
                                    ntxdave
                                    OK, I have installed a trial version of Drop Box and am trying to share the SketchUp file that I need for someone to look at and see if you can generate a video.
                                    Here is a link to the file.SketchUp Animator file
                                    • fredo6F
                                      fredo6 @ntxdave
                                      @ntxdave
                                      Could you leave the Ruby console open when generating the video.
                                      There might be an error worth reporting.
                                      • ntxdaveN
                                        ntxdave @fredo6
                                        @fredo6 That is what I had in mind this morning. I will go do it now and see what happens and if there is anything in the Ruby Concols.
                                        • ntxdaveN
                                          ntxdave @ntxdave
                                          OK, when it got to the point like I posted before, the Ruby Console suddenly filled up and here is what was in the console:
                                          #<TypeError: nil can't be coerced into Float>
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6camerainterpolator.rbe:192:in *' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6camerainterpolator.rbe:192:in create_final_camera'
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6camerainterpolator.rbe:342:in interpolate' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6camerainterpolator.rbe:56:in sucamera_interpolate'
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6viewpoint.rbe:372:in sucamera_interpolate' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6viewpoint.rbe:283:in blend'
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatoranimal.rbe:1582:in animal_post_processing_visual_interpolation' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatoranimal.rbe:1530:in animal_post_processing_visual'
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatoranimal.rbe:1602:in animal_animate_finalize_execution' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatoranimal.rbe:578:in animal_animate_film'
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe:1359:in clip_animate' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe:1537:in notify_from_clip_animation'
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe:243:in call' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe:243:in notify_event'
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe:451:in perform' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:2183:in movie_robot'
                                          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:2241:in `block in movie_continue_after_frame'
                                          I am trying to create a link on Drop Box to share the file with you so that you can see what is going on.
                                          BTW: A silly question is, where are the images stored while it is generating the video?
                                          Never mind, I clicked on the Folder link and see where they are stored.
                                          • ntxdaveN
                                            ntxdave
                                            Here is a Drop Box link to the file so you can look at it and see what I am dong wrong that will not allow me to generate the video. Jesus Plaque SKP file
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 29 / 30
