    shortcuts not retained in 2026 when Sketchup restarts
    11 Posts 5 Posters 2.3k Views 5 Watching
      Some OSs protect/reserve certain Ctrl+Key combos, so your system might revert Ctrl+Q to Quit after changes. Try something else like Shift+Q and see what happens...
      Alternatively, if you haven't installed SketchUp properly SketchUp might not be able to remember user's changes to shortcuts in their preferences file.
      This will be obvious if changing a shortcut to something potentially innocuous isn't remembered across sessions.
      To fix a faulty installation is simple.
      Exit SketchUp and find its Installer exe file, usually in your Downloads folder.
      Select its icon and right-click > context-menu > Run as administrator
      When the dialog opens it should offer a 'Repair' option.
      Choose 'Repair' and let it run,
      this will fix the permissions of various files and folders,
      so that your normal user-accounts changes to things like Shortcuts are remembered between sessions.
      Choosing to 'Run' the installer's exe file, or double-clicking it is not the same as 'Run as administrator', even if your user has some admin-powers.
      There's no need to Uninstall and Reinstall to fix things.
      The Repair will not affect any customized changes or extension installations etc...
      J 1 Reply Last reply
        joshvt @TIG
        @TIG
        Thanks for the response and suggestions.
        Sketchup will retain Shift+Q when I restart it.
        I ran repair and it did not change anything.
        The fact that I when I type Ctrl+Q in the preferences the "+" is unresponsive so it will not add it to the assigned box is strange. But I can add Shift+Q to the assigned box and sketchup will then retain it when restarted.
        So I guess this is an annoying bug and I need to train myself to use a new shortcut.
          This post is deleted!
            joshvt
            Thanks for clarifying. It didn't used to be. previous versions did not have a shortcut for Exit. I've been using it for hide rest model since the early days of sketchup. It's frustrating they made it hard coded with this release (I'm not even sure why they need a shortcut to Exit).
            panixiaP 1 Reply Last reply
              • panixiaP
                panixia @joshvt
                @joshvt said in shortcuts not retained in 2026 when Sketchup restarts:
                Agreed. Moreover it's redundant with Ctrl + F4 which is standard for Windows.
                  joshvt @panixia
                  My second day of using 2026 and I've been having issues with copy and paste working inconsistently (I use Ctrl+C, Ctrl+V- just like every other windows program) Just noticed that sketchup 2026 edit menu shows the shortcuts for these as Ctrl+Ins, Shift+Ins. Presumably this is related to the insconsistent behavior I am experiencing when using the old/ standard shortcuts. Makes total sense to use a shortcut with keys on the opposite side of the keyboard... thanks Sketchup.... unreal.
                    CTRL+C and V works for me even though menu shortcut shows INS
                    I'd say 2026.1 or 2 will address the issues.
                    If you check the shortcuts you'll see 2 entries
                      joshvt
                      Thanks. Ctrl+C and Ctrl+V work about 75% of the time. I'm trying to recreate/ observe the situation where they don't work, but haven't figured it out yet. Ctrl+C works less frequently than Ctrl+V, which is odd.
                        On PCs in v2026.1 some nitwit swapped the order in the Preferences >Shortcuts listed for the Edit commands for Copy Ctrl+C and Ctrl+Insert, and also the Cut [+X/+Insert] and Paste [+V/+Insert] etc, so the Edit menu now gives you an illogical listing because the long established ones now come second and so they aren't listed in that menu.
                        They still work, Unfortunately they are hardwired and not editable in Preferences>Shortcuts.
                        Hopefully common sense will revert this weirdness in the next update.
