    Rayscaper New Releases
    rayscaperrender
    461 Posts 12 Posters 111.9k Views 13 Watching
    • KrassK Offline
      Krass
      Yes, I was able to reduce the noise with a mask to which I applied a denoiser effect, but is that the denoiser you're thinking of? It's better anyway.
      Krass
      • P Online
        This post is deleted!
        • P Online
          @Krass Yes, according to the docs, that should be the one.
            Alattab
            In the latest update, the icons disappeared.
            • P Online
              pixelcruncher Extension Creator @Alattab
              @Alattab That sucks, I'm sorry about that.
              As a first step, can you try reinstalling the plugin and restarting SketchUp afterwards?
              If that doesn't work, can you send me the log files? https://www.rayscaper.com/getting-help/report-a-bug/#1-export-the-log-files - You can send them to thomas at rayscaper.com.
              Thanks,
              Thomas
              A 3 Replies Last reply Reply Quote 0
              • KrassK Offline
                Krass
                Hello Thomas
                Can you tell me why I get a blue display when I change the project folder?
                Krass
                  Alattab @pixelcruncher
                  @pixelcruncher Rayscaper_0.9.85_Beta_Windows_logs_2026-01-13_01-28-57.zip
                    @pixelcruncher I followed your instructions, but the problem persists.
                    KrassK 1 Reply Last reply Reply Quote 0
                      • KrassK Offline
                        Krass
                        Hi Thomas,
                        I'm wondering if the animation export settings in the SketchUp project have an impact on the Rayscaper output: because the last animation I made at 30 frames per second in Rayscaper is set to 24 frames per second in SketchUp...
                        Krass
                        • KrassK Offline
                          Krass
                          Krass
                          • KrassK Offline
                            Krass @Alattab
                            @Alattab hello,
                            I tryied to render a fountain : from a blenderkit free water jet model and a normal map for water and photoshop post processing
                            Krass
                            A 1 Reply Last reply 👍 Reply Quote 1
                            • P Online
                              @Krass Can you provide a screenshot of your HDRI path or the texture paths? The paths that Rayscaper couldn't find would have a danger triangle next to them. If you send me the logs then I could also have a look to see which paths aren't detected, hard to tell for me like this what went wrong.
                              Thanks,
                              Thomas
                              • KrassK Offline
                                Krass
                                Yes Thomas, I will send it to you tomorrow morning. I tried to reload it from Rayscaper and restart RS, but non way. But did not restart SU. Mau be it 'll work tomorrow. I m not homE now. Yes there was a triangle in front of the image slot
                                Krass
                                  Alattab @Krass
                                  @Krass That's great! Could you please attach the SketchUp file, the Normal Map file, and a screenshot showing the settings you used in Rayscaper?
                                  • KrassK Offline
                                    Krass
                                    Hello yes, I will do it tomorrow. Remind it to me if I forget
                                    Krass
                                    • P Online
                                      @Krass These settings have no bearing on the animations that Rayscaper renders.
                                      • P Online
                                        @Alattab, I will have a look at this and maybe provide an installer. I'm not sure what happened here right now. Will get back to you.
                                        Thanks,
                                        Thomas
                                        • KrassK Offline
                                          Krass @pixelcruncher
                                          @pixelcruncher said in Rayscaper New Releases:
                                          THANKS
                                          Krass
                                          • P Online
                                            pixelcruncher Extension Creator @pixelcruncher
                                            @alattab
                                            You can download an installer here: https://rayscaper-releases.s3.amazonaws.com/SketchUp/Windows/Rayscaper_Win_0.9.85_Beta_Setup.exe - Can you try using the installer to see if it works better for you?
                                            Regards,
                                            Thomas
                                            A 1 Reply Last reply Reply Quote 0
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 20 / 24
