    Scene animation with Animator
    107 Posts 3 Posters 25.5k Views 3 Watching
      If you intend to have some type of text based elements in your video its probably better suited to another software.
      You could do it in Animator but I'd offload the non-3D stuff to something else.
      ntxdaveN 1 Reply Last reply
      • ntxdaveN
        ntxdave @Rich O Brien
        @Rich-O-Brien said in Scene animation with Animator:
        Any suggestions as to what? What would you use.
        @rich-o-brien I really need some feedback on the other issues I posted. I am having problems managing some of the elements in my model. In particular, if you look at the previous images I posted, I cannot figure out what that white vertical line is in my timeline and how to edit it. I am also having problems trying to manage the elements.. clips, and views. I have tried to delete some of them but cannot get that to work.
        You are the only one who has given me any feedback and I am watching videos and looking at other thigs to try to figure this stuff out.
        Press F1...thank me later
        • ntxdaveN
          ntxdave
          Here is a thread where I have been posting problems/issues I am having with Animator https://community.sketchucation.com/topic/164682/scene-animation-with-animator/36
          First off, let me say that @rich-o-brien and @fredo05 have been given me some feedback but I still have several issues that I do not seem to be able to resolve.
          I feel I have learned a lot about using Animator and am close to being able to accomplish what I would like. However, there are several issues that I have pointed out in the other thread that I need some assistance/feedback on. I have looked at several videos and other posts, but I just cannot resolve some issues. If you look at the thread, one of the latest issues I need to address is how to combine some text with an Animation video and what tool you would recommend (I am using Windows 11).
          Let me also say that if this is a strand post that is viewed as a duplicate of the thread I mentioned above. I am sorry, I am just trying to resolve a few final issues so that I can complete a couple of projects I want to do.
          • ntxdaveN ntxdave referenced this topic on
            I merged that extra thread to here. Creating separate threads pointing to other threads is not helping you.
            As you have proven, many times already, that if you persevere when you encounter issues you'll figure it out.
            That bar you are pointing is a scrollbar. Not an element related to the animation. You have Clips starting at 24secs in your timeline than go to 33secs.
            Regarding your issue Purging. You haven't explained the issue so I can only guess.
            If you click Purge Unused then Animator will indicate, in Pink, all the unused elements in your file. Then if you click Save Changes and Exit Tool it will remove the Unused Elements.
            It will not remove elements while you still have the tool active.
            Lots of these issues you encounter are resolved by A/B testing yourself. If it is not doing what you expect then try a different approach to understand how it is expected to work.
            So here's a task for you. Get the clips that are way down the timeline to be at the start.
            See if you can find a way to do it without having to drag the elements individual.
            HINT: Right click on your timeline.
            • ntxdaveN
              Thanks Rich - I honestly thought it was a mistake to add another thread. I guess it shows that I needed/wanted more feedback.
              Thanks again. Yes, even though I have gotten kind of frustrated at time, if I do enough research (especially after some of your responses) I have usually found a solution.
              I do not know why I did not see/realize that is what it was. DUH!
              Thanks again. I just was not taking the correct steps. I have been able to purge the unwanted stuff and am redoing other items. I had watched one of Fredo6's videos and thought I was taking the right steps. You explanation got the issues resolved for me. I have been able to clean up the info now. It also lead me to going in and changing the names of several segments and clips so now I can look at the list and see what is what.
              Done..........another silly error on my part that was partly the result the silly bar that was showing up.
              Another DUH! on my part. Another helpful hint.
              Now for my last 2 issues (at least at this point):
              • I am having problems trying to control the camera so that I get things to show up correctly (at least the way I would like) from one clip to another. I have tried several options but so far have not figured things out the way I would like them. Again, any hints/suggestions would be appreciated. As you have seen, there is a lot of difference between the 2 scenes in my model and I would like for the camera position to change from one of the scenes to the other. I also would like to be able to control the transition from one scenes/clip to another. I haven't figured that one out yet either.
              • Yesterday in one of your replies, you suggested using some other software to put together my Animator video and the introduction and conclusion text. While I might want to add some animation to those two sections (which is why I was trying to do it with Animator), you are probably right. Do you have a suggestion of some other software to use? I would prefer a free package but am open to explore suggestions. BTW: Since I have been using Animator for this, I also did some research and found out how to use an image to set the background for my model/animation. I really am looking forward to that for one (and possibly both) of the models/animations I am planning on doing. Neither of them will be all that sophisticated they are just something that I have an inspiration to do and what has lead to all of this hullaballoo.
              Once again, I really appreciate your support/feedback.
              • ntxdaveN
                ntxdave
                OK, I just found a video about the camera position in Animator and I am working on it. If I figure this on out correctly I will be very close to where I want to be. πŸ‘
                  Great, just keep plugging away. There is no better way to learn other than just brute force.
                  Failing is part of winning.
                  • ntxdaveN
                    @Rich-O-Brien πŸ‘
                    Still wondering about some video editing software
                      Rich O Brien Moderator @ntxdave
                      @ntxdave said in Scene animation with Animator:
                      Go research it. But if you keep biting off more and more things to learn you'll get nowhere.
                      What's the rush? Take things at a sensible pace and enjoy the journey. Make the best animation in SketchUp you can then fuss over the rest when that part is sorted.
                      • ntxdaveN
                        ntxdave
                        OK, I have created a very basic model/animation that has an object that I view via the front, right, left, back, top and bottom. Each of the segments is 2.0 seconds. Not what I would like to do is control the transition from one sequence to the next. However, so far, I have not been able to figure out how to control the transitions,
                        Here is the silly little model.
                        Camera Positioning.skp
                        I probably should also figure out a nice clean way to animate the change from one scene to another. Again, this is really helping me get to the direction I want to go with my future 2 models/animations.
                          Try reverse engineer this:
                          nxtdave-camera.skp
                          I didn't look at your file but check that to see if there are scenes in my file. If not then figure out how the camera moves without using scenes.
                          • ntxdaveN
                            @Rich-O-Brien Thanks Rich but that is not my issue. I have some totally different objects in multiple scenes. I can capture the camera position/view in each of the scenes but I cannot get a smooth transition from one of the views to another. Each camera view is the different view, not always but usually different objects' When Animator goes from one camera view to the next, it is a crisp shot. I would like to have a way to make the transition rather smooth instead of just a different shot.
                              That is because the Scene is Static. Hover the buttons to see the tooltips.
                              Use the first icon
                              Click the Scene tab and then Capture View. Repeat for each Scene.
                              • ntxdaveN
                                ntxdave
                                OK, @rich-o-brien I have made some progress thanks to your post in the @majid thread.
                                So here is an updated file with the multiple scenes and the video I was able to create after following you response.
                                Camera Positioning 2.skp
                                amera Positioning 2.mp4
                                Now back to the last thing I am still trying to solve. How do you create a nice smooth transition between the clips. Just to let you (and other) know, I learned that before you do the screen capture, I needed to lick on the scene first.
                                Again, progress....πŸ‘
                                  If it is movement between Camera A position and Camera B position you can see how that is done in the file I shared further up.
                                  If the element in your timeline is stretched or fills the duration between A and B then the transition has no space to occur.
                                  So lets say you capture camera position at 0.0 and make it last 1 sec and then capture at 1.0 for another 1sec. You are essentially telling Animator keep that captured view held from 0.0 to 1.0 then switch to the next view at 1.0 etc.
                                  What should happen is you capture at 0.0 and then set the duration you want that held for. Then space for the Fadeout before your next captured view.
                                  In that 'space' the Fadeout will execute.
                                  • ntxdaveN
                                    ntxdave
                                    Well, again, I have made some progress. On the positive side, I found out that adding a one second blank space between the clips provides a transition between the clips that I like.
                                    However, I have run into 2 problems:
                                    • For some reason, the animation stops after the 3rd clip (right). I have not been able to figure out why.
                                    • I have had problems trying to clean up the Animator clip names. I have tried deleting the names, clicking the Purge Unused, Save Changes, and then exiting Animator. When I come back to the animation, the clip names I tried to delete are still there.
                                    Here is the updated version of the file:Camera Positioning 3.skp
                                      That's a bug. I discovered that today playing with your file. Fredo is aware and will post a fix with a new Libfredo.
                                      • ntxdaveN
                                        @Rich-O-Brien Thanks. I thought I was doing something wrong. πŸ‘πŸ‘
                                        That 1 second pause in between the scenes is giving me what I wanted. I think I will be able to use it in the models I have in mind.
                                        Can you give me a clue as to why I cannot delete some of the unwanted/unneeded clip names.
                                        This is turning into a real learning experience πŸ˜€πŸ˜€
                                        • fredo6F
                                          This should be fixed with LibFredo6 v15.8a, just published.
                                          ntxdaveN 2 Replies Last reply
                                            Would you consider that if you have unused animation elements in your model that this is animation data saved into the file?
                                            The clue:
                                            Could it be that marking unused animation data that is saved into the file for purging needs to be saved?
                                            Could the save icon go from disabled to enabled after you have told Animator to trash it?
                                            Also if you do mark unused elements to be purged by clicking the Maintenance of Data button and Save Changes and then Exit the tool using the Exit Tool button are you prompted that there are changes that have not been saved?
                                            The clue:
                                            • 3 / 6
