    Medeek Floor
    152 Posts 6 Posters 54.5k Views 5 Watching
    • medeekM
      medeek
      After a full day of tinkering and refactoring a bunch of the original floor truss code I think I now have the multi-chase algorithm working:
      Note how the chases all line up even though there are five or six different truss profiles within this assembly. I still need to create the web generator between the central sections of the truss profile, there is quite a bit going on here. I am still a few days out from completing the programming and then another two or three days of testing and further debugging.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Looks like I’m about 95% there with floor trusses:
        The only issue appears to be what happens when ribbon boards are enabled and you have an inside corner as shown. I probably need to add in some additional logic to eliminate the slot for the ribbon board in these cases.
        design.medeek.com
        • gullfoG
          gullfo
          looking good. also - there is some "clumping" of members on the left-hand side of the right-hand chase. likely due to having a second change and the sizing of the middle truss members (maybe instead a long one and clumped one, make two even one as i think this is how they would be manufactured)
          Glenn
          http://www.runnel.com
          • medeekM
            medeek
            Version 1.0.7 - 06.06.2025
            • Enabled MPC Wood Trusses with ribbon boards, multiple chases and gable trusses.
            • Updated the Move Floor Edge tool so that it also toggles the metal plate connector layer.
            • Update the SUBTRACT_JOIST feature so that it can adequately handle MPC wood trusses.
            Tutorial 27 - MPC Wood Trusses (13:25 min.)
            design.medeek.com
            • medeekM
              medeek
              Version 1.0.8 - 06.08.2025
              • Updated the SUBTRACT and SUBTRACT_JOIST features so that they can better handle MPC wood trusses, steel trusses and open web "Redbuilt" trusses.
              • Updated the Floor Opening module so that it can handle MPC wood trusses, steel trusses and open web "Redbuilt" trusses.
              • Added a "None" option for the header type in the draw and edit menus for floor openings.
              design.medeek.com
              • medeekM
                medeek
                In many cases when you introduce a stairwell opening into a floor like this it will be along the perimeter of the floor assembly as shown. In these cases it is simpler to create your floor perimeter with the opening in mind:
                Note, in order to create the additional gable truss (2x6 ply) I first changed my ply width to 5.5" then copied the gable truss at the interior of the stair well, then pasted it in place in the root of the model and then edited the floor assembly back to the typical 3.5" ply width. Alternatively one could simply frame this small pony wall with the Wall plugin (ie. conventional framing) just as easily.
                I'm not exactly sure how the trusses would work where the LVL beam/header is positioned at the start of the stairwell, obviously we would need some kind of header at that location.
                Here is a link to the model for those who are interested in examining this floor truss example in more detail:
                3D Warehouse
                (3dwarehouse.sketchup.com)
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.0.9 - 06.17.2025
                  • Added the floor truss toolbar with the following two items: Draw Beam Pocket, Delete Beam Pocket.
                  • Enabled beam pockets for MPC wood trusses.
                  • Fixed a bug with short span steel trusses.
                  Tutorial 28 - Beam Pockets with Floor Trusses (8:00 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.1.0 - 12.11.2025
                    • Updated the file/component loading method for hangers and certain joist types to increase plugin performance.
                    • Fixed multiple bugs with CFS joists.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.1.1 - 12.15.2025
                      • Added the following face mount Simpson hangers into the built-in library: THA422, THA422_2, THAC422, THAC422_2.
                      • Added the following top flange Simpson hangers into the built-in library: WP48, WP410, WP412, WP414, WP416, HWP156, HWP356.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.1.2 - 01.02.2026
                        • Fixed bugs with saving floor presets
                        Thank-you to all those who are sending in bug reports. Please keep sending those in, they are very helpful and I am able to track down and put out the little fires that much more quickly.
                        If you think you have encountered a bug, turn on the Ruby Console in SketchUp, then duplicate the behavior and then send me any error codes generated with other pertinent details. I will do my best to remedy all bugs that are detected and reported.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.1.3 - 01.13.2026
                          • Enabled custom overhangs for sheathing.
                          • Added a "Remove Overhang" parameter to selectively control the sheathing overhang.
                          Update per customer request.
                          This feature is identical to the overhang feature included with steel decks and will allow the user to set an overhang and then selectively assign specific edges which do not have the overhang enabled.
                          Tutorial #20 explains how this feature works:
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.1.4 - 02.09.2026
                            • Fixed a bug with staggered joists.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.1.5 - 02.23.2026
                              • Added Roseburg RFPI® I-Joists: RFPI 20, RFPI 400, RFPI 40, RFPI 70, RFPI 90, RFPI 40S, RFPI 60S, RFPI 80S.
                              The Roseburg I-Joists include LVL and solid sawn flanges. This manufacturer of I-Joists added per customer request.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.1.6 - 02.24.2026
                                • Added Nordic I-Joists: NI 20, NI 40X, NI 60, NI 80, NI 90, 80X.
                                Added per customer request.
                                design.medeek.com
                                1 Reply Last reply 👍
                                • medeekM
                                  medeek
                                  Version 1.1.7 - 02.25.2026
                                  • Added PWT I-Joists: PWI 18S, PWI 32S, PWI 42S, PWI 53L, PWI 36L, PWI 56L.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.1.7b - 02.25.2026
                                    • Fixed a bug with the ceiling gypsum option.
                                    Previously if you set the ceiling inset parameter to zero the logic would try to apply this zero offset and would throw an error and then abort the draw process. I guess I automatically assumed a non-zero inset (ie. 3.5 or 5.5 inches) and did not test it with a zero inset, so I never caught this specific state.
                                    Shout out to @ArtisanTony for finding this one for me. I probably would never have found out since I'm always using an inset when I turn on the gypsum, I don't think I've ever used a zero inset.
                                    Keep sending in those bug reports, it is greatly appreciated. This extension isn't very old so I know there are still a few more small fires to put out, the trick of course is finding them all.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.1.8 - 02.26.2026
                                      • Added AcuJoist I-Joists: ACJ 40, ACJ 60, ACJ 80.
                                      I think that gets us to nine different I-Joist manufacturers in the US and Canada. I think Lebel and Eacom (both out of Canada) also make some I-Joist products, but I don't believe they have as much market share as the companies listed below:
                                      • Weyerhaeuser Trus Joist®
                                      • Boise Cascade BCI® Joists
                                      • LP SolidStart® I-Joists
                                      • Red Built Red-I™ I-Joists
                                      • PinkWood SAFEjoists and PKjoists™ I-Joists
                                      • Roseburg RFPI® I-Joists
                                      • Nordic I-Joists
                                      • PWT PWI™ I-Joists
                                      • AcuJoist I-Joists
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.1.9 - 03.01.2026
                                        • Updated the draw floor tool with a more robust "face" draw option.
                                        • Updated the draw opening tool with a more robust "face" draw option.
                                        • Updated the draw flooring tool with a more robust "face" draw option.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.2.1 - 03.26.2026
                                          • Enabled the following methods within the Medeek Floor API: lumber_floor_draw, truss_floor_draw
                                          design.medeek.com
                                          Reply Quote 2
                                          • medeekM
                                            medeek
                                            Version 1.2.2 - 07.19.2026
                                            • Added a floor "profile" edit tool within the context menu for floor assemblies.
                                            • Added a "Grid Snap" option with hotkey (End key) into the floor profile edit tool.
                                            design.medeek.com
                                            • 8 / 8
