    Medeek Floor
    152 Posts 6 Posters 37.7k Views 5 Watching
    • medeekM Offline
      medeek
      Version 1.1.1 - 12.15.2025
      • Added the following face mount Simpson hangers into the built-in library: THA422, THA422_2, THAC422, THAC422_2.
      • Added the following top flange Simpson hangers into the built-in library: WP48, WP410, WP412, WP414, WP416, HWP156, HWP356.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.1.2 - 01.02.2026
        • Fixed bugs with saving floor presets
        Thank-you to all those who are sending in bug reports. Please keep sending those in, they are very helpful and I am able to track down and put out the little fires that much more quickly.
        If you think you have encountered a bug, turn on the Ruby Console in SketchUp, then duplicate the behavior and then send me any error codes generated with other pertinent details. I will do my best to remedy all bugs that are detected and reported.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.1.3 - 01.13.2026
          • Enabled custom overhangs for sheathing.
          • Added a "Remove Overhang" parameter to selectively control the sheathing overhang.
          Update per customer request.
          This feature is identical to the overhang feature included with steel decks and will allow the user to set an overhang and then selectively assign specific edges which do not have the overhang enabled.
          Tutorial #20 explains how this feature works:
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.1.4 - 02.09.2026
            • Fixed a bug with staggered joists.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.1.5 - 02.23.2026
              • Added Roseburg RFPI® I-Joists: RFPI 20, RFPI 400, RFPI 40, RFPI 70, RFPI 90, RFPI 40S, RFPI 60S, RFPI 80S.
              The Roseburg I-Joists include LVL and solid sawn flanges. This manufacturer of I-Joists added per customer request.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.1.6 - 02.24.2026
                • Added Nordic I-Joists: NI 20, NI 40X, NI 60, NI 80, NI 90, 80X.
                Added per customer request.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.1.7 - 02.25.2026
                  • Added PWT I-Joists: PWI 18S, PWI 32S, PWI 42S, PWI 53L, PWI 36L, PWI 56L.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.1.7b - 02.25.2026
                    • Fixed a bug with the ceiling gypsum option.
                    Previously if you set the ceiling inset parameter to zero the logic would try to apply this zero offset and would throw an error and then abort the draw process. I guess I automatically assumed a non-zero inset (ie. 3.5 or 5.5 inches) and did not test it with a zero inset, so I never caught this specific state.
                    Shout out to @ArtisanTony for finding this one for me. I probably would never have found out since I'm always using an inset when I turn on the gypsum, I don't think I've ever used a zero inset.
                    Keep sending in those bug reports, it is greatly appreciated. This extension isn't very old so I know there are still a few more small fires to put out, the trick of course is finding them all.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.1.8 - 02.26.2026
                      • Added AcuJoist I-Joists: ACJ 40, ACJ 60, ACJ 80.
                      I think that gets us to nine different I-Joist manufacturers in the US and Canada. I think Lebel and Eacom (both out of Canada) also make some I-Joist products, but I don't believe they have as much market share as the companies listed below:
                      • Weyerhaeuser Trus Joist®
                      • Boise Cascade BCI® Joists
                      • LP SolidStart® I-Joists
                      • Red Built Red-I™ I-Joists
                      • PinkWood SAFEjoists and PKjoists™ I-Joists
                      • Roseburg RFPI® I-Joists
                      • Nordic I-Joists
                      • PWT PWI™ I-Joists
                      • AcuJoist I-Joists
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.1.9 - 03.01.2026
                        • Updated the draw floor tool with a more robust "face" draw option.
                        • Updated the draw opening tool with a more robust "face" draw option.
                        • Updated the draw flooring tool with a more robust "face" draw option.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.2.1 - 03.26.2026
                          • Enabled the following methods within the Medeek Floor API: lumber_floor_draw, truss_floor_draw
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.2.2 - 07.19.2026
                            • Added a floor "profile" edit tool within the context menu for floor assemblies.
                            • Added a "Grid Snap" option with hotkey (End key) into the floor profile edit tool.
                            design.medeek.com
                            • 8 / 8
