    Scene animation with Animator
    107 Posts 3 Posters 25.5k Views 3 Watching
    • ntxdaveN
      ntxdave @fredo6
      @fredo6 said in Scene animation with Animator:
      Scenes can be used in Animator for their camera. The interest versus setting the camera in Animator is that Animator will use the camera of the scene , which is controlled outside of Animator.
      However, for tags (layers) and visibility of objects, you need to use Visual Effects.
      If you look at the tutorial I referenced above at about 1:49, you will see a very interesting way the poster handled an object (trvealing in it I circular pattern).. I want to do something similar with some intro text (probably reveal it in a left to right pattern - like writing or printing the text.
      I have some other things in the back of my mind but I need to takes one step at a time. Bottom line is that I think Animator is a great tool but learning how to take advantage of its features is somewhat difficult.
      Press F1...thank me later
      • ntxdaveN
        ntxdave @fredo6
        Thanks for this feedback. Now I need to figure out how to use a lot of the features of Animator. BTW, I have used Animator many times in the past for things like looking at car washes, a figure walking along a path and even one of a drone moving around. You can see them if you go to YouTube and look for ntxdave animations (I now have a new account on YouTube so that will change in the future).
        Now I want to do something really different. The movie below was created using native SketchUp animation features. I want to make a more sophisticated version using Animator and some of its features (some like the Tutorials Up video I referenced before and adding text intro and conclusion.
        Here is the current video Jesus Animation.mp4
        IHere is the SketchUp model for you to look at and give me advice. Jesus-Animator.skp
        In this video there is a transition that takes place early (about 1:40) that I would like to understand better.
          Rich O Brien Moderator @ntxdave
          @ntxdave said in Scene animation with Animator:
          The object is moved through the plane to fake the appearance of a Spiral getting revealed.
          You can set playback on YouTube to be 0.25x speed if following along in real-time is difficult.
          ntxdaveN 1 Reply Last reply
          • ntxdaveN
            ntxdave @Rich O Brien
            @Rich-O-Brien said in Scene animation with Animator:
            You can set playback on YouTube to be 0.25x speed if following along in real-time is difficulty
            I have never done that before. How do you do that?
            • ntxdaveN
              ntxdave @ntxdave
              OK, I looked it up and found out how to adjust the playback speed. I was able to set the speed to .25 on both my iPad and laptop.πŸ‘
              • ntxdaveN
                ntxdave
                @rich-o-brien @fredo6
                OK guys, I am making some progress. I have a version being developed with Animator. I have to get ff-mpeg installed so I can generate some to share with you. Just want you to know that I am making some progress. Lots of trial and error so far and I can tell you I am going to have a bunch of questions later but I am headed in the direction I want to go. 😁 πŸ‘
                • ntxdaveN
                  ntxdave
                  OK, still more progress but when I click on the Generate Video link, nothing is happening.
                    Go to Tools > Fredo Collection > Animator > Video... menu for guides
                    • ntxdaveN
                      ntxdave
                      Yes, I went there but I cannot generate a video. Again, when I click on the Generate Video button in Animator, nothing happens. It does not launch the screen for me to select the options and generate a video.
                      • fredo6F
                        Can you open the Ruby console.
                        • ntxdaveN
                          ntxdave
                          Here is what I see:
                          BTW: Here is what I am clicking to generate the video.
                          • ntxdaveN
                            ntxdave
                            Now I am seeing more problems. When I open the model and try to replay the animation in Animator, all of the objects are misplaced.
                            Here is a copy of the SketchUp model. If you load it you will see it play the correct movements, but all of the objects are now in the wrong place. How do I keep this from happening?
                            Jesus - Animator Animation.skp
                            Now to tell you where I want to take this:
                            • I want to add some "introductory" text and an image. Part of this will include also animating parts of the text and possibly the image.
                            • I want to add some "exit text" that again, might include some animation.
                            I have had several thoughts about this and with scenes and tags(layers) this is pretty easy but with Animator, it seems like I have more options for the animation sequences.
                            All of this is really an exercise for me to learn more about controlling things in/with Animator. I have another project if mind that would use a lot of these same things. As I have said before, I have used Animator many times in the past. If you go to YouTube and look under my previous account (ntxdave) you can see several videos. Some of them use some additional features that I am not currently using.
                            • ntxdaveN
                              ntxdave @ntxdave
                              OK, I was able to go back and save the model with everything in the right position to make the animation work correctly.
                              Here is an updated copy of the modelJesus - Animator Animation.skp
                              Now I need for someone to give me advice on how to save/create a camera position so that future developments will allow everything to show up in the right position(s).
                              I know, this is not a complicated model and all of this should be very easy to accomplish. As I said before, this seems very much different than things I have done in the past because of the collective movement of objects.
                              Once I have all of this worked out, I want to be able to assign a nice environment and try using Rayscaper to produce a rendered version of the final product.
                                Rayscaper does not support Animator.
                                • ntxdaveN
                                  @Rich-O-Brien ok, I thought I saw something recently that said they were working on that.
                                  • fredo6F
                                    Can you copy/paste the error message as text from the Ruby Console. The screenshot does not show the head of the error message.
                                    Also, always use the positioner (4th toolbar icon) to record the initial position of objects, precisely in case there are issues.
                                    • ntxdaveN
                                      ntxdave @fredo6
                                      There was no error message. I now have it working and ffmpeg is installed. πŸ˜€
                                      This is useful for me also. I am going to have several things located in the model so I will capture the camera position for each of the units.
                                      • ntxdaveN
                                        ntxdave
                                        Is there a way to adjust the camera position during an animation? As an example, I am going to move an object and I would like to move/change the camera as the movement occurs.
                                        I know I used to have the camera follow a car as it went through a car was but it has been too long ago and I do not remember how I achieved it. DUH!
                                        • fredo6F
                                          Just create as many camera view as you like and place them along the timeline. Animator will interpolate the camera between them.
                                          • ntxdaveN
                                            ntxdave
                                            OK guys I keep going backwards. In the screen short below, I cannot seem to click on the right link to get the timeline back to the left side (like normal). Screenshot 2026-01-02 214025.png
                                            I am also having a problem trying combine things to make a Clip. I thought you could hit the shift key and click on multiple items to create a Clip.
                                            • ntxdaveN ntxdave referenced this topic on
                                            • 1 / 6
