    Scene animation with Animator
    107 Posts 3 Posters 27.8k Views 3 Watching
    • ntxdaveN
      ntxdave
      OK, I have a VERY simple model that I would like to use for creating animations with Animator.
      As you will see in the model, there are 2 scenes and two objects.
      • Scene 1 {Side View) has two objects. A wood object that is laying down and a square to the right of the week object. This scene was crated using the "front" camera position.
      • Scen2 (Top View) has only one object viewable. The wood object is being viewed using the "Top" camera view. The second object does not show because the tag associated with it is turned off.
      Now here is what I want to achieve: I want an animation (created with Animator) that achieves the same results as though you had clicked on one of the scenes. In other words, you will see the transition from Side View to Top View and the second object that is hidden in the Top View no longer shows.
      I have a far more complicated model that uses some of the same features. I can create the animation pretty easily with SketchUp but I want to do it with Animator because there are other things that I want to achieve based on these same principles.
      Here is the SketchUp file for you to look at and give me some advice on how to achieve my goals.Animator Learning.skp
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        I just watched a tutorial from Tutorials Up that does a lot of what I would like to do with Animator. The name of the animation was Simple Animation with Fredo6 Animator
        The video showed a lot of things I would like to do in my animation. However, there was no narration of what was being done so I could not really follow what was being done for most of the video.
        I also watched a video for another plugin called Keyframe Animation. It also showed a lot of things I wish we could do in Animator (primarily using SketchUp scenes as "key frames").
        I which I could get some feedback on this thread.
        • ntxdaveN ntxdave marked this topic as a question on
          Animator requires the user to put in the hours playing around with it. Its also pretty advanced and requires a user to be proficient in SketchUp to begin with.
          Anyone adept using Animator has put in the time to discover its features.
          You need to set your Camera to use a scene.
          • ntxdaveN
            ntxdave
            Thanks @rich-o-brien. I will look at that the next time I start up SketchUp.
            Yes, it is hard to find out how things in Animator work. I saw A neat Animator tutorial here. In particular as the 1:49 point in the video there is a really neat feature. The problem with the video is that it is fast and there is no narrative.
            I had wanted this thread moved to a more generic category so that I would get more feedback. I also would like to be able to PM @fredo6-animator so that I could discuss some issues with him.
            I have also looked at another plugin called Keyframe Animation that has some neat feature but not as many options as Animator. One of the primary things it can do is use SketchUp Scenes. Since you pointed out the camera link, I will look at it and see if it gives me some ways to take advantage of scenes.
            OK @rich-o-brien, I just launched SU and then started Animator. How did you get to the option in your post?
              Rich O Brien Moderator @ntxdave
              @ntxdave said in Scene animation with Animator:
              Double clip a strip in your timeline to edit that strip's properties.
              ntxdaveN 1 Reply Last reply
              • fredo6F
                Scenes can be used in Animator for their camera. The interest versus setting the camera in Animator is that Animator will use the camera of the scene , which is controlled outside of Animator.
                However, for tags (layers) and visibility of objects, you need to use Visual Effects.
                ntxdaveN 2 Replies Last reply
                • ntxdaveN
                  ntxdave @Rich O Brien
                  @Rich-O-Brien said in Scene animation with Animator:
                  Thanks @rich-o-brien , I will look at that.
                  • ntxdaveN
                    ntxdave @fredo6
                    @fredo6 said in Scene animation with Animator:
                    If you look at the tutorial I referenced above at about 1:49, you will see a very interesting way the poster handled an object (trvealing in it I circular pattern).. I want to do something similar with some intro text (probably reveal it in a left to right pattern - like writing or printing the text.
                    I have some other things in the back of my mind but I need to takes one step at a time. Bottom line is that I think Animator is a great tool but learning how to take advantage of its features is somewhat difficult.
                    • ntxdaveN
                      ntxdave @fredo6
                      Thanks for this feedback. Now I need to figure out how to use a lot of the features of Animator. BTW, I have used Animator many times in the past for things like looking at car washes, a figure walking along a path and even one of a drone moving around. You can see them if you go to YouTube and look for ntxdave animations (I now have a new account on YouTube so that will change in the future).
                      Now I want to do something really different. The movie below was created using native SketchUp animation features. I want to make a more sophisticated version using Animator and some of its features (some like the Tutorials Up video I referenced before and adding text intro and conclusion.
                      Here is the current video Jesus Animation.mp4
                      IHere is the SketchUp model for you to look at and give me advice. Jesus-Animator.skp
                      In this video there is a transition that takes place early (about 1:40) that I would like to understand better.
                        The object is moved through the plane to fake the appearance of a Spiral getting revealed.
                        You can set playback on YouTube to be 0.25x speed if following along in real-time is difficult.
                        • ntxdaveN
                          You can set playback on YouTube to be 0.25x speed if following along in real-time is difficulty
                          I have never done that before. How do you do that?
                          • ntxdaveN
                            ntxdave @ntxdave
                            OK, I looked it up and found out how to adjust the playback speed. I was able to set the speed to .25 on both my iPad and laptop.πŸ‘
                            • ntxdaveN
                              ntxdave
                              @rich-o-brien @fredo6
                              OK guys, I am making some progress. I have a version being developed with Animator. I have to get ff-mpeg installed so I can generate some to share with you. Just want you to know that I am making some progress. Lots of trial and error so far and I can tell you I am going to have a bunch of questions later but I am headed in the direction I want to go. 😁 πŸ‘
                              • ntxdaveN
                                ntxdave
                                OK, still more progress but when I click on the Generate Video link, nothing is happening.
                                  Go to Tools > Fredo Collection > Animator > Video... menu for guides
                                  • ntxdaveN
                                    ntxdave
                                    Yes, I went there but I cannot generate a video. Again, when I click on the Generate Video button in Animator, nothing happens. It does not launch the screen for me to select the options and generate a video.
                                    • fredo6F
                                      Can you open the Ruby console.
                                      • ntxdaveN
                                        ntxdave
                                        Here is what I see:
                                        BTW: Here is what I am clicking to generate the video.
                                        • ntxdaveN
                                          ntxdave
                                          Now I am seeing more problems. When I open the model and try to replay the animation in Animator, all of the objects are misplaced.
                                          Here is a copy of the SketchUp model. If you load it you will see it play the correct movements, but all of the objects are now in the wrong place. How do I keep this from happening?
                                          Jesus - Animator Animation.skp
                                          Now to tell you where I want to take this:
                                          • I want to add some "introductory" text and an image. Part of this will include also animating parts of the text and possibly the image.
                                          • I want to add some "exit text" that again, might include some animation.
                                          I have had several thoughts about this and with scenes and tags(layers) this is pretty easy but with Animator, it seems like I have more options for the animation sequences.
                                          All of this is really an exercise for me to learn more about controlling things in/with Animator. I have another project if mind that would use a lot of these same things. As I have said before, I have used Animator many times in the past. If you go to YouTube and look under my previous account (ntxdave) you can see several videos. Some of them use some additional features that I am not currently using.
                                          • ntxdaveN
                                            ntxdave @ntxdave
                                            OK, I was able to go back and save the model with everything in the right position to make the animation work correctly.
                                            Here is an updated copy of the modelJesus - Animator Animation.skp
                                            Now I need for someone to give me advice on how to save/create a camera position so that future developments will allow everything to show up in the right position(s).
                                            I know, this is not a complicated model and all of this should be very easy to accomplish. As I said before, this seems very much different than things I have done in the past because of the collective movement of objects.
                                            Once I have all of this worked out, I want to be able to assign a nice environment and try using Rayscaper to produce a rendered version of the final product.
                                            • 1 / 6
