    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • gullfoG
      gullfo
      any future option on framing (wall and trusses) to include the plate end marks? e.g.
      also on the blocking (noggin marks?) etc.?
      Glenn
      http://www.runnel.com
      1 Reply Last reply 👍
      • medeekM
        medeek
        I will be running a Thanksgiving promotion beginning Oct. 30th until Dec. 1st with 30% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS25.
        This will reduce the bundle price from $280.00 USD to $196.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the Electrical, HVAC and Engineering plugins will also be included upon request at no additional cost. The offer ends on Dec.1st and no rain checks will issued thereafter.
        design.medeek.com
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          Version 4.1.4 - 11.26.2025
          • Added "GPS" and "PU" foam insulation as an option for SIP wall panels.
          • Enabled insulated (filled) custom headers for windows, doors and garage doors: XPS, ISO, EPS, GPS, PU.
          • Insulated headers can be customized/created with the Global Settings similar to standard (OSB/PLY) headers.
          • Added a QHQ Single Hung window to the window draw and edit menus.
          wall_su1013_800.jpg wall_su1014_800.jpg wall_su1016_800.jpg wall_su1018_800.jpg
          All updates per customer requests.
          design.medeek.com
          • medeekM
            medeek
            Tutorial 74 - Insulated Headers (6:28 min.)
            design.medeek.com
            • medeekM
              medeek
              Version 4.1.5 - 11.29.2025
              • Enabled Green, Pink and Grey options for XPS headers and SIP wall panels.
              • Added an option in the door draw and edit menus to change the door hardware material/color: None, Brass, Nickel, Bronze, Black, Copper, Gold.
              • Updated the file/component loading method for door hardware and shearwall holdowns to increase plugin performance.
              design.medeek.com
              • medeekM
                medeek
                Version 4.1.6 - 11.30.2025
                • Updated the context menus for walls with an “Edit Opening…” option if the selected (right click) wall contains a door, window or garage door.
                • Added “Arial Bold” as a font within the Annotation Formatting section of the General tab of the Global Settings.
                • Fixed a bug with Single and Double Hung QHQ windows.
                • Added a QHQ Double Hung window to the window draw and edit menus.
                design.medeek.com
                • medeekM
                  medeek
                  Tutorial 75 - Updated Context Menu (5:22 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 4.1.7 - 12.05.2025
                    • Enabled XPS (blue, green, pink and grey), ISO, EPS, GPS, and PU foam insulation within the wall sheathing options.
                    design.medeek.com
                    • medeekM
                      medeek
                      Tutorial 76 - Double Stud Walls (18:03 min.)
                      design.medeek.com
                      • medeekM
                        medeek
                        Tutorial 77 - Mitek vs. Simpson (11:00 min.)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 4.1.8 - 12.13.2025
                          • Fixed a long standing bug where blocking was not created above and below doors, windows and garage doors.
                          • Fixed the blocking bug for rectangular, gable, shed and hip walls.
                          • Fixed a context menu bug (Edit Opening...) for gable, shed and hip walls.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 4.1.9 - 12.16.2025
                            • Enabled the "Add Studs" feature for the following wall types: rectangular, gable, shed and hip.
                            Tutorial 79 - Adding Studs (5:31 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 4.1.9b - 12.18.2025
                              • Fixed a bug (door presets) introduced with door hardware material update on 11/29/2015 (Version 4.1.5).
                              design.medeek.com
                              Reply Quote 2
                              • medeekM
                                medeek
                                Version 4.2.0 - 12.22.2025
                                • Updated the opening and closing algorithm for all (panel) garage doors.
                                Not a customer request, just an interesting kinematic challenge that I felt like addressing at some point. I found the previous garage door opening animation largely unsatisfactory for panel doors like these. Hopefully you can indulge me with a little gold plating... now back to the real stuff.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I have posted a FAQ for licensing questions on my website with the most common questions that I am asked, hopefully this is helpful:
                                  Medeek Design Inc. - Medeek Extensions - Licensing
                                  Medeek Design Inc. - Medeek Licensing
                                  (design.medeek.com)
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 4.2.1 - 01.09.2026
                                    • Enabled the CUSTOM E casing for rectangular windows.
                                    • Enabled the CUSTOM H casing for rectangular windows.
                                    • Added a STYLE H casing option for rectangular windows.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 4.2.2 - 01.11.2026
                                      • Enabled the CUSTOM casing for trapezoid windows.
                                      • Enabled the CUSTOM H casing for trapezoid windows.
                                      • Enabled the CUSTOM casing for arched windows.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I just received a very long and detailed email from one of my power users and I was thoroughly impressed with many of the suggestions and usability notes provided to me.
                                        A long standing issue has been wall cladding as it relates to exterior trim of windows and doors. Up until now if you place your trim on the sheathing (not on cladding) then the trim interferes with the cladding. This usually isn't too big of a problem (visually) provided your cladding is not thicker than your trim. However, in the real world you generally install your trim first and then butt your cladding up to it, so there is no interference. When your cladding is thicker than your trim or you are using one of the 3D cladding options (ie. board and batten) this does become a bit of an issue and for me personally has been an annoying lack of realism now for a few years.
                                        To fix this I needed to enable an option where one can toggle the trimming of the cladding by the exterior trim and then add some logic and geometry into the current algorithms so that the end result is as follows:
                                        I won't bore you with the details of the rather complicated logic under the hood that accomplishes this but suffice it to say it is not trivial. It will take about 4-5 days to complete this update.
                                        The window algorithms are now updated but I will need to update the door and garage door methods as well now.
                                        In the global settings one will be able to independently toggle this on and off for windows, doors and garage doors. I will also probably put out another tutorial video on this feature specifically so that everyone is clear on how it works.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 4.2.3 - 01.18.2026
                                          • Added an option (global settings) to remove cladding with the exterior trim of doors, windows and garage doors.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Tutorial 80 - Removing Cladding (5:43 min.)
                                            design.medeek.com
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 80
                                            • 81
                                            • 74 / 81
