    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 4.1.1 - 08.17.2025
      • Added Fixed - Slider (L) and Fixed - Slider (R) windows to the window module.
      These two window types added per customer request.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 4.1.2 - 08.18.2025
        • Added hexagon windows to the window module.
        Note, that to get a regular hexagon window you will want to enter in a window height that is given by this formula:
        height = width x 0.8660254
        So for example if window is 48" wide its height will be: 48" x 0.8660254 = 41.569219"
        One can always enter in any size for example an elongated hexagon or squished hexagon but I suspect most manufacturers will typically only stock a "regular" hexagon shaped windows in various sizes.
        design.medeek.com
        • medeekM
          medeek
          Version 4.1.3 - 08.21.2025
          • Added a "Label Scaling" parameter for all wall types.
          Update per customer request.
          design.medeek.com
          • gullfoG
            gullfo
            any future option on framing (wall and trusses) to include the plate end marks? e.g.
            also on the blocking (noggin marks?) etc.?
            Glenn
            http://www.runnel.com
            1 Reply Last reply 👍
            • medeekM
              medeek
              I will be running a Thanksgiving promotion beginning Oct. 30th until Dec. 1st with 30% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS25.
              This will reduce the bundle price from $280.00 USD to $196.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the Electrical, HVAC and Engineering plugins will also be included upon request at no additional cost. The offer ends on Dec.1st and no rain checks will issued thereafter.
              design.medeek.com
              design.medeek.com
              • medeekM
                medeek
                Version 4.1.4 - 11.26.2025
                • Added "GPS" and "PU" foam insulation as an option for SIP wall panels.
                • Enabled insulated (filled) custom headers for windows, doors and garage doors: XPS, ISO, EPS, GPS, PU.
                • Insulated headers can be customized/created with the Global Settings similar to standard (OSB/PLY) headers.
                • Added a QHQ Single Hung window to the window draw and edit menus.
                wall_su1013_800.jpg wall_su1014_800.jpg wall_su1016_800.jpg wall_su1018_800.jpg
                All updates per customer requests.
                design.medeek.com
                • medeekM
                  medeek
                  Tutorial 74 - Insulated Headers (6:28 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 4.1.5 - 11.29.2025
                    • Enabled Green, Pink and Grey options for XPS headers and SIP wall panels.
                    • Added an option in the door draw and edit menus to change the door hardware material/color: None, Brass, Nickel, Bronze, Black, Copper, Gold.
                    • Updated the file/component loading method for door hardware and shearwall holdowns to increase plugin performance.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 4.1.6 - 11.30.2025
                      • Updated the context menus for walls with an “Edit Opening…” option if the selected (right click) wall contains a door, window or garage door.
                      • Added “Arial Bold” as a font within the Annotation Formatting section of the General tab of the Global Settings.
                      • Fixed a bug with Single and Double Hung QHQ windows.
                      • Added a QHQ Double Hung window to the window draw and edit menus.
                      design.medeek.com
                      • medeekM
                        medeek
                        Tutorial 75 - Updated Context Menu (5:22 min.)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 4.1.7 - 12.05.2025
                          • Enabled XPS (blue, green, pink and grey), ISO, EPS, GPS, and PU foam insulation within the wall sheathing options.
                          design.medeek.com
                          • medeekM
                            medeek
                            Tutorial 76 - Double Stud Walls (18:03 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              Tutorial 77 - Mitek vs. Simpson (11:00 min.)
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 4.1.8 - 12.13.2025
                                • Fixed a long standing bug where blocking was not created above and below doors, windows and garage doors.
                                • Fixed the blocking bug for rectangular, gable, shed and hip walls.
                                • Fixed a context menu bug (Edit Opening...) for gable, shed and hip walls.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 4.1.9 - 12.16.2025
                                  • Enabled the "Add Studs" feature for the following wall types: rectangular, gable, shed and hip.
                                  Tutorial 79 - Adding Studs (5:31 min.)
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 4.1.9b - 12.18.2025
                                    • Fixed a bug (door presets) introduced with door hardware material update on 11/29/2015 (Version 4.1.5).
                                    design.medeek.com
                                    Reply Quote 2
                                    • medeekM
                                      medeek
                                      Version 4.2.0 - 12.22.2025
                                      • Updated the opening and closing algorithm for all (panel) garage doors.
                                      Not a customer request, just an interesting kinematic challenge that I felt like addressing at some point. I found the previous garage door opening animation largely unsatisfactory for panel doors like these. Hopefully you can indulge me with a little gold plating... now back to the real stuff.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I have posted a FAQ for licensing questions on my website with the most common questions that I am asked, hopefully this is helpful:
                                        Medeek Design Inc. - Medeek Extensions - Licensing
                                        Medeek Design Inc. - Medeek Licensing
                                        (design.medeek.com)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 4.2.1 - 01.09.2026
                                          • Enabled the CUSTOM E casing for rectangular windows.
                                          • Enabled the CUSTOM H casing for rectangular windows.
                                          • Added a STYLE H casing option for rectangular windows.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 4.2.2 - 01.11.2026
                                            • Enabled the CUSTOM casing for trapezoid windows.
                                            • Enabled the CUSTOM H casing for trapezoid windows.
                                            • Enabled the CUSTOM casing for arched windows.
                                            design.medeek.com
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 80
                                            • 81
                                            • 74 / 81
