    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Tutorial 75 - Updated Context Menu (5:22 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 4.1.7 - 12.05.2025
        • Enabled XPS (blue, green, pink and grey), ISO, EPS, GPS, and PU foam insulation within the wall sheathing options.
        design.medeek.com
        • medeekM
          medeek
          Tutorial 76 - Double Stud Walls (18:03 min.)
          design.medeek.com
          • medeekM
            medeek
            Tutorial 77 - Mitek vs. Simpson (11:00 min.)
            design.medeek.com
            • medeekM
              medeek
              Version 4.1.8 - 12.13.2025
              • Fixed a long standing bug where blocking was not created above and below doors, windows and garage doors.
              • Fixed the blocking bug for rectangular, gable, shed and hip walls.
              • Fixed a context menu bug (Edit Opening...) for gable, shed and hip walls.
              design.medeek.com
              • medeekM
                medeek
                Version 4.1.9 - 12.16.2025
                • Enabled the "Add Studs" feature for the following wall types: rectangular, gable, shed and hip.
                Tutorial 79 - Adding Studs (5:31 min.)
                design.medeek.com
                • medeekM
                  medeek
                  Version 4.1.9b - 12.18.2025
                  • Fixed a bug (door presets) introduced with door hardware material update on 11/29/2015 (Version 4.1.5).
                  design.medeek.com
                  Reply Quote 2
                  • medeekM
                    medeek
                    Version 4.2.0 - 12.22.2025
                    • Updated the opening and closing algorithm for all (panel) garage doors.
                    Not a customer request, just an interesting kinematic challenge that I felt like addressing at some point. I found the previous garage door opening animation largely unsatisfactory for panel doors like these. Hopefully you can indulge me with a little gold plating... now back to the real stuff.
                    design.medeek.com
                    • medeekM
                      medeek
                      I have posted a FAQ for licensing questions on my website with the most common questions that I am asked, hopefully this is helpful:
                      Medeek Design Inc. - Medeek Extensions - Licensing
                      Medeek Design Inc. - Medeek Licensing
                      (design.medeek.com)
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 4.2.1 - 01.09.2026
                        • Enabled the CUSTOM E casing for rectangular windows.
                        • Enabled the CUSTOM H casing for rectangular windows.
                        • Added a STYLE H casing option for rectangular windows.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 4.2.2 - 01.11.2026
                          • Enabled the CUSTOM casing for trapezoid windows.
                          • Enabled the CUSTOM H casing for trapezoid windows.
                          • Enabled the CUSTOM casing for arched windows.
                          design.medeek.com
                          • medeekM
                            medeek
                            I just received a very long and detailed email from one of my power users and I was thoroughly impressed with many of the suggestions and usability notes provided to me.
                            A long standing issue has been wall cladding as it relates to exterior trim of windows and doors. Up until now if you place your trim on the sheathing (not on cladding) then the trim interferes with the cladding. This usually isn't too big of a problem (visually) provided your cladding is not thicker than your trim. However, in the real world you generally install your trim first and then butt your cladding up to it, so there is no interference. When your cladding is thicker than your trim or you are using one of the 3D cladding options (ie. board and batten) this does become a bit of an issue and for me personally has been an annoying lack of realism now for a few years.
                            To fix this I needed to enable an option where one can toggle the trimming of the cladding by the exterior trim and then add some logic and geometry into the current algorithms so that the end result is as follows:
                            I won't bore you with the details of the rather complicated logic under the hood that accomplishes this but suffice it to say it is not trivial. It will take about 4-5 days to complete this update.
                            The window algorithms are now updated but I will need to update the door and garage door methods as well now.
                            In the global settings one will be able to independently toggle this on and off for windows, doors and garage doors. I will also probably put out another tutorial video on this feature specifically so that everyone is clear on how it works.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 4.2.3 - 01.18.2026
                              • Added an option (global settings) to remove cladding with the exterior trim of doors, windows and garage doors.
                              design.medeek.com
                              • medeekM
                                medeek
                                Tutorial 80 - Removing Cladding (5:43 min.)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 4.2.4 - 01.19.2026
                                  • Added bypass (2 panel - solid) doors to the door module.
                                  This door type added per customer request.
                                  At some point I should probably add in the "barn door" type, these seem to be quite popular these days.
                                  design.medeek.com
                                    MtnArch
                                    Popular now, but give it another 5 years and there will be a new "it" feature to work with.
                                    Highest Regards,
                                    Alan T. Hendry, RA
                                    Architect
                                    medeekM 1 Reply Last reply
                                    • medeekM
                                      medeek
                                      Version 4.2.5 - 01.20.2026
                                      • Added an option (global settings) to miter trim for rectangular doors and windows.
                                      • Fixed a minor bug with the remove cladding feature introduced in Version 4.2.3.
                                      This update per customer request.
                                      design.medeek.com
                                      • medeekM
                                        medeek @MtnArch
                                        @MtnArch
                                        My last house had three of them and I found them quite clunky to use. They look nice but functionality is marginal.
                                        design.medeek.com
                                          MtnArch
                                          And privacy next to non-existent. I can see in a primary bedroom for the ensuite, but I see them being used for powder baths now, too. Yikes!
                                          Highest Regards,
                                          Alan T. Hendry, RA
                                          Architect
                                          • gullfoG
                                            gullfo
                                            anyone seeing my naked through my windows is all the punishment they need... 🙂 Mindwash® is very expensive... LOL
                                            Glenn
                                            http://www.runnel.com
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 80
                                            • 81
                                            • 75 / 81
