Medeek Wall Plugin
yeah, definitely depends on the gear a content creator needs. many will simply need a good computer, possible a good music keyboard or two, good video monitors, good audio monitors, and fresh air. many would fit into a 9x11 room but more would be better in a 12.4' W x 15' L due to best ratio for acoustics assuming 8' H ceiling.
Version 4.0.8 - 07.25.2025
- Enabled LSL as a wall framing material.
- Updated the material textures for LSL and PSL.
These don't seem like major updates however there are numerous places within the plugin that required updating and also during the process I was able to further refine and compress the code so it is now more efficient and better organized. Updates were made to the following modules: Walls, Stairs, Columns, Beams, Posts and Shearwalls.
Version 4.1.0 - 07.28.2025
- Added the following Simpson "Sage" post caps and bases to the post module: SAGE_B66, SAGE_C66, SAGE_T66
- Fixed a critical bug for custom materials within the stair module.
- Updated all of the move tools with upgraded wireframe previews and dimensions.
- Updated the window, door and garage door draw tools with a filled wireframe preview.
Version 4.1.1 - 08.17.2025
- Added Fixed - Slider (L) and Fixed - Slider (R) windows to the window module.
These two window types added per customer request.
Version 4.1.2 - 08.18.2025
- Added hexagon windows to the window module.
Note, that to get a regular hexagon window you will want to enter in a window height that is given by this formula:
height = width x 0.8660254
So for example if window is 48" wide its height will be: 48" x 0.8660254 = 41.569219"
One can always enter in any size for example an elongated hexagon or squished hexagon but I suspect most manufacturers will typically only stock a "regular" hexagon shaped windows in various sizes.
Version 4.1.3 - 08.21.2025
- Added a "Label Scaling" parameter for all wall types.
Update per customer request.
any future option on framing (wall and trusses) to include the plate end marks? e.g.
also on the blocking (noggin marks?) etc.?
I will be running a Thanksgiving promotion beginning Oct. 30th until Dec. 1st with 30% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS25.
This will reduce the bundle price from $280.00 USD to $196.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the Electrical, HVAC and Engineering plugins will also be included upon request at no additional cost. The offer ends on Dec.1st and no rain checks will issued thereafter.
Version 4.1.4 - 11.26.2025
- Added "GPS" and "PU" foam insulation as an option for SIP wall panels.
- Enabled insulated (filled) custom headers for windows, doors and garage doors: XPS, ISO, EPS, GPS, PU.
- Insulated headers can be customized/created with the Global Settings similar to standard (OSB/PLY) headers.
- Added a QHQ Single Hung window to the window draw and edit menus.
All updates per customer requests.
Tutorial 74 - Insulated Headers (6:28 min.)
Version 4.1.5 - 11.29.2025
- Enabled Green, Pink and Grey options for XPS headers and SIP wall panels.
- Added an option in the door draw and edit menus to change the door hardware material/color: None, Brass, Nickel, Bronze, Black, Copper, Gold.
- Updated the file/component loading method for door hardware and shearwall holdowns to increase plugin performance.
Version 4.1.6 - 11.30.2025
- Updated the context menus for walls with an “Edit Opening…” option if the selected (right click) wall contains a door, window or garage door.
- Added “Arial Bold” as a font within the Annotation Formatting section of the General tab of the Global Settings.
- Fixed a bug with Single and Double Hung QHQ windows.
- Added a QHQ Double Hung window to the window draw and edit menus.
Tutorial 75 - Updated Context Menu (5:22 min.)
Version 4.1.7 - 12.05.2025
- Enabled XPS (blue, green, pink and grey), ISO, EPS, GPS, and PU foam insulation within the wall sheathing options.
Tutorial 76 - Double Stud Walls (18:03 min.)
Tutorial 77 - Mitek vs. Simpson (11:00 min.)
Version 4.1.8 - 12.13.2025
- Fixed a long standing bug where blocking was not created above and below doors, windows and garage doors.
- Fixed the blocking bug for rectangular, gable, shed and hip walls.
- Fixed a context menu bug (Edit Opening...) for gable, shed and hip walls.
Version 4.1.9 - 12.16.2025
- Enabled the "Add Studs" feature for the following wall types: rectangular, gable, shed and hip.
Tutorial 79 - Adding Studs (5:31 min.)
Version 4.1.9b - 12.18.2025
- Fixed a bug (door presets) introduced with door hardware material update on 11/29/2015 (Version 4.1.5).
Version 4.2.0 - 12.22.2025
- Updated the opening and closing algorithm for all (panel) garage doors.
Not a customer request, just an interesting kinematic challenge that I felt like addressing at some point. I found the previous garage door opening animation largely unsatisfactory for panel doors like these. Hopefully you can indulge me with a little gold plating... now back to the real stuff.
