    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 4.0.5 - 07.16.2025
      • Fixed a bug with quadruple end wall studs (applies to all wall types).
      • Added the following Simpson Strong-Tie pre-assembled anchor bolts to the wall, column and shearwall modules: PAB6-12, PAB6-18, PAB6-24, PAB6-30, PAB6-36, PAB7-12, PAB7-18, PAB7-24, PAB7-30, PAB7-36, PAB8-12, PAB8-18, PAB8-24, PAB8-30, PAB8-36, PAB10-12, PAB10-18, PAB10-24, PAB10-30, PAB10-36.
      • Added the HTTH6.5 holdown to the built-in holdown library.
      Note, that these anchor bolts come in five different lengths (12, 18, 24, 30 and 36). I did not add in the 1/2 and 5/8 dia. anchor bolts since this option is primarily chosen when a much larger anchor bolt is needed, but do let me know if you would like to see them added in.
      Just playing catch up on a number of items after spending three or so weeks on the HVAC plugin. Undoubtedly, I am spread a bit thin these days with six plugins now under active development.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 4.0.6 - 07.17.2025
        • Fixed a bug with gable walls.
        • Added the following Simpson Strong-Tie pre-assembled anchor bolts to the wall, column and shearwall modules: PAB4-12, PAB4-18, PAB4-24, PAB4-30, PAB4-36, PAB5-12, PAB5-18, PAB5-24, PAB5-30, PAB5-36, PAB9-12, PAB9-18, PAB9-24, PAB9-30, PAB9-36.
        design.medeek.com
        • medeekM
          medeek
          Version 4.0.7 - 07.20.2025
          • Enabled the polyline draw mode for all wall justification options: Front, Center, Back, Sheathing.
          Tutorial 72 - Wall Justification (7:16 min.)
          design.medeek.com
          • medeekM
            medeek
            mdkBIM Tutorial 6 - Building a Ham Shack
            My initial concept of the ultimate Ham Shack (16' x 12') designed in SketchUp using the Medeek extensions.
            The model can be found here:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            My call sign is KK7UXO, but I don't get on the radio much, mostly I'm programming. :slight_smile:
            design.medeek.com
            • medeekM
              medeek
              Per customer request I will add in an LSL option for the framing very shortly:
              I'm using the updated LSL texture I created for the Floor plugin, but I still feel like it is a bit dull or dark compared to my previous texture (OSB). It could be a bit more vibrant or saturated. I will need to spend some more time on this.
              Weyerhaeuser sells their Timberstrand line of LSL framing and studs:
              TimberStrand® LSL Wall Framing & Studs
              Picks up framing where the code stops
              (www.weyerhaeuser.com)
              However, I would always worry about water damage. What happens if the LSL gets wet? We all know what happens to OSB, and plywood is a much more robust product in comparison. Standard lumber seems like a much more resilient choice when it comes to potential water damage, but I could be wrong.
              design.medeek.com
              • medeekM
                medeek
                Some Youtube viewers of this video reached out and told me that they had more equipment than could reasonably fit within such a small structure. I agree, maybe a 16'x12' space is a bit cramped for anyone, especially if you are also using it for a content creation studio. This is where the parametrics of the extensions come in real handy:
                The model(s) can be viewed and downloaded here:
                3D Warehouse
                design.medeek.com
                Reply Quote 2
                • gullfoG
                  gullfo
                  yeah, definitely depends on the gear a content creator needs. many will simply need a good computer, possible a good music keyboard or two, good video monitors, good audio monitors, and fresh air. many would fit into a 9x11 room but more would be better in a 12.4' W x 15' L due to best ratio for acoustics assuming 8' H ceiling.
                  Glenn
                  http://www.runnel.com
                  • medeekM
                    medeek
                    Version 4.0.8 - 07.25.2025
                    • Enabled LSL as a wall framing material.
                    • Updated the material textures for LSL and PSL.
                    These don't seem like major updates however there are numerous places within the plugin that required updating and also during the process I was able to further refine and compress the code so it is now more efficient and better organized. Updates were made to the following modules: Walls, Stairs, Columns, Beams, Posts and Shearwalls.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 4.1.0 - 07.28.2025
                      • Added the following Simpson "Sage" post caps and bases to the post module: SAGE_B66, SAGE_C66, SAGE_T66
                      • Fixed a critical bug for custom materials within the stair module.
                      • Updated all of the move tools with upgraded wireframe previews and dimensions.
                      • Updated the window, door and garage door draw tools with a filled wireframe preview.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 4.1.1 - 08.17.2025
                        • Added Fixed - Slider (L) and Fixed - Slider (R) windows to the window module.
                        These two window types added per customer request.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 4.1.2 - 08.18.2025
                          • Added hexagon windows to the window module.
                          Note, that to get a regular hexagon window you will want to enter in a window height that is given by this formula:
                          height = width x 0.8660254
                          So for example if window is 48" wide its height will be: 48" x 0.8660254 = 41.569219"
                          One can always enter in any size for example an elongated hexagon or squished hexagon but I suspect most manufacturers will typically only stock a "regular" hexagon shaped windows in various sizes.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 4.1.3 - 08.21.2025
                            • Added a "Label Scaling" parameter for all wall types.
                            Update per customer request.
                            design.medeek.com
                            • gullfoG
                              gullfo
                              any future option on framing (wall and trusses) to include the plate end marks? e.g.
                              also on the blocking (noggin marks?) etc.?
                              Glenn
                              1 Reply Last reply 👍
                              • medeekM
                                medeek
                                I will be running a Thanksgiving promotion beginning Oct. 30th until Dec. 1st with 30% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS25.
                                This will reduce the bundle price from $280.00 USD to $196.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the Electrical, HVAC and Engineering plugins will also be included upon request at no additional cost. The offer ends on Dec.1st and no rain checks will issued thereafter.
                                design.medeek.com
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 4.1.4 - 11.26.2025
                                  • Added "GPS" and "PU" foam insulation as an option for SIP wall panels.
                                  • Enabled insulated (filled) custom headers for windows, doors and garage doors: XPS, ISO, EPS, GPS, PU.
                                  • Insulated headers can be customized/created with the Global Settings similar to standard (OSB/PLY) headers.
                                  • Added a QHQ Single Hung window to the window draw and edit menus.
                                  wall_su1013_800.jpg wall_su1014_800.jpg wall_su1016_800.jpg wall_su1018_800.jpg
                                  All updates per customer requests.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Tutorial 74 - Insulated Headers (6:28 min.)
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 4.1.5 - 11.29.2025
                                      • Enabled Green, Pink and Grey options for XPS headers and SIP wall panels.
                                      • Added an option in the door draw and edit menus to change the door hardware material/color: None, Brass, Nickel, Bronze, Black, Copper, Gold.
                                      • Updated the file/component loading method for door hardware and shearwall holdowns to increase plugin performance.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 4.1.6 - 11.30.2025
                                        • Updated the context menus for walls with an “Edit Opening…” option if the selected (right click) wall contains a door, window or garage door.
                                        • Added “Arial Bold” as a font within the Annotation Formatting section of the General tab of the Global Settings.
                                        • Fixed a bug with Single and Double Hung QHQ windows.
                                        • Added a QHQ Double Hung window to the window draw and edit menus.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Tutorial 75 - Updated Context Menu (5:22 min.)
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 4.1.7 - 12.05.2025
                                            • Enabled XPS (blue, green, pink and grey), ISO, EPS, GPS, and PU foam insulation within the wall sheathing options.
                                            design.medeek.com
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 80
                                            • 81
                                            • 74 / 81
