    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • pixelcruncherP
      @Krass said in Rayscaper New Releases:
      I just installed version 9.7.0. I'm testing with a new file, a cube that I place on a "cube" tag.
      If I hide the cube tag, Sketchup crashes.
      if i open an existing model and launch Rayscaper and reveal a hidden tag sketchup crashes
      Hey @Krass
      I'm not following your workflow. What do you mean by placing on a "cube" tag? Do you create the cube and then tag it or do something else first? Would be great if you could send me a quick screen recording or some screenshots of your workflow.
      Cheers,
      Thomas
      • pixelcruncherP
        @Krass Can you e-mail or DM me this scene so I can have a look? Thanks!
        • KrassK
          Krass
          I just sent you an email
          Krass
          • KrassK
            Krass
            Hi, I had to reinstall SketchUp 2024 and I can't install Rayscaper 9.7.0. Thanks for your help.
            Krass
            • pixelcruncherP
              @Krass, I'm working on a fix for 2024. I will keep you posted.
              • KrassK
                Krass
                That's strange, because I previously managed to use RS in SU 2024...
                Krass
                • pixelcruncherP
                  @Krass True, but we found a bug in the SketchUp SDK (https://forums.sketchup.com/t/sdk-compatibility-issue-sureftype-enum-change-between-2024-and-2026-sdks/341530/9), that didn't surface yet in older versions of Rayscaper because we weren't using that code. It got broken in one of the previous updates. EDIT: 2025 and 2026 are fine; this only impacts 2024.
                  • KrassK
                    Krass
                    No worries, in the meantime I reinstalled my version 9.6.4 which works fine, good luck!
                    Krass
                    • pixelcruncherP
                      @Krass I sent you an e-mail with a test build. Let me know if it works (or not).
                      • KrassK
                        Krass
                        yes! thanks Pixelcruncher, thanks for this so fastresolution, it works well
                        Krass
                        • pixelcruncherP
                          Hey, Rayscaper users!
                          Rayscaper 0.9.72 Beta is available. You can get it via:
                          • The SketchUcation store.
                          • Direct download: link.
                          I recommend upgrading to the latest version.
                          What Changed?
                          • Rayscaper now supports direct integration with the Skatter plugin. Render-only Skatter data can now be ingested directly from Skatter, bypassing the
                            SketchUp viewport. This offloads complex instancing and geometry handling to Rayscaper, keeping SketchUp responsive and lightweight during rendering.
                            Perfect for large vegetation or scattering setups β€” just hit render and let Rayscaper handle the heavy lifting. (@ntxdave Thanks for connecting me with the Skatter people).
                          • Bugfix: push/pull geometry would not properly propagate to Rayscaper.
                          • Fix Rayscaper for SketchUp 2024, caused by a breaking change in the SketchUp SDK. Note: Going forward, Rayscaper will only support the latest three
                            SketchUp releases because now that it's for sure that the SDK is not backwards compatible, it's too much overhead for me to maintain more versions. The
                            current version supports: SketchUp 2026, SketchUp 2025 & SketchUp 2024.
                          • Make materials assigned to a SketchUp group or component instance work again. cc: @sashapepperspray
                          Here's a screenshot of a simple forest I created using Skatter:
                          Help Me Build the Community πŸ‘
                          If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities
                          to new users.
                          Follow me on https://x.com/rayscaper3d.
                          Happy Rendering!
                          Thomas
                          S 1 Reply Last reply
                          • ntxdaveN
                            ntxdave
                            But now I need to be remember how to make RayScaper work with Skatter.
                            Press F1...thank me later
                            • ntxdaveN
                              ntxdave
                              So far, I cannot get Rayscaper to work with Skatter. Need some help.
                              • KrassK
                                Krass
                                That's impressive! With Skatter... well done!
                                Krass
                                ntxdaveN 1 Reply Last reply
                                • ntxdaveN
                                  ntxdave @Krass
                                  Don’t know what I am doing wrong but it is not working for me. 😞
                                  • KrassK
                                    Krass
                                    I don't use Skatter... sorry
                                    Krass
                                      sashapepperspray @pixelcruncher
                                      @pixelcruncher thank you very much!
                                      • pixelcruncherP
                                        pixelcruncher Extension Creator @ntxdave
                                        @ntxdave Can you provide some context on what's now working?
                                        As soon as you have a Skatter composition, click generate, and the skattered items should appear in Rayscaper. I will create a demo video later. It would be great if you could provide a screenshot (or video) of what youare seeing. Just saying "it doesn't work" isn't providing me much to help you.
                                          Thanks Thomas. I think the inclusion of Skatter will make for a more capable render program and enable us to produce better results, getting to grips with it is the issue a few of us will have but keeping on will be the answer.
                                          Step by step, tbh, I have never had a decent result but that is me and NOT Skatter at fault.
                                          • ntxdaveN
                                            ntxdave
                                            OK - Some progress. Although there are some problems, I just did a new test and "kind of" got it to work. Although the grass and bush colors are wrong in the rendered copy, here is the result of the test.
                                            As I said, this is progress but so far, I can only get this to work with a new project. If I go back to an existing model, I cannot get things to work with an old/existing model. I do cannot get the Generate option to show up.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 37
                                            • 38
                                            • 12 / 38
