[Plugin] Material Browser - v1.1.2 - 15 Nov 2026
Issue persists at the moment...
What is strange is that recently we encounter an error unzipping with Sketchucation Tools 5 that was related to IPv6.
Not sure if this is similar just sharing as much info as I can.
This looks like a great tool Samuel. Unfortunately I'm not seeing a way to use the textures from it. I am not seeing the error message Rich shows but clicking on a material doesn't seem to do anything unless the material is already in the local Materials folder. This is also with SU2026 on Windows 11.
Same in v2023
SketchUcation tools only loads the ZIP gem stuff if it hasn't been already loaded [required].
I suggest you adjust your code to do the same.
It doesn't break things. it just warns about it already being installed ? -
@Dave-R
Thank for your interest. What was the source of the material you were targeting? The active model, a local collection, or Poly Haven?Once selected in the Material Browser plugin window, a material can be applied in the SketchUp scene with the Paint Bucket tool.
In your case, selection seems to have succeed... Did the plugin add wanted material to the model and select the Paint Bucket tool?
I wonder if this timeout appears outside SU
Can you please open this URL in your browser?https://api.polyhaven.com/info/fabric_pattern_05If request was successful, you should get JSON.
Was this response "instant" or "seconds long"? -
@Rich-O-Brien And you obtained JSON, isn't?
I suggest you adjust your code to do the same.I will. Thanks for your suggestion.
Seems
By the way, SketchUcation Tools v5.0.2 bundles Rubyzip v1.1.6, whereas Material Browser v1.1.0 bundles Rubyzip v1.3.0.
Upon GitHub tags, this latter is the highest version compatible with SketchUp 2017 (Ruby v2.2.4), since Rubyzip v2.0.0 requires at least Ruby 2.4. -
Incidentally, our test is...
[Assume a valid path to load the RB files]require('zlib') unless defined?(Zlib) require('zip') unless defined?(Zip) -
Thanks @TIG
@samuel_t said in [Plugin] Material Browser - v1.1.0 - 12 Oct 2025:
Yes. Near instantly
{"type":1,"date_published":1590810670,"name":"Fabric Pattern 05","old_id":262,"authors":{"Rob Tuytel":"All"},"dimensions":[500,499.9999403953552],"max_resolution":[8192,8192],"categories":["fabric","cotton"],"files_hash":"be7f619f251a6ba2f829e658c6a20948cdc18a4f","tags":["plain","cloth","towel","checker","checkered","plaid","grid pattern","windowpane plaid","upholstery","textile ","woven","drape"],"description":"Free 8K cotton fabric texture with a soft, woven, slightly nubby surface and natural drape, olive‑khaki base with thin deep‑blue windowpane plaid grid.","download_count":159063,"thumbnail_url":"https://cdn.polyhaven.com/asset_img/thumbs/fabric_pattern_05.png?width=256&height=256"} -
@Rich-O-Brien Thanks. I need to figure out why it fails in SketchUp...
Hello,
Material Browser v1.1.1 is out
Here what's new:- You can precisely choose which sources to display:
- Interface is more reactive and more predictable (status bar).
- Source logos and material names are proportional to thumbnails.
- Plugin window can be resized to a smaller width and height.
- Poly Haven catalog has been extended to 713 textures.
- Texture downloading is more robust (3 attempts before giving up).
- On SketchUp open, toolbar position and visibility are restored.
- It shouldn't emit warnings when SketchUcation Tools is installed.
Thanks to @judedouch and @ateliernab for their suggestions.
Download latest Material Browser plugin from SketchUcation PluginStore.
Hello friends,
Material Browser 1.1.2 has just been released, it extends the Poly Haven catalog to 869 textures.
Download the latest Material Browser plugin from the SketchUcation PluginStore.
@samuel_t
Wish you could make it work with Modlumi.
